Results 1 to 23 of 23
Thread: VW mass air flow sensor on 540i
    Avondale,Az
    S50 E30,S52 TI,VFE E46 M
    I heard that a vw maf would work on a 5 series before. Does any one know the part number of vw maf that will work. The guy at the dealership said there is two different ones and I dont know which one to choose. Any help would be great.
    03 M3 AW/IR, VFE 570 with upgraded SI impeller (tuned by Evolve 477WHP), SS Headers, CPI Sec1, Scorpion Muffler, PSS9, ARC8's + CF goodies Instagram @kings5x
    Forum Fixer
    CDN 98 540iA M62 3.15
    Not sure about VW, but I heard the Land Rover one is cheaper than BMW too. Especially since the 4.4i is used on the Range Rover Part Number: B3130139283. Keep in mind this is for Post 98 540i only. If your signature is correct, 2000. It should fit.
    Here's another thread about it: Different part number though
    http://bimmerfest.com/forums/showthr...ight=rover+maf
    http://bimmerfest.com/forums/showthr...ghlight=vw+maf
    Dec 2005
    Bimmerforums
    2001 540iA
    I just ordered:
    1 x MAF 2.0/1.8T -->09/2000 (06A906461A) = $89.99CAD
    Sub-Total: $89.99CAD
    Zone Rates (Shipping to US : 4 lb(s)): $20.00CAD
    Total: $109.99CAD
    http://www.precisiontuning.ca
    Someone from the 'fest order w/ success.
    Avondale,Az
    540DELL you are awesome man and saved me a bunch of money as the dealer wanted to charge me $240,more money for next mods!
    Avondale,Az
    dvsgene-thanks for the threads,I'll always check bimmerfest too for more info and hopefully I'll find it at a cheap price at the Rover dealer
    Forum Fixer
    Quote Originally Posted by 54ODell View Post
    I just ordered:
    Total: $109.99CAD
    Is it still cheaper ordering from Canada with the weak US dollar and customs duty?
    North Dakota
    2000 528i, 97 Jeep Cherokee
    One brother in-law has a 98(or maybe it was 99?) Land Rover Discovery 4.0l, the other a 99 540. The sensing elements themselves, not the housing, have the same Bosch part number. I think the Land Rover sensor is purchasable without the housing. Even if it isn't, you can always swap the sensing element to the BMW housing. The Land Rover part was oodles cheaper, I think around $150. Just another option...
    I was wrong on the year, 99 Discovery II.
    North Dakota
    Looks to be Rover part number ERR7171. I'll try to get a hold of my brother in-law tomorrow for the Bosch part number.
    Valparaiso, In.
    2000 M5 & 2000 540i sport
    NO! The VW sensor itself does NOT have the same part number that the 540 or the M5 has for that matter and the 540 and the M5 use the same sensor. The number 06A906461A is the correct number sensor and tube assm you want to buy. Save your currency conversion decisions as you will save practically nothing. You can buy from US sources for $89 US as well. When you remove the sensor itself from the housings, you will notice your 540 has an 032 last 3 numbers and the VW sensor is 029. NOT a problem. The sensor will work, but it is NOT the same number. The VW sensor will run a tad (3-4%) richer than your OEM BMW sensor, but I don't think it is important as the O2 sensor should adjust quickly. I just wanted you not to be surprised when you actually have the guts side by side and the sensor numbers are not the same. You will neel a torx security bit to get the sensor out of the housing or a dremil tool where you can cut a slot and use a regular screwdriver. This info is courtesy of a UK forum friend who works at Bosch and knows what the hell he is talking about. Use the search fuction.
    Forum Fixer
    Quote Originally Posted by 540iman View Post
    NO! The VW sensor itself does NOT have the same part number that the 540 or the M5 has for that matter and the 540 and the M5 use the same sensor. The number 06A906461A is the correct number sensor and tube assm you want to by. Save your currency conversion decisions as you will save practically nothing. You can buy from US sources for $89 US as well. When you remove the sensor itself from the housings, you will notice your 540 has an 032 last 3 numbers and the VW sensor is 029. NOT a problem. The sensor will work, but it is NOT the same number. The VW sensor will run a tad (3-4%) richer than you OEM BMW sensor, but I don't think it is important as the O2 sensor should adjust quickly. I just wanted you not to be surprised when you actually have the guts side by side and the sensor numbers are not the same. You will neel a torx security bit to get the sensor out of the housing or a dremil drill where you can cut a slot and use a regular screwdriver. This info is courtesy of a UK forum friend who works at Bosch and knows what the hell he is talking about. Use the search fuction.
    As I understand, this option is only for post 98 cars. Will not work on 97 and 98 540is. Those of us with 97 or 98 have no options but the BMW route. Unless your friend at Bosch knows otherwise.
    Valparaiso, In.
    Unfortunately, I believe you are correct. A VW swap for pre-'99 cars has not been found yet...sorry.
    Massachusetts
    1987 BMW 535is
    I have a spare one for sale(70 bucks) if anyone needs it, PM me if you interested
    Nov 2007
    Tucson, AZ
    2001 BMW 540i M-Sport, 1990 VW Corrado G60
    Just ordered one of the VW MAF's from ECSTuning.com for 89.95 + 10.50 UPS ground shipping.
    Hopefully it goes well!
    2001 540i M-Sport
    Avondale,Az
    Konarider98 pm sent
    thanks everybody for the input but is there a hi-flow MAF that is sold by a tuner that would be more reliable and an improvement at the same time?
    Franklin, NC
    1999 540i/6
    I just installed the VW MAF sensors in my M5 and it runs great. I got them from Canada for $207 delivered. If I would have known of the place mentioned above, I would have purchased from USA.
    Sometimes its better to make a good run than a bad stand.
    Forum Fixer
    Quote Originally Posted by kingamr View Post
    Konarider98 pm sent
    There is a Hi Flow MAF from Dinan. Check Dinan's website.
    Dec 2004
    Mill Creek, WA
    98 740iL, 01 Suzuki TL10
    I just ordered:
    Total: $109.99CAD
    Thread revival!!
    How's that part number working out for you? I've got no issues, but figured I'd replace the MAF for the hell of it in my X5 4.4 and I'm still on the fence if I should go w/ the RR, VW or stick to the overpriced BMW version....all Bosch of course.
    650hp 10 X5///M5
    PERFORMANCE:JB4 w/ meth, stage 2 tune, wrapped downpipes, custom intake
    INTERIOR:AVIN 10.25" screen, Blackvue 550 dashcam, 7" tablet for JB4 logging
    EXTERIOR:Niche staggered 20's or AC Forged staggered 22's, H&R 2" suspension, LED AE, CF front splitter
    325hp 98 BMW 740iL6
    PERFORMANCE:///M5 6spd swap, iron sleeves, L/W Teflon coated & silicone impregnated pistons, Sealed Power rings, 3 angle valvejob, P&P head, perf cams, electric fan, CF intake tube w/aluminium heatshield/wrapped MAF tubing, Magnaflow 14816'd, Eaton M112 in-work
    INTERIOR:Android Dynavin, hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D monoblock, CF silver trim, 5% tint
    EXTERIOR:///MPar staggered 19's, H&R Stage 2/Bilstein HD, custom notched bumper, Shadowline trim, 750iL brakes w/ Axxis pads
    190hp 97 328ci
    PERFORMANCE:Single mass flywheel, ///M3 clutch
    EXTERIOR:Z4///M staggered 18's, rolled fenders, tinted markers
    May 2010
    USA
    08 535xit
    i just got a bosch MAF for the M62 from AutohausAZ for $130.
    for that price i did not see the reason to risk doing something other than correct MAF.
    G~
    nashville
    M3, 540I, M5
    I have an Extra one if anybody needs one.
    2006 e60 M5 Dinan S2
    2001 M5 Carbon Black Dinan Stage 3 - Sold
    2003 M-Tech 540i - sold
    1995 /// M3 Alpine White - sold
    Orange Co., NY
    64-BUICK; 95-E34; 00-E39
    is this any improvement over the one that came with the car?
    • 2000 BMW 540i/6 (Anthrazit Metallic 397)
    • 2001 Buick Park Avenue Ultra (Bronzemist Metallic)
    • 1964 Buick Wildcat (Sunburst Yellow / Arctic White)
    Fan Blades Can Explode.. Read My Thread
    Dec 2008
    Chicago
    some old BMWs
    why the huge discrepancy in price for the MAF sensor. I see it listed online from $60 to $400+?
    May 2005
    Meriden, CT
    '03 540i/6 M-tech
    For $130 I think I'll stick with the OEM maf.
    2001 330Cic/A in the same color combo is "Her" ride.
    North County San Diego
    Sometimes the price quote is for the MAF + the housing. That can be the reason for the big variance in price.
    Life's what you make it
