Went to track tonight thanks Ahmad for coming down and filming.
I wanted a easy full pass and got one .
It was actually to easy car could not get going this turbo needs to spin low rpm launches and a on off clutch make things slow and jerkey but once and all kicked in felt nice. Still shifting early hard to kepp a eye on tach and track and shift so I shift by ear.I have a shift light hooked up but never see it when racing .After this run they called me to the tower said had to get a cage they said they would let it slide but the MPH is getting up there.So that sucked then Ahmad and I had a Idea tell them I would run a easy pass but really try for a good run.
My friend that works there said they will only make you leave if you ran over again so I wanted one more run with a good start and taken her to redlime 8000rpm not 7400-7600. Well I found the next week link the input flange in the diff that bolts to axle went I should have know this would happen as I broke one last season.Any way there will be a upgrade on these as I talked to drive shaft shop already and he said he would make us some
Like the title says I will not give up
http://www.bmwturbo328.com/street/1strun.wmv
http://www.bmwturbo328.com/street/2ndrun.wmv
996WHP 2.8 and going nowhere fast
. e36 4Dr with A/C and leather seats in U.S.
www.bmwturbo328.com 9.93@152.6
Inspiring to see your effort, keep it up man! Good luck.
Joseph
Dealer for: TC Kline, Aquamist, AEM, Haltech, KW Suspensions, and more! PM me if interested.
man the saga continues.. keep at it.
there is no doubt that car has 9s in it. 11.02 on a "slow" pass.
Sucks that you broke but I admire your tenacity. Good luck, you WILL get there eventually.
edit: what am I missing here? http://www.dragtimes.com/horsepower-...power+Estimate
1/4 mile in 13.1 @ 106++ (calculators put this at 0-60 in "4.21" seconds.)
Good progress Uly ... stick with it and you'll be there before long.
.-=[ Kenny ]=-. See the BFc Drag Racing Standings List for BMW street cars. Watch my drag racing movies on YouTube. Some info on
BMW turbo street car Drag Racing 101
I think you surprised the hell out of the announcer with the trap speed Widebody that thing and get some beef under the rear!!
----Dave----
Nice run Uly.. What boost level was this? 142mph is moving!!
__________
98 M3
2008 G35S
anouncer definately seemed surprised at that trap, lol. nice!
lookn good man keep it commin!
///Andres
11 X5d sport - daily tow rig
09 335d - evolve tuned 327whp / 490wtq
97 M3 - NASA TTB
95 M3 Turbo - 3.0l s52, PTE74GTQ, AEM EMS & CDI, etc
You are not missing any thing dont use et as that has to many varibles
use trap speed and weight (weighed in last night at 3380).My car gained
30 lbs over the winter was 3350 last year I think bigger turbo,
metal manifold and no loger use a light weight battery.It come out to 752whp
Thats a litle lower than I thought but off waste gate spring no gain = slower
boost and Im using less timing than original map.It takes a while for the turbo to spool.The slow start car falling on its face(it takes a while for the turbo to spool) a low rpm start hurts the trap and et with this setup.
http://www.speedworldmotorplex.com/calc.htm
Thanks Kenny ,lucky season is just starting so I have time to get the bugs out
True,what sucks is I need rpm for turbo
but the triple disc will not let me slip clutch like twin disc did, its on or off period.
22lbs waste gate spring.
60ft 2.327
1/8 113.16
1/4 141.77
et 11.02
I REALLY DON'T THINK THAT MOST PEOPLE REALIZE WHAT A 141.xx TRAP SPEED REALLY MEANS. That MPH correlates to a high 9 time slip!! It's gonna get scarrrrrry when you can hook up.
Holy wategates
great work Ulysees
That announcer was shocked to hell when you laid down 141mph!!
Just a real shame the bolts broke on the second pass..just as he said "now watch this BMW, he was real quick on the first pass" ..still, should be an easy repair hopefully.
Also, with regards to your 3 disk clutch, can't you just hold the revs high and drop it..BAM....and see if your drivetrain is truly beefed up That would test all those new parts for sure though
Keep at it CC!!
Thanks for posting the vids.
Yes, thanks for posting vids and keeping us all updated!!!!
Actuall the input flange in the diff that bolts to the axle broke heavy duty one are being made.Seems like 5000rpm has broken somthing every time.Sad thing is I need a 6500 rpm launch to be optimal my peake tourqe is 5700rpm launch at 6500 rpm and it will drop right in to peake tourqe
You said brother ..I just need more practiced with the new clutch.Im thinking maybe try a higher rpm as 5000 is the highest I tried
both times broke somthing.You think I might get better clutch slip with a higher rpm as the clutch just sticks at 5000 like a magnet.
If I make or breakI post there are few that only show the good but we all know with good come bad. Its also interesting finding the weakest link.After the flanges are made the only two things left are diff and trans
just to point out the vega ran in the 9's with a 13xmph run!
All you need is a solid launch w/ nothing giving up and you'll be there!
11.75 @ 131 6262 2.8l TRM Tuning e36 m3 - 2011 http://dragtimes.com/BMW-M3-Timeslip-23541.html
Keep up the hard work man! Your surprised the crap outta that announcer hahah.
i just love the fact that the front wheels nearly lifted off the ground!!!! keep workin at it bro!
p.s. i am home in a week and a half. time to work on cars then!
TCD S3 Completed! 400 rwhp/455 tq. Tuned by Larry Strouth @ HP Works.
www.Turbochargingdynamics.com
http://forums.bimmerforums.com/forum...929post7215929 <-------Parts for sale
nice videos, you don't have a roll cage yet?
National Capital Chapter BMW CCA #367673
Sounds like that clutch setup is killing you more than helping.
Rob - 2000 BMW Z3 M Roadster | 1986 Porsche 944 5.3L LM4
