Results 1 to 9 of 9
Thread: Testing for a faulty lifter?
    Jan 2002
    Atlanta, GA
    2011 CC 2.0t, 98 M3
    I've run into a slight situation with my car. Since swapping the headgasket/installing M50 I'm now experiencing a 'ticking' sound. The sound appears to match the tick coming from the Fuel injectors, but I can't be 100% sure. I'm a little worried that when I sent out my head to be resurfaced, the machine shop may have swapped the location of the lifters.
    Is there a way to test them to find which one is faulty? What is the worst case scenario if the vehicle is driven with the 'tick' and it is lifter noise?
    Marco has helped me TREMENDOUSLY through my whole process. Just looking for others who may have experienced this...
    __________
    98 M3
    2008 G35S
    GGray's Avatar
    GGray is offline Did someone say racetrack BMW CCA Member
    Aug 2003
    Christiansburg,Va.
    A few BMW's...
    Lifter tick
    The location doesn't matter to much.
    Have you driven the car or just let it idle?
    If you drive them most of the time the lifter tick goes away. My S50 had horrid lifter tick...Only real way to stop it is replace the lifters with updated ones.
    Gary Gray
    If you can take it apart you can make it faster!
    Jun 2006
    Baton Rouge, LA
    '90 329is 2.9L M50,
    Or, if you take the head off, you can replace the oil pressure check valve that holds oil pressure for the lifters.
    1990 BMW 329is 2 Door Alpineweiss II
    Fully built 2.9L Stroked M50
    My 2.9L M50 Build
    Jan 2002
    Atlanta, GA
    2011 CC 2.0t, 98 M3
    Quote Originally Posted by jone30 View Post
    I think you may be on to something here...Would a machine shop need to remove this check valve? When I pulled the head, I made sure that it was still there. I can't for sure remember if it was there when I put it back on ( HAve a few pics I ned to review tonight of when I got the head back!). Have you experienced this check valve going bad?
    I have driven the car and it does drive like normal after I resolved a slight timing issue. Assuming that the check valve is there and intact, and that it is lifter noise, is my only option to replace all 24?
    Thanks guys..
    __________
    98 M3
    2008 G35S
    Naperville,IL
    600cc of pure fury
    there is a lifter bleeding procedure which involves holding the revs at like 3-3.5krpm
    Jan 2002
    Atlanta, GA
    2011 CC 2.0t, 98 M3
    Do tell! 3 - 3.5 rpm, then what? This 'ticking' is driving me bonkers!!
    Quote Originally Posted by bmwperson View Post
    __________
    98 M3
    2008 G35S
    Jan 2002
    Atlanta, GA
    2011 CC 2.0t, 98 M3
    I think I found my answer.. I love this forum!
    http://forums.bimmerforums.com/forum...16&postcount=7
    __________
    98 M3
    2008 G35S
    Jun 2006
    New York
    1996 Ferrari F355 Spider
    Great information! It's great to know, thank you for posting that link!
    Sep 2002
    USA
    BMWs
    PN?
    11121735180 got it
