The dreaded thread but here goes:
Build Month/Year: 01/2007
Type: E90
Model: 335i
Miles: 13,000 miles
Major problem(s): Fuse box assembly box not correctly installed
Minor problem(s): Reoccuring (2x) false indicator that brake pads need to be replaced.
Modifications: Golf-tee mod and Euro foglight switch
06 750i E65 (CPO), Titanium Silver/Black Leather, Packages: Convenience, Luxury Seating, Premium Sound and Rear Entertainment, Heated Steering Wheel, Comfort Access and Sirius
Sold: 07 E90 335i (shouldn't have gotten the sports seats)
Build Month/Year: 05/2007
Type: E92
Model: 335i
Miles: 18,5XX miles
Major problem(s): None
Minor problem(s): None
Modifications: None
The only issue I had, was the sidewall of my left front tire had a bubble. Most likely from a pothole. RFT Coverage took care of that for me.
I think people should also mention if their cars are modified with any piggybacks or anything else as it may possibly skew results, such as people throwing CELs.
What would Crockett and Tubbs do?
1994 E36 Hellrot/Black 325is
2007 E92 Jet Black/Saddle Brown 335i
I've parked this thread since it can prove useful to some that are looking for others who may have experienced similar problems. Thanks to the OP for posting it.
I'll just remind everyone to keep it strictly for listing issues. Any discussions pertaining to those issues can be put in a different thread (or threads) as need be, this way we don't pollute this thread. Also please come back and update your original posts and don't create duplicate posts.
I will monitor this thread and move noncompliant posts accordingly, but help from posters is much appreciated.
Current Car (delivered 20/10/21): 2021 G80 M3; 6MT; DravitGrau/Kyalami Orange/Black Extended Merino; Permium Pkg (ZPP); 826M bicolor wheels; Black M Compound brakes; Sunroof (yes no CF roof)
(more pictures here)
Previous Cars: 2018 F30 340ix 6MT Msport(Dec 2017 - Sep 2021); 2013 F30 335ix 6MT Msport (Nov 2013-17); 2011 e90 328i 6MT ZSP (Aug 10-Nov 13); 07 e90-323i ZSP (May 07 - Aug 10); 97-318ti ZSP (Feb 97 - May 07)
"Mit der Dummheit kämpfen Götter selbst vergebens", Friedrich von Schiller -- "Life is simple, people make it complicated", Me (About me)
Overall it's been a dream. Just turned 13000 miles. Delivered Jan 07.
1. My biggest complaint is with the run flats. I got a huge hole in my tire between Indianapolis and Cincinnati on my way to a Cubs game. Technically I should not have driven the distance that I did but I was running late for the game. A Chevy dealer plugged it for me. Hate the whole concept of run flats so I keep a spare in my trunk now.
2. The seatbelt presenter. Just a dumb looking POS that keeps getting more fragile by the day. My passenger side presenter refuses to retract all the way now unless I force it in. I'm sure my dealer will spend four hours fixing it. What a waste of engineering effort.
3. Had the light bulb sensor go off though my lights were all working fine. Took the dealer three hours to reset it.
4. I can't stand the pretentious nature of bimmer dealerships. Can't explain this one but I find Audi and Ford dealerships to be more down to earth.
Build Month/Year: 10/2007
Type: E92
Model: 328i
Miles: 28,200 miles
Major problem(s): Ticking at idle (especially after cold start). Problem has grown louder since I first noticed it weeks after delivery. I had the bleeding procedure outlined in SIB 1109 075 (performed at 28,000). The noise is no longer present, but if it returns, I will need to have my cylinder head replaced.
Minor problem(s): CBS data incorrect for brake pads (required reset 5 times). Brake pads no longer squealing like stuck pigs, but only after: Brake pad sensor wires trimmed, pads resurfaced, still squealing. Trimmed and resurfaced again. Eventually replaced all four pads and each axle sensor at 21,000 (approx.) Four (4) new tires needed at 17,800 miles - replaced with OEM Bridgestone Potenzas -- I paid for the rears and BMW paid for the fronts in an effort to appease me due to the tire's short service life, and high price. 28,000 miles: Driver's side front seat not flipping forward and back smoothly -- rear trim piece of seat replaced. Also: Trunk storage compartment handle replaced.
Modifications: SSK, OEM M Dead Pedal, BMW aluminum pedals, Bumper Reflector Delete, Flat Black Kidney Grille, Hardwired Bel Tronics Rx65, Rear Fogs Enabled, Lamin-X Fog light covers, Black Emblem overlays, Debadged
Type: E92
Model: 335i
Miles: 39,000 miles
Major problem(s): None - unless you consider a bad fuel pump major (see my minor prob)
Minor problem(s):
1. Rear bumper tow cover fell off - dealer replaced free
2. C/D player continues to run (without sound) CD even when I turn the car off or when I switch to tuner - so when I go back to CD, it's not where I left it, and still running. --- this stopped happening (spontaneously)
3. At 7200 miles it kicked and knocked - I figured HPFP, they said CPU needed reset, was getting lean fuel mixture. It's happening again at 9,000 miles - not happy. This time, I was told I needed a new (HPFP) fuel pump. (See #4)
4. HPFP replaced - took two days, I had a 535 loaner and my car's been running like a champ since. Overall, I'm happy. Still happy!
5. HPFP replaced (yes, again) - 30k miles, long crank on start up, took it in over lunch, they drove me to work, picked me up at 5 all finished.
6. HPFP replaced (yes, again and again) - 38,500 miles, got a 'reduced power' warning light. The dealer picked up my car out of my garage, replaced the fuel pump and parked it back in my garage while I was on vacation. Runs like a charm again...stupid fuel pump.
Modifications: None
8000 mls and had to add 1 quart of oil
e92; 12/06 build; 11,000 miles; no problems!
Mods: dlr installed oil cooler, tee mod, seat belt mod, visor sticker mod, K & N filter, Turbo Tuner
2007 335i Coupe
Mileage: 19,000
Manufacture Date: 10/2006
Issues.. man, a little more than I was expecting but thank God for warranty.
-Biggest would be with the Run Flat Tires, replaced both which balded by 10,000 and ALSO had punctures from a nail or something in them.
My rear tires at 19k (replaced at 10k fresh new), are NOW bald again. I do not even launch or burn out hardly ever, maybe a couple times. I drive fairly decent, just punching it occasionally on the free way.
-At 17k.. Steering Lock sign would not turn off, had it checked out, turned out they replaced the WHOLE entire Steering Column.
-Service at 13k.. apparently there was a programming recall for the navigation they updated
besides that, I've noted from the beginning til now, the engine does heat up quite a bit with heavy driving but not so much anymore, i avoid hammering the crap out of my car and only occasionally punch it, mostly on the freeway
2007 335i
alpine white
automatic
sport pckg, premium pckg, cold weather pckg, navigation, blue tooth
e90 330xi built 01/06
mileage-33000
no majors
only minor was the tires that came with it. the bridgestone rfts were crap. i swapped with non-rfts michelin pilot sports and its like a totally different car. other than that my ultimate driving machine has been perfect, lets hope the next two years are as good!
Build Month/Year: 6/2005
Type: E90
Model: 325i
Miles: 39,000 miles
Minor problem(s): rear window regulators, pass. seat occupancy sensor
Modifications: None
Doug (BMWCCA HPDE Instructor, Respect My Authoritay!)
1999 Titanium Silver M3 track Rat
2017 F250 Powerstroke
2004 M3 Widebody, LS
2007 335i
miles- 25,000
problems- power steering out, run flats sensor, radiator
thank god for warranty
06 330xi
No Majors, O2 sensor had to be replaced.
Like merchantmariner said, once i replaced the bridgestones that came with the car it felt much smoother and less road noise.
Oh. One thing actually, i have the convenience key package and i'd say it works like 30-40% of the time while its in my pocket. Someone suggested that maybe the tint was interferring? I have only 25% tint, any ideas?
05/2007
E90
335i
20,000 miles
No major problems
Changed squeaking brakes when accelerating from a stop, and replacing tires 4 times due to nails(tire warranty paid for itself).
Bone stock
Build Month/Year: ?/07
Type: E91
Model: 328xi
Miles: 34,000 miles
Minor problem(s):
Steering wheel lock: flash update worked for 2 weeks now I get a permanent code warning me not to turn my car off. Need to get it back in...
Drivers Door Tweeter: replaced for crackling sound, lasted 2 weeks now it crackles again... I think the crossover is gone
Pano Sunroof: Makes a lot of noise on the highway, dealer performed the software update... still makes nose...
Modifications: KW V3 and Breyton Race GTS
2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
Coming soon: and a visit to Randy Forbes
We had an E91 come in today that was out of warranty (over on the miles); that was a bit strange.
out of no where, my car felt like it was running on 2 cylinders.. no acceleration, was not keepin an idle..
i restarted and it was fine. they told me to bring it in if it happens again... how reassuring.
-Paul
If you can't dazzle em with brilliance, baffle em with bullshit
http://paulio.net/
http://vepix.net/
http://mensalmanac.com/
Build Month/Year: 12/2005
Type: E90
Model: 325i Prem
Miles: 29,XXX miles
Minor problem(s): Weather strip ware, Seat Airbag sensors
Modifications: when the warranty runs out.
Notice the worn out weather strip just above the door catch, this was covered by the factory warranty in my case, both sides were replaced.
I've updated my info in my post to include regular maintenance, feel free to do so for your posts.
Both wategates replaced, a sensor sent the car into safe mode and that took a month to fix. New tires $1250...yikes
Seems like more trouble than I have ever had with a car.
06 325i w/31K miles
-left fog light got loose (on one side) while on a highway - luckily fixed by dealer under warranty (dealer replaced fog light and bracket supporting it) but common BMW!!!!! how can anything get loose in a car???????
Type: E90
Model: 323i
Build Month/Year: 04/2007
Delivery Date: May 25, 07
Delivered Miles: ~5 miles
Current Miles: approx 23,000km (14000 miles)
Minor problem(s): CBS data incorrect for brake pads (required reset), car left in economy mode at delivery (required reset otherwise won't rev beyond 4500rpm) + cracked windshield (fixed by dealer and covered by my 0 deductible comp. ins.). At around 23000 km they had to take apart the diff and grease it due to a clicking noise at launch (PUMA Measure #4670944, see this post http://forums.bimmerforums.com/forum....php?t=1029234).
Modifications: Cosmetic + wheels (see my sig)
Regular Maintenance: Oil change done at 1 year interval (at ~20,600 km and CBS was indicating ~2500 more to go) - FREE, microfilter replaced at same time - FREE, wiper bladed replaced at same time (63$).
Oh yeah, I had a nail in one of my tires which was eventually replaced for no cost under my tire hazard warranty, had to go in twice though, once to get them to take my tire info and order one + take photos to submit the claim and another to get the tire replaced once it arrived. Even with 4 dealer trips, I'd still rate reliability as excellent since none of these issue were anything but a minor annoyance and they got taken care of promptly and expertly. I sure hope the next 2 years are as smooth, knock on wood.
Bought mine 4/08 w/35K miles. Recently, my moon roof stopped working. Dealer said it needed to be reprogrammed. Yesterday, "Service Engine" light went on. Another trip to the dealer.
But, it's under warranty, and they have great loner cars. Other than that, LOVE the car.
