I need to take the leather back and bottom off the seat frame. I also need to remove the rear seat back. It looks as if the front bottom is held in with 4 plastic push pins, but it is hard to tell if that is all. I have tried to search for a howto but no luck. Any info would be great!
Front seats: 4 16mm bolts.
Rear bench just pulls out. So does the rear backrest. Just make sure you remove the rear headrests first.
don't know what you call a search but "seat removal " will provide help. Actually MParallel is again the answer guy. Thanks M
Slightly different but anyone removed the leather covering from the front seat base (need to change an airbag seat occupancy sensor)? How hard is it - is it clipped on or glued??
Euro ///M3 Evolution Individual vert, 321bhp
18" CSL's, P'flex RTAB, ARB's, wishbones, CDV delete, DaveF Induction, Eibach Coilovers, EBC Yellowstuff pads, Supersprint, Gen 6 Angels & HID lights, Royal Purple throughout.
Evoman, that is great color 3...
I know I need to remove the headrests to remove rear back panel, but having trouble removing them. Any suggestions?
Brad
Lots has been written about this in the convertible forum. A quick search will give at least half a dozen threads on people's tips and tricks for removing the head rests.
Maybe there should be something about that in the sticky if there isn't already.
In my 97 318ti I am taking out the back seats. I have removed the bottom and unbolted the seat belts. When I fold the back part of the seats down there is the hooks, but it is covered with a piece of plastic. There is a special kind of screw. Does anyone know what kinda of tool I need to get to undo the screw and then how to go from there
The front bottom is held in with 4 push things nicknamed 'xmas trees'. get new ones from dealer for like 80 cents ea, you will break em. I did.
If your seat is like mine, there are 4 torx bolts holding on the seat back.
You pop the bottom piece off, then under a flap attached to the top leather you will see two tork. Then when you take the headrest off (pull hard) under that plastic piece there are two more torx.
Heres a pic of how mine looked with the top leather out too...
oh, btw the vinyl on the back of the seat is really glued onto the shell well. I just painted mine.
1994 325iC for 19 years, upgraded to 2011 335i Turbo with Sport package
