[ame="http://youtu.be/303iU_hAJ_Y"]http://youtu.be/303iU_hAJ_Y[/ame]
If you are installing a Brake Duct Kit on your Bmw e36 M3 it is most like you have a Big Brake kit Right?
So why not have Backing Plates that are designed to fit your StopTech or Brembro Big Brake kit!
Here is your answer the Hard Motorsport BBK Brake Duct Kit Bmw E36 M3. Other Backing Plates are very
small and only fit insides a factory rotor hat, which is about an inch smaller than the hat size of a 332mm
bbk so air just blows out the sides instead of going through the vents of the rotor which it is made to do.
Also there is no heat shield to protect from heating up your oil in your shocks which will thin the oil and
change the dampening.
So the Hard Motorsport BBK Brake Duct Kit Bmw E36 M3 is design to fit inside the hat of a bbk and also has
a heat shield that protects ball joints.
This kit mounts to the frame of your Bmw M3 so that you can remove your front bumper and the Brake
Ducts stay in place for fast track repairs.
Kit Includes:
Backing Plates for Big Brake Kits Powder Coated
High Temp Flex Tubing
Hose Clamps
Aluminum Powder Coated Tubing
Silicon Coupler
ABS Brake Duct Intake for E36 M3 Front Bumper
Frame Mounting Bracket
http://hardmotorsport.com/Hard-Motor...BBKDUCTKIT.htm
EVERYTHING YOU NEED NO DRILLING REQUIRED DIRECT FIT! THIS KIT IS MADE IN THE USA!
MANUFACTURED IN OUR 8,000SQFT RACE SHOP WITH PERFORMANCE AND LONGEVITY IN MIND
Sweet.... Nice work! any chance you can show a picture of the brake duct with the front bumper take off? interested in how it connects to the frame.
Monday I will be back at the race shop and take some pictures before I head down for the 24hr at daytona.
That's really cool. Great job on the manufacturing and fitment. A heatshield for the ball joints is a pretty neat idea.
In order inlet, coupler, aluminium tube, flex duct, backing plate.Originally Posted by uconnr
The aluminum tubing mounts to the frame and the inlet stays in place so removal of the front bumper is possible without messing with the brake cooling system.
I will have picture of this kit installed tomorrow when I'm back at our race shop.
Here is a picture of a similar setup on a Honda BTCC race car.
Yes no problemOriginally Posted by xsport652
Interesting, but really, really do need those installed pix.
Neil
E36 3, StopTechs
Thanks James.Originally Posted by thedizzle
I will post pictures of his setup also custom made for his e39 M5 race car.
Sorry for the Delay I have been very busy trying to take care of things at the race shop before I leave for the Daytona 24hr tomorrow
quick video
wow. nice. can you get full steering lock with those in place?
David Ortiz
Interesting, but the video doesn't help to understand how/if the system fits a car with fender liners...or a radiator and its ducting. The way the intake scoops remain on the car when the bumper is pulled is really nice.
Neil
Fender liners will have to be modified. As per the duct hole are square and my kit is 3in and retains 3in the whole life of the air flow. It stays clear of radiator ducting. This is designed for track/race car applications.Originally Posted by NeilM
Yes they will hit at full lock. As does any kit but where in other kits you tear though $100 of flextubing this kit only will touch an aluminium tube and the kit stays in tacked with no holes. We are working on a steering reducer product currently.Originally Posted by odortiz
How much lock can you get before it touches the Alu? With my current setup I get roughly 1.5 turns.
These already exist for very cheap. http://www.turnermotorsport.com/p-42...-stop-kit.aspx
I like your inlet mounting. Will you sell parts of this kit piecemeal?
-tammer
Thanks James. Rich, Dave, and Eric are working today. I CALLED RICH TO MEASURE TOUCHING POINTOriginally Posted by thedizzle
Sorry I will be out for the week in Daytona.
Roughly 1.5 turns from center but that will very from car to car with different tire setups and and offsets. I suggest running steering limiters to prevent damage.
And yes I will have individual pricing up later once I get to the track at daytona tonight
Looks very nice.
Have you checked fit with a Motion Motorsports underpanel installed? I ask because the uprights on mine got in the way for routing the way I think you may have it running.
Thank you!
Im not sure On the on that underpanel I do not carry any of there products. but we are developing an under tray/ splitter that stays on the front bumper to allow access to the front of the car, thats why we designed this kit that stays on the car so at the track you can quickly remove the bumper without unbolting your cooling ducts and soon your splitter.
Looks great
Pricing for Cooling ducts without Backing Plates
http://www.hardmotorsport.com/Hard-M...BBKDUCTKIT.htm
Look great! Your fitment of the backing plates for the E39 M5 Brecus Motorsport race car has created quite a lot of interest in these for E39s on the M5board. I for one have been looking for an option for such plates and ducts other than having them custom made out of carbon fiber. I know at least three or four others would be in for a set as well. Please make them!
--Peter
