It's been about three weeks since I've had the Ring Wraith back
(or had him at all, since I never drove the car, let alone an E36 M3,
before the compressor was installed.)
Decent numbers for 95 3.0L, I believe.
I'm content (for now.)
6-6.5 LBS of boost at WOT, across the board.
As ///M3///M5 had some issues w/ headers and 264/256 cams
I started and finished my set-up
before his warnings of AFR problems.
Mine has a slight lean issue between light and medium throttle
but has been solved for the time being.
The bug has struck however,
and its only a matter of time until I take a ride
to Eat a 76mm, 42lb Peach in GA...
(unless there is another financially, yet potent, comparable option in the near future.)
Originally 335whp/285wtq
After 76mm pulley addition, upgraded injectors, pulling Schrick intake cam
and TRM Gandalf tune
390whp/340wtq
Patience young Padawan...
Peaches ARE nice however...
Nice numbers and I hope you eventually correct your lean condition.
97 ///M3 Turbo Saloon
VEHICLE: TRM Tuning Turbo System | Built Engine | SwainTech coatings | Custom 3.5" exhaust | Cryo Treated 210mm 3.15 Diff w/40% lock-up | 420G 6-speed transmission | UUC Twin Disc clutch | AMS-500 | AST Suspension | AP Racing | Racelogic TC | Dr. Vanos | Riot Racing BBTB | Vorshlag | UUC | AA | JT Design | Recaro | SPA Technique | VDO | Raid | Turner | Castillo Design FXR Retrofits | Zionsville Autosport | Stewart Components | Motion Motorsport underpanel | Z3 steering rack retrofit | Billet throttle body bushings
SOUND: Pioneer DEX-P99RS | Dynaudio | Morel | Image Dynamics | Arc Audio | JL Audio | Audio Control
OTHER: AEM Wideband Failsafe gauge | Ecliptech | Escort 9500Ci | LI | Hüper Optik | Llumar Air Blue | Skene Design
PHOTOS: Engine Bay: Click
More pictures!!
I love how clean these twinscrew kits look.
Very nice numbers! Love the looks of that engine.
2009 BMW 335i
Nice numbers! That thing must sound mean with those euro headers and cams!
JMC
Motor: Hurtig/AA custom 2.0l TS OBD2 AA tuned 444whp/384wtq SAE 470whp/400wtq STD
Exhaust RMS headers, Maximum PSI custom exhaust, magnaflow mufflers
Driveline E46 M3 6 SPEED, 2.93 LSD, Rouge SSK/tranny mounts, UUC Ultrasmooth /LTW steel flywheel. CDV delete, UUC clutch pedal bushings with GSP pedal
COOLING: Stewart WP, 78* thermostat, S54 radiator, Euro/S54 oil cooler, ES TS oil cooler adapter, M3 power steering cooler
HANDLING: MR M CAR SF reinforcement, TCK D/A CO 450/500, TCK Camber Plates, Rogue RSM, Ireland SFB, Dinan STB. CCW classics, polished lip, brushed centers. P295/30/18 P245/35/18.
THE SHOW: Stygar Z8 Nozzels, Leather Z armrest, Z8 push button start, chrome door handles, OEM FOGS, BMW Traffic Pro.
Monitoring: PLX Wideband, VDO vision boost/VAC both with custom chrome trim ring.
COMING SOON: custom intake
I could eat a peach for hours...
98 sliver M3 coupe
TT stage II w/GT35R
nice pull and some damn sexy pictures
'99 Hellrot M3 vert; Eurosport twin-screw SC w/ 76mm pulley + Schrick cam (i.e., TRM Stage 2 TS), UDP's,
oil cooler; GC coilovers; Z3 steering rack; Euro 6-spd trans; Diffsonline 3.46 LSD
simply beautiful! can't wait to hear it with those headers.
Why is there a full point AFR difference between the 2nd and the 5th runs posted?
but has been solved for the time being<<
Isnt light to medium throttle still under control of the closed loop system on your car? If so, then afrs are being forced to stoichio, so how did you determine that you were lean here? Had you disabled closed loop running so that you could measure native afrs without the intervention of the feedback loop?
___________________
Paul E
'11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
http://s11.photobucket.com/albums/a173/boostm3/
run 2 was before the forced richening
thru the use of an FMU.
Pulling the Schrick intake cam out
was not really an option at the time
as my stock intake cam has a
decent amount of material missing from the very rear lobe.
The lean was determined earlier thru light pulls.
"Had you disabled closed loop running so that you could measure native afrs without the intervention of the feedback loop?"
Is this a suggestion??
should have had to?
Unless I'm mistaken, you and I have the same engine. The Eurosport supercharger is on my short dream list of mods.
I thought that it would take the S52 to 416hp. Why the discrecpancy?
Those pictures are gorgeous, I'm drooling!
'99 M coupe
Autosolutions Short Shifter
Momo Pedal set
ECIS CAI
Dinan stage 3 Software
Dinan Wide Throttle Body
BillyBoat Tri-Flo Exhaust
BBS RS-GT 18X8.5F 18X9.5R
TC Kline True Match Suspension
Valentine One
Dreaming About Eurosport TwinScrew 416hp!
awesome!!! congrats on the results.
-M3J0N
maybe it was Gollum
a small issue.
things'll get better,
much better
I saw '99 M3 and figured S52.
'99 M coupe
Momo Pedal set
ECIS CAI
Valentine One
1995
My mistake reading too many posts at once trying to get 100 so I can post some pictures.
So you have the S50 with 240hp stock.
Interesting, the S52 has 240hp stock also.
'99 M coupe
Momo Pedal set
ECIS CAI
Valentine One
