Ever since I started pulling parts out of the M3 I have kept a component weight log. Other Items I still beed to weigh. Heres what Ive got so far:
Vader 1 63.00
Vader 2 63.00
Radio 3.00
CD 5.00
ASC Throttle Body 5.00
Fog Lt 10.00
Rear Spkrs 10.00
Fr. Spkrs 3.08
Fr. Speaker Ins. 0.24
Rear Speaker Grilles 0.48
Amp 5.00
Sound Ins. - Dash 4.00
Sound Ins. - Btm Rr Seat 2.00
Sound Ins. Rr sides 5.00
Sound Ins. - Rr Wheel Wells 3.00
Sound Ins. - Fold Down Trunk Access 1.00
Sound Ins. - Hood 1.00
Tool Kit 5.00
Trunk Trim 3.00
Steering Wheel 10.00
Jack 3.00
Right Fold Down Seat 16.54
Left Fold Down Seat 15.44
Seat Bench 12.13
Rear Small Vertical Carpet 4.41
Rear Seat Bolster - L 2.03
Rear Seat Bolster - R 2.21
Right Side Trim 2.21
Left Side Trim 2.21
Upper Plastic Trim 0.55
Rear Deck Cover 3.31
Rear Deck Insulation 5.51
Right Door Panel 7.72
Left Door Panel 7.72
Fuel & Batt Cable Cover 1.10
Rear Trunk Panel 1.00
Bottom Left Trunk Panel 1.50
Bottom RightTrunk Panel 0.50
Trunk Carpet 8.00
Trunk Lid Carpet 0.50
Spare - DSII 17x7.5 20.70
Mich Pilot Sport 22.00
Tar 34.00
Carpet 39.00
Flywheel 16.00
Hood catch (passenger side) - .30
Hood Latches - .93
Heater Valve - 1.09
A/C Tensioner - 1.57
A/C Compresor Bracket - 3.5
A/C Compressor 14.00
A/C Condensor 7
A/C Dryer 2.21
Firewall A/C Connector 0.55
Condensor / Compressor Line 1.10
Condensor / Compressor Line 2 0.53
Compressor / Firewall 1.40
Heater Box 19.00
Aux Fan 8.00
Pass. Airbag 7.00
Visors 1.32
A Pillar Panels 0.80
C Pillar Panels 1.38
Rear Driver Side Elec. Floor Cover 0.43
Front floor Electrical Covers 0.68
Rear Pass. Side Floor Electrical Cover 0.41
Driver Side Rear Floor Vent Duct 0.75
Pass. Side Rear Floor Vebt Duct 0.69
Glove Box Vent Tubes 0.69
Driver Side Vent Tubes 0.65
Driver Side Foot Vent 0.25
Pass. Side Foot Vent 0.32
Knee Bolster 3.00
Glove Box / Vent Assy. 4.00
Glove Box / Airbag Frame 4.00
Driver Side Speaker Trim / Dead Pedal 0.94
Pass Side Speaker Panel 0.47
Lower Seatbelt Guides 1.12
Stereo Wiring 5.00
HVAC Wiring 0.67
Lower Door Trim 0.82
Driver side under dash panel 1.13
Pass. Side underdash panel 1.06
Radio Antena / Defrost Stuff 0.35
Shifter Console 1.4
Dash (For referemce only. My car will retain dashboard) 10.4
Seatbelt Retractors 3.96
Shift Boot 0.13
E Brake Boot 0.17
HVAC Control 0.69
Washer Reservoir 1.19
Washer hose 0.23
11 Button OBC 0.62
E-Brake Console 1.78
Sunglass Console 0.50
Keyless Entry Module 0.63
Airbag Sensor 0.57
Map Light 0.36
Driver Side Coin Pocket 0.14
Gas Door Lock Actuator 0.24
Rear View Mirror 0.96
Windshield Defrost Vent Covers 0.26
Pass. Side Dash End Trim 0.28
Knee Bolster Trim Cover 0.98
Misc. Wiring: Glove box, cd player power, cabin lights 0.92
Headliner 3.93
ASC Actuator .75
Cruise Control Actuator 1.81
Secondary Air Pump 3.88
US Headlight 3.43 (will use these to replace ZKW's, which Im sure weight more)
Engine Side Rubber ECU Cover 1.19
Hood Release Lever/Cable/Housing - .48
Horn & Bracket - .65
ZKW (Swaped Euros for US Spec) - 6.37
Fan shroud and expansion tank - 3.17 lbs.
Stock Behr radiator - 9.77 lbs
Door window seal: inside - .375lbs.
S/M 52 intake manifold - 6.1
Driver Side Window - 10.26
Window Track / Rollers - .97
Window Crank Mech, incl. window motor - 5.5
Driver Side Power Lock Actuator - .63
Shoulder Belt Height Adjuster - .71
Shift lever rubber boot - .31
Stock Shift Lever with Momo competition knob - 1.146
Radio Hi/Fi switch - .033
ASC Switch - .044
Heated Seat Switch - .044
Door Lock Switch - .022
Wow, 415 lbs out. How much did you have to put back in (seats, roll bar, etc)?
Nice list. What are you weighing things with?
I weighed the steel E36 trunk lid at 31.5 pounds a couple of weeks ago. Yikes!
What's the race weight of the car as it sits now?
edit: Do you still race on stock wheels??? There's lots of weight to be removed yet. LTW5 17x9 = 16.6 pounds.... PM me.
heck, the 18.7 pound 18x10s are lighter than the stockers. And they are b-b-b-bigger!
Terry Fair @ Vorshlag Motorsports
With Cobra Seats, sideplates, vac mounts, rollbar, CF LTW wing, splitter, momo wheel, LTB Qr Ive added back about 135-145lbs.
Fair: I use a warehouse pallet scale or a UPS shipping scale.
At the last corner balance with 3/4 tank of fuel, Cobra seats, Kirk Rollbar and full interior, no radio, rear speakers, stock radio amp, side trunk carpet, no asc throttle body the car weighed in at 3090lbs.
My track wheels are 17x8 BBS RX with 235/40R15 RA-1. I will be looking to get a new primary wheel set and make the BBS the rain set.
cool list. good work. documenting that stuff is a pita that most don't do, but it's helpful.
FMJ Motorsports
"not everyone is a princess like riley"
[16:04] spg383: my vagina gets cold below 40
Funny, my '95 M3 (with 3/4+ fuel load) with me in it weighs 3094lbs. 2915lbs without my a$$ in the seat.
Racetech seats, Safety Devices roll bar, 5 pt harnesses replaced 3 pt. OE. Full interior forward of the rear seats (including side panels in the rear and rear parcel shelf, just no rear seat and no junk in the trunk). My car has a 5-disc changer, amp and all speakers still in place.
But I've done a few other weight savings measures too. Many of the same items you've listed plus I removed the A/C system and electric fan, cruise control among other things. The pass. side airbag is pretty heavy (15lbs-ish) and gone from my car too.
The factory airbox is heavy too.
Nice job detailing all the part/piece weights. I'll keep this list. I was too lazy to weigh each piece. I figured I'd take the part weights from the ETK if I ever needed to know.
Nice list. I'm under 2900 now... not sure of the exact # since I've removed more stuff since my last corner weighting. I also have the A/C out... I wanted to tackle the heater stuff next... I saw a plate for sale that is used to plug the hole in the firewall... thinking of having one fab instead as IIRC it was around $200
FMJ Motorsports
If you were really into it you could not only measure the weights, but their location in relation to car's center (or CG if you knew it) as well to see how the weight distribution and CG location changes.
-Peter
Current toy: none
Past cars: 88 M3, 99 M3 x2, 04 M3, 91 NSX, 06 S2000, 01 911TT, 06 Exige, 00 NSX, 04 GT3
Nice job Mario, are going to the Boston event at WG?
anyone know how much the heater core weighs? What about stock hood?
Matt Williams -
Current - 01 LSB M3
Past - #21 GTS-3 -
95 Alpine White/Yellow M3 - Stock, except for the stuff that isn't
Someone mentioned the heater core is around 15 lbs. Personally, I thought it was more. But, I never weighed mine.
The hood...depends if it's original or replacement. My original hood weighed around 47 lbs. My certifit replacement hood weighs 42 lbs. However, I plan to skin it this weekend. I'm hoping to get it down to around 22 lbs. That's still heavy but an improvement nonetheless.
Passenger side airbag is 6 lbs, 13 oz on my postal scale.
Anyone know the weight of the headliner and separately, the sunroof removable parts?
I was including the front catch on both sides, shocks and hinges. But, I should've clarified that my weights were measured on a bathroom scale. Definitely not the most accurate way of measuring. LOL
But, it's for certain that the certifit hood and fenders were much ligher than the stock parts.
Great list! I just stripped out the interior this past weekend and it's nice to have an idea how much weight actually came out.
Thanks!
John
Hey Tony, I bought your old SS Race. I don't think there is any baffelling left, it just keeps getting louder and louder.
When my E46 goes back I am going to be following the same route as you, makes more sense then messing with the E46.
Tucker
speaking of weight savings....... Erebuni is going out of business and doing $125 for any CF/fiberglass hood!!
http://www.erebunicorp.com/2dayhood.htm
Element Tuning - 2008/2009 NJMP Redline Time Attack/Formula X Champions [Street & Modified]
RightFootDown
FS: E36 OEM fogs | UUC Chromoly RLCA's
Tony, I think the age and track time have helped to remove the baffelling. I like the way it sounds, at 7K it screams, I don't even need to look at the tach anymore. I get positive comments from guys at the track all the time.
Good Luck with your projects.
Tucker
Good to see all that weight coming out! Sometimes I forget how heavy E36's are. ; ) As a legal JS car mine weighed 2740 with ~3/8 tank of fuel. Since then I've gotten the car down to 2500 with ~1/4+ of fuel. And I have put no money into weight, this is only removal.
From a some calculations I've got going on my list I've another 210lbs to come out yet and that's not really working hard to get stuff out. It's at the point now where it's a bit more than just unbolt and discard but not much futher. Granted, there are 2 or 3 ltw body parts in there but it's almost a must, the weigh/$ is quite good...so much that it's worth the money. Those bits are a little over 40lbs of that.
Now over the winter when I get the new cage I'll probably add back in 75lbs but that's fine. The improvement in chassis stiffness and suspension efficiency will be wellllll worth it. The cage now is a pretty basic 6pt welded cage. I will likely do tower to tower since I'm switcing to coil overs in the rear.
So if I can drop the 15-20lbs I've put on myself as ballast that would be nice too. I should have to add about 75-85lbs of ballast to be where I need to be...and I'll have to run a bit heavier on fuel. I have to be careful about how much HP I add though so I don't get stuck in GTS3 without the power to even have a chance.
I gotta say though, removing weight is awesome!
Damn, I just thought of another 15lbs that I hadn't originally thought of. It's getting really tight now....
