Seriously, how many threads do we need about people asking about offsets?
Use this link and leave us alone
http://www.1010tires.com/WheelOffsetCalculator.asp
Stock offset for Ms:
41 front (7.5" wide)
8 rear (9" wide)
Non-M:
Style 32: 17x7.5 et41 front, 17x8.5 et41 rear
Good information. Thanks for that.
Sticky!
I guess everyone knows this as well, but just for completeness, 5x120 bolt pattern on all the Z cars.
Yep, that's been a 5-bolt/lug BMW standard since the 1960's. Only the four bolt wheels are different. The hubcentricity of the wheels are the same too, EXCEPT for e39's. For some reason, some genius at BMW decided that the e39 needed a larger center hub boss. Goofy barst.
Here's a picture of my '72 CSi with 16x7 (offset 20mm) e39 Style 32 wheels with 225/50-16 AVS Sports on it. Fit like a charm.
The one thing that's different about the CSi is that it has lugs, not wheel bolts. I never needed the hubcentric adapter rings to use the e39 wheels on it, the nuts seem to pull the wheels on straight. While, on the e28, I always had to use the rings to avoid off center shakes. Then I learned about making the hubcentric adapter rings of of beer cans, but that's a digression.
Hey man what offset are the wheels on a Z3............ he he..... I kid I kid
BMW E36, the new Honda Civic of tuning.
The question is usually not 'what are the offsets', its usually, 'will these wheels fit'. Maybe it would be more useful to list the offsets of some wheels that press the bounds of what fit. Its hard to find wheels that fit the M's, so its more useful to list what works, not what is stock.
seriously sticky this so people stop asking
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
BF.c member 39,803
Before I forget, sticky might be nice for the offset calculator. Maybe put it in a single message titled "Wheel offset calculator", put the various standard offsets in the message body, then lock it.
I don't think Pat is wanting it made a sticky for his own use....
This should be sticky.
http://www.albinoblacksheep.com/flash/posting
Offset is relative to wheel width.
Maybe keep bumping this thread so it stays at the top? Noobs or people that don't post often seem to be the ones that miss these "No more questions about offset" threads.
random bump
What you need is a sticky thread with a title that's helpful ... like "wheel sizes that fit"
I like the unicorns.
'99 Z3 Coupe - Jet Black/Black (1-of-114)
'99 M Coupe - Estoril Blue/Black (1-of-82)
'03 540iT - Sterling Gray/Black (1-of-24)
'16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
Here's some more info and calculators. It's nice to know what sizes work, but to determine if [insert size here] will work, you'll more than likely have to take some measurements to find out.
http://exoticwheelsdirect.com/Boze_Alloys.html
http://www.skulte.com/adapterfaq.html
