Im selling my setup I was going to use on my Corrado. They are too wide to use on a VR6 but have perfect spacing for an M50 or M52 engine. Infact the company that makes these throttle bodies makes a head plate for an M50/M52.
These are extrudabody ITB's 45mm bore.
http://extrudabody.com
I am including the 90mm bore to bore weld plate, 6 ITB's, 6 air horns, throttle linkages, throttle cam and stops, return springs (you will still need some larger carb return springs on the manifold) Webber IDF base plates, GM style TPS, filters, 3 addon stacks (can be cut in half and used on all 6)
The fuel rail is only 18 inches long, so it would be too short for an M50/52, but I will include it with all the mouting hardware. (you can get just the stock from extrudabody)
All of this is new. I have all of the original boxes ETC. I really wish these would fit, but they are too long for a VR6.
I am asking 1100 shipped OBO I have about 1400 into these.
NO LOWBALLERS
Last edited by piercedwinky; 04-02-2008 at 12:55 PM. Reason: no one ever said I could type
ChuD
bump, want these gone so I can buy a setup that fits the dub
ChuD
might want to change the link you have.. its www.extrudabody.com not exutrudabody
98 Estoril ///M3 4/6
S54 swap CSL
Bump cause i have seen this set up first hand and its beautiful!!!! A bit wide for a VR but would go perfect on the 6.....AHHHHhhhhh i need money!!!
very nice setup.
custom plenum + boost would make these throttles very happy
No animations? 2001 called, they want their forum rules back.
Bump, need these gone.
ChuD
bump, that's a nice part
99 TitanSilber ///M3
13.90 @ 101 mph
i wish i could afford this .... this is my dream performance upgrade....free bump
CORBEAU CR-1 SEATS--SPARCO RACING HARNESS--SCHROTH HARNESSES--JTD UNDERPANEL...
ALL FOR SALE
PM ME
bump... what would one have to do "chip" wise for tuning on a E36 M3? or would they not work?
E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
*RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
o how i want these
wow that would be so bad ass in my e30 with ms lol bump for a bad ass project
bizzumb
ChuD
How much would it cost to have that setup running on an M52. I guess it would need standalone to run it. Right?
Cost of ITB's plus a weld plate for the m52... and standalone unless you can tune for alpha-n on standard management.
Depending on how much of your own work you can do figure in another 800 to have it up and running completely (stand alone, manifold, odds and ends needed for your specific setup.)
ChuD
would these work on a stock M20 and how much would it require to have it running right?
S50 in progress.....
See my above post, the proceedure would be similar to the m50/m52
ChuD
Bump need these gone
ChuD
ChuD
I can not believe this set up is still forsale. We will see how money goes come time to put the 6ers motor in i may just snag em and have you build me a squirt set up.
No one on here has the balls to rock something that isn't factory
For an additional charge I will build an MS ecu for a car. but I wont go anywhere to wire it. I have enough wiring to do owning 2 VW's
And Russ if I still have these when you put the 6 together you don't have a choice. BTW do you have a bentley for that car so we can look at wiring diagrams??
ChuD
Still for sale bump
ChuD
