Hello, can you send me please the password for carsoft? I have crack folder with 4 files. Thanks.
Michal.Humlicek@centrum.cz
hey guys i also am having a problem i get bad communication issue i need the proper 10 file crack as i lost the cd that came with the interface thanks ,email : oowwnn@sapo.pt
Hello!
First of all, sorry for my english.
I have ordered from China this kit (see image bellow)
I install'd BMW Scanner (PaSoft) V1.3.6 who came along with interface and adapters.
Then i connected 20pin adapter to my e36 93" and to PC's COM port.
Power and K-Line led indicators turned on (Both was red color)
When i started to scan for DME it showed an error "No communication with unit"
And with BMW CarSoft 6.5SP1 it showed "Bad Communication" too...
But with Carsoft on unit sync K-Line led turned green, but when it show'ed error it turned back to red color...
I disambled 20pin adapter and there i found 3 wire who was connected to RS232. GND 19pin, +12V 14pin and on wire to 20pin.
pin 15, 17, 20 was soldered with wires together...
Anny ideas why i can't run diagnostic ?
Why would a PA Soft interface work for Carsoft? Different company..different software.
Hello David
Hope you are doing good.
I'm getting these codes (car is runs fine and it has a Cold Air intake)
Can you help me?
DME/DDE module
18 EMS - faulty signal / signal cam shaft encoder (MS43)
From the electronic-Wegfahr backup (EMS) took place at the
Launch attempt no release for the DME.
Check the battery in the ignition key, the connections
At the EMS and the ERM link - DME.
ZKE/ZVM module
7 module is not coded
Airco/HKL module
1 temperaturwählrad right
Thank you
Air
It is telling you that there has been a problem with the EWS and to check the supply voltage at the ignition and electrical connections between the EMS and DME. This could have resulted from an intermittent fault, blown fuse or low battery voltage. My first suspicion would be battery voltage (below 12.5v at the diagnostic port). The airco/HKL fault relates to the temperature control knob for the aircon and is usually just caused by an accumulation of dust behind the control panel - taking the faceplate off and blowing it out with low pressure compressed air usually does the trick.
Clean the battery terminals, check the battery charge and clean behind the aircon control faceplate, then clear the error codes and see if anything resets.
Put a voltmeter between pin 14 (Battery +) and pin 19 (Ground) of the 20 pin diagnostic port and make sure that you have better than 12.5 volts at the port. You will need to check the Electrical Troubleshooting Manual for your car as BMW seem to have an aversion for using just one fuse when they can use half a dozen to control different functions but if the horn relay is interchangeable with the DME relay on your particular car, it may be worth swapping relays as the DME relay gets lots more use than the horn relay and can generate intermittent power faults when it is on the way out. The aircon thing only needs you to remove the faceplate from the dash, there is no point in blowing air on the back of the unit. Normally it is just a minute amount of dust that becomes slightly conductive as the result of exposure to atmospheric moisture which sets the fault code. If you are not bothered by the code, you can always just wait for a day with low humidity and let the moisture evaporate - you will probably find that then you can just clear the code and it won't reset until the weather turns damp again.
Hi David, a member here posted on my e46fanatics post to visit you here as you may have some insight. Please allow me to thank you for your time before we begin....I wasn't able to PM/email you so I thought I'd try here. I apologize as it is not really in regards to this thread
I have used my setup to successfully reset others airbags as well as coding and testing my vehicles. So let's start with this is not a configuration/set-up issue on INPA or DIS or anything else pulling codes
I have the SRS light illuminated. All connections have been checked and appear tight. Fuse 11 for Airbag and Side Airbag is good and seated well.
Running INPA and DIS I can see 10 stored fault codes, none of which are active codes. Both apps read the 10 codes the same and neither app is able to reset the light/module by erasing the codes. The error is something to the effect of : {error ecu rejected} instead of {ok}
Any ideas? Is my control module dead? I would't think so since I can read the codes but I am unsure and second guessing myself at this point.
Errors:
ECU MRS4 Part#6933238
10 Errors in memory!
240 Internal Error
Error Frequency 1
Error not currently present
Error not sporadic
240 Internal Error
Error Frequency 1
Error not sporadic
6 Ignition circuit zk5 / side airbag front right
Error Frequency 1
Resistance too large
Error not sporadic
1 Ignition circuit zk0 / airbag driver stage 1
Error Frequency 1
Error not sporadic
240 Internal Error
Error Frequency 1
Error not sporadic
240 Internal Error
Error Frequency 1
Error not sporadic
4 Ignition circuit zk3 / airbag passenger stage 1
Error Frequency 1
Error not sporadic
3 Ignition circuit zk2 / belt tensioner passenger
Error Frequency 1
Error not sporadic
240 Internal Error
Error Frequency 1
Error not sporadic
240 Internal Error
Error Frequency 1
Error not sporadic
Okay, I only have an Electrical Troubleshooting Manual for the early E46's but looking at it, both the driver's and passenger airbag side impact sensors and the seat belt switch are powered from Fuse 42. Since you are unable to clear the fault codes, this means that the fault still exists and since fuse 42 seems to be the common link, my bet is that either the fuse or the wiring link is damaged. When checking fuses a visual inspection is not good enough, pull the fuse and check it with a multimeter. My ETM also shows some power to the SRS module is supplied via Fuse 27 (you will find both fuses in the front power distribution box).
TIS also contains some service information about repairing damaged airbag wiring harnesses for certain models and it may be worth checking to see if your car is listed as a potentially affected model. Other than the above info, I need to know more about how and when the fault occurred but bear in mind that the SRS module is also only good for 3 crashes (i.e. 3 crashes where the airbags are deployed) after which the module must be replaced.
Thank you.
The car has no accidents, no airbag deployment, is garage kept with 60K miles. 330ci mfg 10/2003 (2k4Model) The harness' have never been disconnected or anything of the nature. All parts are original, including the module. The light simply appeared while driving for no apparent reason.
Intitial tests on 42 and 27 are they are good. Multimeter used.
When you say the error is still present, why would the codes read as not present/active? That is what has me thrown here. I figured the ecu would reject if code was still present, but the readout confuses me.
Hi guys
its been a while
its just because my baby runs so good, is this rarely that i have to use my Carsoft
but i had an issue with Carsoft not comunicating with the DME
but did with the other modules
so i removed and re installed Carsoft
its version 6.5.06
i just want to ask if this is the lattest and greatest?
or should i get a new upgrade
thanks to all
and i see good old David Mc is still "the man"
cheers brother
Fern.
Ego sum Abbas cucaniensis
et consiglium meum ist cum BIMMER PILOTS
Xanthoxx, my apologies that will teach me to read posts more thoroughly and also to refer to the correct wiring diagram info. WDS gives a good explanation of the SRS system functions for the E46 here http://wds.spaghetticoder.org/en/zin...-001651000.htm and this E46 SRS location.png shows the location of the module and related grey 50 pin connector under the centre console.
The usual caution applies when working on anything associated with the airbag system (i.e. DISCONNECT BATTERY FIRST) but it looks as though an internal fault may have developed within the airbag module. As you have already checked the fuses, the only avenue that I can suggest is disconnecting the battery for an hour (assuming that you have the radio security code) and then allowing the module to re-boot in the hope that the internal fault clears.
Bimmermig, Carsoft v6.5.06 was the last free version of Carsoft available. Later versions are genuine-only and are protected via a security dongle.
Hi David, thanks again
as usual your advise is the best and very much appreciated
Hello fellas
now that my Carsoft is working again
i have decided to investigate this weird snag that i have ever since try it for the first time (and ignored)
this is the thing:
Single diagnosis ZKE/ZVM - status error
ZKE 5
supplier: Siemens
part nr: 6 914 368
software nr: 20
hardware nr: 11
code index: 2
diagnosis index: 40
bus index: 12
production date: 19/02
zke4.dxt
7 Module not coded
61 fuse for passenger-compartment sensor
single diagnosis completed.
another one misterious
HKL diagnosis - status: ERROR - read the error memory
but there's no such a thing as HKL on Carsoft perform diagnosis nor erease error memory menus
my baby works fine everything works fine
so that's why i've decided to ignore those snags
but now, if somebody has seen this before and has some pointers
it will be great to see this
another question:
how do you convert PDB files (from the diagnosis files) into something we can use to post?
it takes a helluva lot of time to write each snag
cant find no PDB/TXT converter on google
thanks in advance
Fern
Unfortunately, didn't work. I left the battery disconnected 12 hrs. Apparently this issue is growing, here is another thread for it....
http://forums.bimmerforums.com/forum....php?t=1622709
Hi all,
After a bit of a struggle, I have managed to install Carsoft and it is up and running. I would like to hear from some other members who have a working copy of Carsoft running on Windows XP. Particularly, I would like to know the file size and time stamp of carsoft.exe file they are using in BMW folder.
The reason I am asking is that the first time I attempted to run Carsoft, it started all right doing Total Diagnostics, but then crashed after about a minute or so with an Application Error in carsoft.exe (exception breakpoint). So I then read somewhere about DJ Genius comments about improper renames and double-checked my renames, but they were correct. I was using Carsoft.exe that came from the Crack folder, file size 1256Kb and date and time 5/4/2007 at 1:17 AM. On a hunch, I reverse renamed so that I would be executing SP1 version, dated 6/7/2005 at 3:07 PM (v 6.5.06). And it worked, I was able to run total diagnostics and check out the errors it reported.
The bottom line of all this is that if the SP1 version works, even though it is about two years behind the Cracked version, what am I missing out on, if anything?
Thanks and any comments are welcome
The "cracked" version of Carsoft is the work of hackers. The SP1 upgrade is original Carsoft v6.5 upgrade software. I run v6.5.06 in Windows XP, which is 23.4mb (16.7mb on disk). Not sure about the relevance of the timestamp, which is set by your machine at the time of installation, but the original v6.5.05 Carsoft.exe file that I have is dated around 2007, which would be when the original Carsoft v6.5 beta version was pirated.
Xanthoxx, I have studied the WDS for your car. From the results you have posted and info re the MRS used in your car contained in the BMW WDS, the 240 error appears to be indicating that the airbag module has failed the self test several times, which I believe may be related to a current fault (this causes the warning lamp to remain on). I suggest that you check that Fuse 13 is in good condition and that connections to both the module and ignition switch are clean and firm. I have reset many airbag errors for E36's over the years without problems and as I indicated, if an error remains you will be unable to clear the fault codes. Since your diagnostic indicates that a number of faults have occurred but no longer exist, I tend to believe that the problem is current related. Also check ground connections at the battery, chassis and module.
Thanks David,
For the sake of discussion, I was under the impression that the cracked version was the preferred way to go since it supersedes SP1. By dates I meant the file Modified Date in Windows Explorer which in my case is the original date of the file from installation disk (or download and I have got both, which turned out to be identical). In any case it appears that you and I are running the same level of Carsoft and I am happy with that and that's good enough for me. Thanks again.
Adam, SP1 is just a service pack to fix some bugs in v6.5. It can be applied to either the cracked or genuine version of Carsoft v6.5.05.
I realize this is old news but you really don't have to jump through all the hoops mentioned above.
Do and uninstall of the program, go to C:\ or D:\ Program Files (depending on how you have your hard drive partitioned and configured. On mine I have the OS installed on C and Data on D.
Once into Program Files delete the Carsoft directory (folder)
Go back to the Root of C and locate the cm75f directory (folder) and delete it.
Go to <Start><Run> and type regedit
Under HKey Current User>Software> delete Carsoft
Reinstall Carsoft, this time if you don't have it run the BMWv65SP01 file when finished open the Crack folder and copy all the contents and paste them in the Program Files\Carsoft\BMW directory.
If you don't have extensions showing delete the carsoft file which is actually carsoft.exe and rename the Carsoft65BMW.exe to Carsoft.exe.
No need to restart the computer just run Carsoft from the BMW shortcut on your desktop and your good to go.
I have the same question about 4shared file because I get an invalid link error message when I try to go there?
