| 1987 - 1991 M3 (E30) (1987 - 1991) The E30 M3 was developed by BMW M division to be an upgrade from the E30 3 Series. Using a S14 four-cylinder powerplant (upgraded from the M10) the car was known to be quite powerful and nimble for its time. |
Thread Tools |
Interior light delay with auto dimming - ONLY $31.50 - 20% OFF!!!!
Pay now and lock in the low low price of $31.50. All you need to do is to paypal $31.50 to george.graves@gmail.com All units will ship on the 25th. This is a limited time offer. When I've sold enough I'll will be closing the $31.50 price and will sell them at the normal price for $39.50. ![]() http://www.digitalunderpants.com/dim/demo.mp4 (Youtube version here: http://www.youtube.com/watch?v=xjPSJVDmgaU) ![]() It works just like newer BMW’s, when you close your driver’s door, it keeps the the lights on, and then slowly fades out over a period of about 30-45 seconds. It has an added feature that when you turn the key, it dims down the light quicker, so that you can start driving. Anyone that had driven a newer BMW knows this feature. It adds a really cool lighting effect, and is very useful at times. Like when you need to read a map real quick. - Quality construction - PWM (pulse width modulation) design uses very little current, less then the stock relay - Custom printed circuit board. - Replaces stock relay - No cutting, no splicing - Installation only requires a Phillips head screw driver and a 8mm socket. - Free USPS priority shipping(USA only) - Bench tested to over 50,000 cycles with out failure, about 6+ years of normal use EDIT: Note that the delay featured is only triggered by the drivers side door - opening the passenger side door simply switches the light on and off, handy if you're like me, and always getting something out of the car. All the original functions of the interior lights remain. You can still manually switch them to the "always on" or "always off" position as well. ![]() Here is a look "under the hood" ![]() ![]() - remove the drivers side bottem dash cover to gain access to the hood relase cable bolts (8mm) and remove the bolts. - Remove the speaker panel and the speaker. - Remove the two screws that is just below the speaker opening and reach into the speaker cavity and pull the bracket out - Remove relay, and plug in the new dimmer mod. - button it back up and you are done. ![]() QUESTION: How do I check to see if I have the stock relay? ANSWER: Don’t worry, you don’t have to take anything apart. Simply open your drive’s door, kneel down, and slowly and gently push in the black pin in your door jam (it’s on the car not the door), you should see your interior light go out when you do. Now do it a few more times slowly, and listen for a clicking sound coming from about where the speaker is. If you hear a click, you have a relay and are good to go. QUESTION: "Does it require no extra modification for it to dim down quick when you turn the key or do we have to tap into the ignition switch?" ANSWER: No extra work, it is plug and play. remove the stock relay, and replace with this. ZERO cutting, ZERO splicing... QUESTION: Where exactly is the relay that it replaces? ANSWER: The stock relay is located below the speaker on the driver side foot well. Basically, you remove the kick panel, and then pull the speaker out, undo two screws holding the relay bracket and pull the bracket out from under the speaker cavity, replace the relay, and you are done. QUESTION: What happens if I don't have the stock relay, will this still work? ANSWER: Yes, you will need to splice two wires to make it work, when you paypal me request the non-stock relay version. ![]() BEFORE INSTALLING THIS PRODUCT YOU MUST AGREE TO THE FOLLOWING CONDITIONS: 1. YOU AGREE TO BE FULLY RESPONSIBLE FOR ANY MISTAKES, ERRORS, MATERIAL LOSS, PERSONAL DAMAGE, SECONDARY DAMAGES, CAUSED BY ANY CIRCUMSTANCES RELATING TO THE USE OF THIS PRODUCT. 2. YOU ACCEPT FULL LIABILITY FOR THE OPERATION AND USE OF THIS PRODUCT AND ANY VEHICLE HAS BEEN INSTALLED ON. THE ONUS IS ON YOU TO CAUTION OTHERS WHO MAY OPERATE THE ABOVE VECHILE. 3. AGREE TO COMPENSATE GEORGE GRAVES FOR ANY LOSSES DUE TO LEGAL ACTION BROUGHT AGAINST ME BY YOU AND OR ANY OTHERS WHO HAVE OPERATED YOUR VEHICLE FOR ANY REASON. 4. ALL DRAWINGS, PICTURES, DESIGNS, ARE COPY WRITTEN AND ARE THE INTELLECTUAL PROPERTY OF GEORGE GRAVES AND ARE NOT TO BE REPRODUCED. 5. NO WARRANTY OR GUARANTEES EXPRESS OR IMPLIED. Thanks you all, and I hope you enjoy! George Graves |
I made up a small batch for a few friends. I have one left over.
EBAY link: BMW E30 M3 325 318 interior light delay w/ auto dimming |
Interior light delay with auto dimming - ***$31.50***
I have 4 available. First come, first serve.
Shipping is USPS Priority mail - that's 2-3 days for most of the US. $31.50 + $4.60 Shipping = $36.10 PAYPAL: george.graves@gmail.com ![]() http://www.digitalunderpants.com/dim/demo.mp4 (Youtube version here: ) ![]() It works just like newer BMW’s, when you close your driver’s door, it keeps the the lights on, and then slowly fades out over a period of about 30-45 seconds. It has an added feature that when you turn the key, it dims down the light quicker, so that you can start driving. Anyone that had driven a newer BMW knows this feature. It adds a really cool lighting effect, and is very useful at times. Like when you need to read a map real quick. - Over 100 happy customers! - Quality construction - PWM (pulse width modulation) design uses very little current, less then the stock relay - Custom printed circuit board. - Replaces stock relay - No cutting, no splicing - Installation only requires a Phillips head screw driver and a 8mm socket. - Bench tested to over 50,000 cycles with out failure, about 6+ years of normal use ![]() Here is a look "under the hood" ![]() ![]() - remove the drivers side bottem dash cover to gain access to the hood relase cable bolts (8mm) and remove the bolts. - Remove the speaker panel and the speaker. - Remove the two screws that is just below the speaker opening and reach into the speaker cavity and pull the bracket out - Remove relay, and plug in the new dimmer mod. - button it back up and you are done. ![]() QUESTION: How do I check to see if I have the stock relay? ANSWER: Don’t worry, you don’t have to take anything apart. Simply open your drive’s door, kneel down, and slowly and gently push in the black pin in your door jam (it’s on the car not the door), you should see your interior light go out when you do. Now do it a few more times slowly, and listen for a clicking sound coming from about where the speaker is. If you hear a click, you have a relay and are good to go. QUESTION: "Does it require no extra modification for it to dim down quick when you turn the key or do we have to tap into the ignition switch?" ANSWER: No extra work, it is plug and play. remove the stock relay, and replace with this. ZERO cutting, ZERO splicing... QUESTION: Where exactly is the relay that it replaces? ANSWER: The stock relay is located below the speaker on the driver side foot well. Basically, you remove the kick panel, and then pull the speaker out, undo two screws holding the relay bracket and pull the bracket out from under the speaker cavity, replace the relay, and you are done. QUESTION: What happens if I don't have the stock relay, will this still work? ANSWER: Yes, you will need to splice two wires to make it work, when you paypal me request the non-stock relay version. ![]() BEFORE INSTALLING THIS PRODUCT YOU MUST AGREE TO THE FOLLOWING CONDITIONS: 1. YOU AGREE TO BE FULLY RESPONSIBLE FOR ANY MISTAKES, ERRORS, MATERIAL LOSS, PERSONAL DAMAGE, SECONDARY DAMAGES, CAUSED BY ANY CIRCUMSTANCES RELATING TO THE USE OF THIS PRODUCT. 2. YOU ACCEPT FULL LIABILITY FOR THE OPERATION AND USE OF THIS PRODUCT AND ANY VEHICLE HAS BEEN INSTALLED ON. THE ONUS IS ON YOU TO CAUTION OTHERS WHO MAY OPERATE THE ABOVE VECHILE. 3. AGREE TO COMPENSATE GEORGE GRAVES FOR ANY LOSSES DUE TO LEGAL ACTION BROUGHT AGAINST ME BY YOU AND OR ANY OTHERS WHO HAVE OPERATED YOUR VEHICLE FOR ANY REASON. 4. ALL DRAWINGS, PICTURES, DESIGNS, ARE COPY WRITTEN AND ARE THE INTELLECTUAL PROPERTY OF GEORGE GRAVES AND ARE NOT TO BE REPRODUCED. 5. NO WARRANTY OR GUARANTEES EXPRESS OR IMPLIED. Thanks you all, and I hope you enjoy! George Graves |
| Bookmarks |
| Thread Tools | |
