Thread Tools |
Drivers side wiper stops working...
My drivers side wiper stopped working the other day. When I removed the cabin air filter housing (could see the clutch/ brake fluid resevior), I found that the ball & socket joint had separated. I just popped them back together, but I am sure it will happen again. There seemed to be some slack & wear. Can the ball joint be replaced/ repaired?
The whole drive arm is only $10, but there would be lots more work involved... I'd love to find a way to fix just the joint.
1999 M3 Vert
1997 528i (totally stock for now) 2009 Ford Flex Cape Breton, Canada |
Bump....
1999 M3 Vert
i have the same problem but on my passanger side
drill a whole that goes straight thru the cup and the ball, then install a bolt and a nylock style nut onto it. tighten it up enough to stop the cup coming off the ball but not so tight as to cause any extra friction. i did this as an emergency repair about a year ago and still have not had to replace it yet
the threading / bushing is finished I repaired about 10 of these on other vehicles, the temp repairs are not great as if it starts to rain / snow my friend you are in trouble if it stops working (it happend to me
)go to the wrecking yard or someone who is parting out and purchase the entire wiper linkage. I will give you an estimate for a pos tercel the linkage was 490 dollars at the dealer (worth more then the car) I ripped the part off a scrapped car for 30 dollars. its a little bit of work to get into the area where it sits, and quick tip if you get it off a car that is sitting for a while, lube the joints (with the covers) with some grease best of luck |
| Bookmarks |
| Thread Tools | |
