there is no end to the range of effectiveness of being able to alter the cam timing. Removing/disabling vanos narrows the powerband by cutting or removing total power from the system.
Michael McCoy TRM
85' Turbo M50 E30 | 95' M3 Nitrous, Coilovers, DJ Autos, UUC SSK
Edit: im not posting an IM as I don't want to risk a TO, but Techno550's real intention was to call out JT and Andreas about VANOS functionality. He decided to wimp out and be vague.
the posts Jon is referring to are:
The problem here is that there is no such ineffective range. Vanos is a tool to alter the LSA. being able to vary cam timing is a very valuable tool any time the used RPM range is a consideration. Even if the "power band" is only 2k - 3k rpm wide, you could still use VANOS effectively and have a great benefit from it.
Michael McCoy TRM
If my turbo reaches full boost at 5-5.5k and I redline at 7.5k, can vanos help me increase power in boost? reall question.
Michael McCoy TRM
996WHP 2.8 and going nowhere fast
. e36 4Dr with A/C and leather seats in U.S.
www.bmwturbo328.com 9.93@152.6
DVANOS helps your turbo spool sooner. All else is rhetoric.
.-=[ Kenny ]=-. See the BFc Drag Racing Standings List for BMW street cars. Watch my drag racing movies on YouTube. Some info on
BMW turbo street car Drag Racing 101
Michael McCoy TRM
If I can get my scanner working I can post the dynos.The only explanation I have is vanos increasing torque mid range made more air flow that in turn spooled turbo sooner.All this was done with a leaking intercooler so results could be diffrent now we will see soon
Yes it makes the turbo spool faster.
But who needs that for dragracing?
Euro S50 spools very large turbos quickly!
PT76GTS/GT4202 at around 4000 rpm full boost without vanos with correct adjust cams.
9.42@155mph
Spooling faster is spooling faster. would full boost sooner not be better?
Even when drag racing, you use a band that is probably 3k wide, and you could either use the vanos to spool the turbo before that, or use it to make two narrow peaks in that 3k rpm range. with dual vanos, you could do all of the above.
Michael McCoy TRM
My vanos does not even work on the track leave line 5200rpm's shift at 8000rpm's next gear catches at 5600-5800.Now on the street it comes into play alot.
I left the line at 7500 rpm on my 9.42 run.
9.42@155mph
WOW, i feel like im at home in this thread. Everyone kept riding my nuts about vanos this and vanos that. But the bottem line is i dont care about low end tq. the only thing that matters to me is 5500ish to redline when im drag racing. I have antilag that i can use to spool my turbo if needed. Id be extremely interested if there was a way i could adjust/lock my cam into place to ONLY gain top end.
1005whp/831wtq little bit of low boost pump gas magic...
license suspended
1995 E36 M3 (Sold)
FS: BRAND NEW SHOEI HELMET http://forums.bimmerforums.com/forum....php?t=1275204
That is frickin lame.
Just because people don't agree with Mike, and just because Mike is often lacking a bit in "tact" in his approach, he is typically making valid points for people to consider, if they wish to take the time to understand the points he is trying to make.
Some argue with him just to argue, which then brings on all of the drama, without any substance to the argument in most cases.
And once again this forum will be faced with the reality that the majority of people around here that actually KNOW something, and/or have real experience doing things themselves, will be gone, or afraid to post...
A sad state of affairs if you ask me.
And in case any of you are paying attention, Yes, I have made comments both past and present to back up some of the poeple on both sides of these arguments.
My viewpoint is that of an impartial observer, that has been around here for WAY too long...
Have you been Screwed?
Yes he knows what he is talking about and does make some very valid points and often is a big help in the FI section. BUT he is constantly shoving his information down peoples throats even after people have chosen their way around the project. It's great that he offers the help and advice but it only needs to be stated once, not 10 pages of the same sh*t regarding Dvanos.
He also seems to instigate anything Jon (5mall5nails) says just b/c of a grudge he has with Jon; he will often rant for 5 pages in a heated discussion which completely ruins the OP's thread. JMO
1995 E36 M3 (Sold)
I personally think a HIGH horsepower car can benefit from from a later spool. I the later the better for traction and drivetrain parts. Of course some wastegate tuning could make both pretty safe.
1990 A2 GTi 20V swap with a GT35R 350 + WHP on pump. 84 325e-M50 soon to be 50 trim
Why is his license suspended? Strange for a supporting vendor.
Anyway, dvanos may spool the turbo faster, but so would a shot of nitrous or a postive displacement blower. Shouldn't we all be using these as well, Mike?
If the builder/tuner does not want to or can not tune for the use of dvanos, then who cares. There are lots of tradeoffs made in a build, many of which sacrifice power for reliability or ease of use. I don't think there is anything sacred about dvanos.
If the builder/tuner doesn't want to run double vanos for whatever reason, then that's perfectly fine. But to state that running the cams locked in position will produce more area under the torque curve is completely false. I'm guessing that's what the problem really is. People love to state things as fact when they're not.
Case in point.....below is a dyno comparison of my turbo E46 330ci. The blue curve is with the cams in the stock positions, and the red curve is with them tweaked. It's clear as day that using the vanos and varying the camshaft angles are different RPMs gains power under the curve. I was able to pick up power throughout the entire RPM band by utilizing the VANOS functionality.
Nick Glantzis
2005 330i ZHP auto with Technique Tuning turbo kit (currently For Sale)
Can you say what rpms the vanos was used in that dyno? since the gains are across the entire board, its as though vanos came on at idle and turned off at redline.
