I just wanted to post that I didn't fall off the face of the earth.
My car was running well with the exception of some fuel system issues related to the twin walbro 255 pumps. I have about 2000 miles on the new setup running 17psi on pump gas. I have been very busy at the shop and have had little to no time to work on my own cars.
A few weeks ago I tried to fix my fuel system woes. The dual walbros were sucking more gas then the return siphon could provide. I made several changes to the routing and design of the fuel system so that I could run below 1/2 tank and still have a fuel system to support 800+whp. I finally came up with a dual siphon system that seems to have eliminated all of my problems. I now have factory function with big power capability. I will be putting together a kit most likely consisting of a billet pump holder and custom lines/siphon system.
Last week I got all of the issues taken care of and made some slight changes in preparation for race gas/higher boost. I was driving the car last night and over-revved the car and bent some exhaust valves. Oh well, back to the shop she goes. I should have things taken care of this weekend. New parts are on order. I was really trying to get to the track a few times before the 10/8/07 track rental at MIR.
Back to work...
97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
16 M3 - 9.3@151 - Built motor/twins
15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
BMW SOB's turbo E30 - 8.72@158.39
follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
Mike just because I bent all my exhaust valves you did not have to go out and bend yours also to make me feel better...What a friend
996WHP 2.8 and going nowhere fast
. e36 4Dr with A/C and leather seats in U.S.
www.bmwturbo328.com 9.93@152.6
Wow...
M3 Sedan Club President #21
My car was running for like 30 minutes one time and I had the same problem. I don't feel like running out of fuel at half a tank. I would love to purchase this system once you have it ready for sale.
P.S. Can't wait to meet you at MIR!
fishforlife = new best friend
I'll be at the track no matter what. I'll drag race a moped if I have to.
so... did the syphon work out for you???
NWS would be nice... for us @ work guys
wtf is with the NWS pics... I mean she's hot and all, but damn, right in the middle of a thread
I love this forum! Great cars, hot chicks, broken drive shafts, blown o-rings, and bent exhaust valves all in one!
___________________
Paul E
'11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
http://s11.photobucket.com/albums/a173/boostm3/
Mike any update on the E46 project?
Steve
That's interesting about the dual walbros. I just finished a dual walbro pump hanger for my E30 fuel tank and didn't think about keeping fuel in the pickup bowl once the level drops below the top of the bowl. There is the siphon/return line that picks up fuel from the driver side half of the tank and pours into the bowl the pump/s sit in on the passenger side, but it sounds like you are draining the pickup bowl faster than the siphon/return line can fill it up, once you are below half tank.
I know Andreas ran (is still running?) dual intank walbros in his S38 E30 M3 but I don't know if he did anything special to keep more fuel in the pickup bowl.
I'm currently not doing anything special. I had considered trying to remake and replace the stock return/siphon line with a larger diameter tube, but figured it would require cutting the top of the tank off to get at it. Welding that back together could get interesting.
Any chance your fix might work for an E30 tank?
You still planning on an aem ems release?
stock is the new mod
When is Cardcounter going to MIR ?
Anyone on a low horsepower/torque turbo car seeing these problems at cold temperatures with a high flow fuel pump?
Current: 95 M3 Turbo | 08 335i
2011 M3 Coupe - Individual Fire Orange/Black Novillo Extended Leather, 6MT, Mode Carbon, Eisenmann Race, BBS CH-R, BC Coil-overs (Sold)
1995 M3 Coupe - Avus/Hurricane, AEM EMS, Precision Turbo, Boostlogic, H&R, Fikse FM/5, MaxVelocity, Maximum PSI, 20% Tint, etc etc.. (Sold)
2009 M3 Coupe - AW/Fox Red, 6MT, Carbon Roof, Shadow Trim, etc (Sold)
cant wait to see how it turns out
M52 Power! 500whp?, ? ft/lbs
Mods:8.5:1 CP pistons, Eagle rods, S52 cams, M50 intake manifold, Eurosport High Performance underdrive pullies, 3.23 lsd, ZKW's w. DDE, BBS RC's 18x8.5, Bilstein sport shocks, H&R sport springs, Eibach sway bars, BMW Motorsports x-brace, pwr 57mm rad, stewart high performance water pump, 6000k prolumen hid's, m tech kit
custom turbo: sias tuning tec3, t67 ho, spa turbo manifold, 24x12x3 ebay intercooler, 750 cc low impedence injectors, arp head studs, walbro 255 fuel pump, aeromotive fuel pressure regulator, hks ezII evc, tial 50mm bov, tial 40mm wastegate, plx m250 wideband o2, cartech motor mount, turbowerx oil scavenge pump, spa gauges
