Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1996 - 2003 (E39) > E39 Common Problems and DIY Fixes
E39 Common Problems and DIY Fixes E39 DIY Instructions - Documents instructions on how to take certain tasks. Pictures are normally included.
Old 05-13-2007, 03:48 AM
SleekBMW's Avatar
SleekBMW SleekBMW is offline
It's a BMW
Cars: 2002 BMW 530i Sport
Auxiliary Fan write up
MODS PLEASE STICKY
Thanks to E39Dream for helping me when i did it and being patient to answer my questions.
DISCLAIMER:
I am not responsible for any damages to your car upon using this or any other DIY write up. You assume all responsibility for damages or improper installation to your car.
Hello,
Here is a write up for a E39 Aux fan change. This was done on a 1999 528I and may differ slightly for your car.(resistors)
Job difficulty
2.5 wrenches out of 5.
Tools Needed
-1/4' ratchet
-3/8' ratchet
-8mm socket
-10mm socket
-13mm socket
-Needle nose pliers
-T45 torx bit
-8' extension
Parts Needed
- Auxiliary fan assembly - see No. 5 in link below
http://realoem.com/bmw/showparts.do?...32&hg=64&fg=55
-Resistor No. 08 on link above.
- 50 amp fuse
- various fuses.
- Rivets Nos. 22 and 31 ten of each
http://www.realoem.com/bmw/showparts...53&hg=51&fg=15
before ANYTHING.
Turn your ac on after your car has been operating for a while and is HOT
60 degrees and wait, if fan turns your aux fan is fine, if not you have a problem.
I have been told it can be your aux fan assembly itself, blow fuse, OR coolant temp sensor, or failed relay (ive been told this is very rare.)
FIRST THING, check the fuses in your glove compartment,
Fuses in glove compartment guide
This is a pic of fuse 75 and 76 lookin lying down above into your glove compartment from the passenger side foot well. That panel needs to be pulled BACK towards the passenger side seat with SLIGHT pressure to the floor and should come out. THE AREA THAT 75 and 76 are in is circled. you will reach in there, and grab the fuse and push UP towards the sky and it will come out.
Preparation
park your car on a flat leveled surface or your driveway.
put a blanket or sheet infront of your bumper, and set weights down so it doesnt fly away, i used my tool box.
here we go!
1-
Use the 8mm bolt to remove the 4 bolts that hold the headlight. Make sure you remove the bulbs from the housing of the headlamp.
there are 4 screws 2 on top and 2 on bottom.
2-
Remove 3 bolts from your wheel well, 1 above and 2 on bottom. refer below
Top bolt
Bottom bolt-the second one is just left to that, it may help to turn your tires side to side.
3-
Go and lie down on the sheet you just put in front of your front bumper.
You will look above the grills in your bumper and see little buttons, these are the plastic rivets. MAKE SURE YOU BUY EXTRA ONES FROM THE DEALER. 10 OF EACH TO BE ON THE SAFE SIDE IS WHAT I DID.
use the needle nose pliers and pull away the center pin, and pull out the rest of the rivet. there are about 4 rivets on each grill, pull them all out and pull away the grill.
4-
You will now see T45 torx bolt on the left of your license plate, and the right, the grill covered this area. Heres a pic
find both and unscrew using the T45 bit.
5-
Disconnect fog lights from the back
You should now be able to remove the bumper, MINE however was unremovable. so i had to remove the bumper shock absorber
pictured below
This isnt necessary to remove it, but if your having a tough time getting the bumper off, it helps.
after you have done 1-5.
have a friend support the bumper while you go to each side and SLIDE out the bumper from its track, it sits in a sliding track.
6-
This is what your car should look like now.
7-
Use a 10mm bolt and remove 3 bolts that hold this air snorkel.
the next one is to the right UNDER the snorkel.
last one is all the way to the right. cant miss it.
8-
Use the same method that you used for the grill on these plastic rivets
Remove ALL 3
9-
This rivet holds the power supply to the Fan, disconnect the wire this wire from the fan assembly
This is another rivet that i broke, but my dealer gave me a plastic zip tie and said this is better
10-
Remove 4 fan bolts, these are the 13mm bolts. there are 4. do the same on the opposite sides
also remove the kidney shroud which you removed the 3 rivets from. BE VERY DELICATE WITH THE SHROUD it breaks easily.
Front right
front right bottom
11-
Gently remove the fan frame assembly. MAKE SURE YOU SEE EVERY LITTLE POINT IN TAKING IT OFF, THE NEXT ONE NEEDS TO BE MOUNTED ON EXACTLY THE SAME OR IT WONT WORK.
Once removed, clean all the crap.
(if you have a resistor now is the time to replace it use diagram to locate resistor, if its not there you dont have one.
http://realoem.com/bmw/showparts.do?...32&hg=64&fg=55 number 8)
Hook up the fan, let the car run for a bit and see if the aux fan is working, there is no guarantee it will work, because the engine needs to be at a certain temp.
Put everything back together again.
Go to Autozone, buy R134a with a guage, turn ac on at 60 and fill the AC to the BLUE level of the guage.
If after ALL of this your aux fan is not working, it could be the coolant temp sensor pictured below
Buy soda, drink, and look at the progress youve made. and now
Congratulations your Auxilary fan is now working. its better than paying 900 at the dealer right!
Cost
Aux fan assembly 297
50 amp fuse 2 dollars.
rivets about 3-5 dollars.
coolant temp sensor 22
resistors 60
soda 1.39
DISCLAIMER:
QUESTIONS!?!?!
Pm me.
2 out of 2 members found this post helpful.
Old 05-13-2007, 12:11 PM
e39dream's Avatar
e39dream e39dream is offline
five a day
Cars: m52 powered
Send a message via AIM to e39dream Send a message via MSN to e39dream
excellent work Sleek! thanks for taking the time to share your progress- you just saved e39 owners alot of money.
Old 05-13-2007, 01:08 PM
Steve530's Avatar
Steve530 Steve530 is offline
Cars: 2001 BMW 530i
Nice write-up with good pictures. Thanks for documenting it for us.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads/M5 SSK/RedLine MTL/M5 rear sway bar
1998 323is CDV delete/Findanza LWFW/M3 clutch/Denso Iridium
BMWCCA Member #337964
Old 05-13-2007, 02:51 PM
SleekBMW's Avatar
It's a BMW
Thank you much for appreciating it.
Old 05-13-2007, 03:29 PM
Hotswimmer's Avatar
Hotswimmer Hotswimmer is offline
Cars: 1998 BMW 540i
Thanks for contributing this. Beautifully done.
Old 05-13-2007, 05:09 PM
SleekBMW's Avatar
It's a BMW
Your quite welcome
Old 05-14-2007, 05:42 PM
Shogunl Shogunl is offline
Cars: 528
I am going to be taking on this project this weekend for 97 528I
2 questions
1. If you have bad coolant temperture sensor your instruement cluster shouldn't work either?
2.Where exactely is this resistor located? Under the shroud/side?
Old 05-14-2007, 09:51 PM
SleekBMW's Avatar
It's a BMW
2 questions
I have never heard of this. i mean its worth just replacing, it is only like 25 dollars. So no biggy.
my car didnt have one, but they told me, when i was looking for it, its EXACTLY how it looks in the diagram.
GL
Old 05-15-2007, 07:16 AM
xxcat xxcat is offline
Cars: M3 EVO E36; 530D E39
Is it for 1st speed? Should it be closed or opened (temp?)?
Old 06-04-2008, 05:39 PM
busabim's Avatar
busabim busabim is offline
Cars: E46/E39 R1200GS
Pusher Fan replacement
Thanxs for the excellent write up it really made the job easy.
After all that work my temperature sensor switch is faulty; when I plug in my pusher fan it runs continuously!
BB
Old 06-04-2008, 09:58 PM
jnyost's Avatar
jnyost jnyost is offline
EACTuning.com
Supporting Vendor
Cars: 540i/6, 02 Excursion Powerstroke
Very nice work. Well documented. The hardest thing to do when working on your car is to stop and take pictures. I always keep on moving and forget to take pics...
Jared
Old 07-10-2008, 09:27 PM
Aero Guy Aero Guy is offline
Cars: '97 528, 2007 Cobra
I couldn't find the motor at the local parts houses but found a cross reference to a Four Seasons model. Ordered from below and the Siemens motor showed up with the right pins on it and the hook up for the resistors. A plug and play replacement for much less than the complete assembly shown by most online places!
I'm not allowed to post links yet but search for FS75720 at autopartswarehouse.com It's listed for a '97 740 but is the same as mine '97 528
Old 08-19-2008, 02:47 PM
wquiles wquiles is offline
Cars: 2000 BMW 540iA
Very nice writeup - thanks for taking the time to document it so well
Old 07-07-2009, 03:14 PM
s car s car is offline
Cars: E39
This is EXACTLY what I need. Looking at the realoem link, #5 is $468.19...not $297..am I looking at the wrong thing? Thanks guys.
Old 07-23-2009, 06:37 PM
mrfinagle mrfinagle is offline
Cars: 2002 530i S
I think that's too much money. My question is, can you use the DEPO fans on eBay for 139? My mechanic says the aux is 325 oem and that's what I should be using, but what happens if I save $186?
Old 07-24-2009, 01:56 AM
Cars: E39
I bought one of the ebay ones...I need to kick my cheap habits.
The fan seemed of good quality. Not quite as good as the OEM one I pulled, but still a fan that blows cold.
Like I said though, I need to kick my being cheap habits.
Old 07-26-2009, 03:57 AM
stormyslaton's Avatar
stormyslaton stormyslaton is offline
Cars: BMW 528i, Scooter
Does anyone know where I can get an aluminum one? I don't want to have keep replacing.....due to rocks cracking my stuff
Old 07-26-2009, 02:06 PM
jamesdc4's Avatar
jamesdc4 jamesdc4 is offline
Rogue Moderator ಠಠ
Cars: 98 540iA (Prd 11/97)
You could try my brother's Racing Mesh Upgrade...Inexpensive! retrofit. It looks better in black poly, but either aluminum or the poly will add additional protection from rock strikes.
E39 Ugly Mugs________________________________Registry Photos
Old 10-05-2009, 09:39 AM
pjett pjett is offline
Cars: 1973 Plymouth Satallite
Super Fast
I took my time on doing this, and it took an hour and 10 min to remove all of the parts, and about 20 min to put it all back. This was a great write up and recommend follow the directions to the letter.
I also took some time in fixing my head light adjusters(seeing that my headlights were already out) once I got through the first tab, that has a seal on it (top side) the rest popped right out, there is no glue to make it difficult to remove, and although I have read that there is glue holding the headlight together I would recommend checking first before you ruin your headlights, by doing something stupid like putting them in the oven. and drop in a silicon pack(got some from one of my wife's shoe boxes) to keep the moisture down, I was able to do the lights rather quickly, and adjusted the beams that evening.
