So i'm tired of traveling like 6 inches from gear to gear and want a short shifter kit but here's the thing:
I DEF under no circumstance want to exchange my gear knob
What are your suggestions?
Tis a 6speed BTW
I've been debating this myself... Similar but not quite the same situation. I think I'm going to end up going the understeer.com route and getting a E46 M3 shifter and a weighted linkage, possibly a weighted knob too.
I hear mixed reviews on the hi-po SSK kits, from "too notchy" to "too much effort to shift", both of which are cool when driving the snot out of the car but in traffic and parking, ugh, not for me. Plus OEM FTW.
Rules to live by:
- Fast, reliable, cheap. You can only have two.
- Do it right, or do it twice.
- BMW: Just because you can afford to buy one, that doesn't mean you can afford to own one.
1998 528i 5-speed sport - sandbeige with technical graphite trim - Jim Conforti Shark Injector - CDV delete - MY2000 M5 Xenon headlights - MY2000 M5 tails - PP M5 front bumper - E46 M3 paper filter - E60 545i shifter w/ E46 ZHP knob - 12" Alpine Type-R & 500w RF - CD53 w/ AUX input
go to your BMW dealer and ask for an '05 545 shifter, same as the Dinan m5 shifter 1 hour to install and about $60
I have it in my car, just perfect throws
I have an M5 shifter, 25-11-2-228-069. 25% shorter than stock, so it's sort of a conservative approach. Kind of a "not too short shifter".
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads/M5 SSK/RedLine MTL/M5 rear sway bar
BMWCCA Member #337964
I second that, go with e60 545i short shifter (part number # 25117546373)
http://www.m5board.com/vbulletin/sho...d.php?t=103511
I love my Rogue SSK w/WSSR.
oooo good idea.. My friend wants one i will tell him about this
any good ideas for 528i 5 speed.. i would like to stay away from the "too notchy" to "too much effort to shift" as well..
I have UUC in my car. 2nd-6th is fine but the 1st to 2nd shift sucks. But I had a B&M in my VR6 jetta, and that was horrible.
do you have balls of steel??? =) UCC short shifter is getting good reviews with theirs...
trivia: UCC stands for Underground Car Club and was originally formed by a bunch of guys who were secretly customizing parts behind their wives' backs! look how big they are now! =)
authorized distributors of:: carbon 8 :: mycarrauthorized seller of :: linea corse :: miro design :: dp engineering
please don't hesitate to contact me for your BMW needs!
AIM : eur0dyne || Yahoo : euro_dyne || MSN : eur0dyne
Email : sales@euro-dyne.com || Phone : (714) 901-5080
I just put in the B&M sport shift kit - it's great. I don't think it's the "full race" version which is louder and harder on the hands. This one is very crisp and definitely quickens the shifting and shortens the throws. Not that much more effort than the standard one, IMO.
-K
thanks.. considering i drive this car almost daily, i'm not looking to make a hassle out of shifting
ucc?? pretty sure its uuc..
635csi 5sp. tastefully modified, preparing for headwork, headers, new exhaust...
www.andrewtrahanphotography.com
AHHH wait i really like azaytsev idea but can i use my stock knob with it? how much does that cost? Can any 5speed fit into the 6speed one?
If you want to spend for a really good SSK, go w/ Rogue Octane SSK. The weighted rod makes a real difference. It cost about $285, but it is great. I was lucky and found mine for $100 from a friend.
If you are on a budget, go w/ the Budget SSK from understeer.com. $80, and it comes w/ pivot cup, washers, and clips. They even have instructions on their web site to make your own weighted selector rod (see Cheap WSR).
I have the Rogue, and a friend has the understeer. The Rouge is better, but $200 better? I think not.
chiefwej 2003 540i ///m-tech 6-speed Black Sapphire Metallic w/grayMods:plate delete, debadged, 35% tint,euro console, Evans NPG (zero pressure cooling system), CDV delete, Rogue Octane SSK, RP Symcromax
See: My REGISTRY PICTURES
The 545 sport shifter is less than $60 from crownauto. Also, your existing knob will work with it although you will probably want to go ahead and spend another $60 on a weighted ZHP knob off Ebay. They come with 6-speed indicators as well and look sharp. Look at asaytev's post - he has a pick of this mod with the ZHP knob on his M5. Very slick and low cost. Agreed - though - if you have the $$$ go for the Rogue SSK.
99 540i/6 - 18" Breyton Visions, LED tail lights, Hella Euro Angel Eyes, ATE Rotors, Hawk HPS Pads, K&N filter, CDV-delete, ZHP Weighted Shift. Making life in traffic a little easier...
First post here.....
I have a '98 540i Sport with the B&M shifter on it. I got talked into it by a shop here in DFW in order to fix my complaints about a sloppy shifter. Well it didn't work and I can't stand how notchy and loud the B&M shifter is.
I've talked with a stealership here and they told me that using a M-Coupe shifter would give me a short shifter that isn't notchy or noisy. I've read dozens of posts on this forum, but I haven't seen much on this. Is the M-Coupe shifter the same as an M3 shifter? Is this a good mod? The stealership recommended the M-Coupe over using the 545 shifter that many have had good success with, what do y'all think? Thanks in advance for your advice.
Go with the Rogue SSK! I f*cking love mine.
Steve
i just installed a m5 shifter today. it took all of 15 min and i absolutely love it. its not notchy and its not too short of a throw. by the way, it only cost me 30 bucks shipped on ebay. you should try it and if you dont like it then only 30 bucks lost..
#412153
I bought an oem one from an E46 M3. It's not too short. I weighted the rod with solder too.
"If everything seems under control, you're not going fast enough. - Mario Andretti"
I just got done installing the 545i short shifter. Shifts are really short but not to difficult. It's a little notchy but I didn't change to Royal Purple trans fluid yet. I'm hoping that after I change the transmission fluid it will feel the same as stock.
The only down side is that it is nowhere near centered. In fifth gear it's all the way up against the center console. Second gear is about where neutral use to be. I took some pictures but I can't post them, if anyone would like to post them for me send me an email.
