I finally found a decent throttle cable for the E12 throttle body that works perfectly, it only cost $25 at autozone. I had to modify things slightly to get it to fit, but it was an easy install. I also notice a little bit more power at the top end.
Here's a pic of my temporary weld job to get my too short stock cable to hook on to the e12 throttle body. It got the car on the road and drivable but it was preventing me from getting WOT:
Here's a comparison of the end fittings for the firewall, I couldn't believe how close they were:
Here's the stock gas pedal hook/lever:
and after grinding a little to fit in the new cable end:
Here's the 2 cables side by side:
And here it is installed, I slipped a piece of rubber hose over the housing to protect my shock tower from abrasion:
eh, a few more to show the installed cable better:
E12 TB FTW
Clean install too! Your car is rockin now!!
Josh,
Every time you post pics of a project I am in awe of your work.
Bruce
Only Josh can make a throttle cable thread interesting...
.: M42 Swap Thread M42 Turbo Build Thread E85 Conversion :.
My YouTube Channel: https://youtube.com/c/AdamPE21
Josh, is that a universal throttle cable or a new E12 cable? What part number?
engine bay looks very good, it looks like just out of a show
e30 325i, the mighty 4 door granma mobile....Gone
e39 528i, 4 door sports tank
You car as usual looks great. Props.
"..Horsepower is a measure of work done over time, or the rate at which work is done."
http://www.cardomain.com/ride/579694/1
It's a universal 3' cable w/ 2' housing, brand name Spectre, part # 2431
Spectre throttle cable
Every time I see you engine bay I get jealous at how clean it is. Simpley awesome job!
how'd you get the part off to file it? i don't see how to get it out of there.
What part? The stock throttle lever under the dash? a couple snap rings and it should come out, I don't remember more than that. It wasn't hard.
Wow! That looks amazing! Thats also some really nice welding on the strut brace too. Perfect bead. Good job on the entire engine bay dude! It looks gorgeous!
Kudos x2!
thanks for the partial, i'ma run your print through avis. Hopefully you are wanted for questioning which will lead to the necessity of you selling me your car for bail......
haha...jk....top 3 e21 in the states imo....
amazing, im in awe... such a nice engine bay. really creative too. good job josh
Not only is that a nice install, but the braided cable just adds a little more flash to that killer engine bay. I think I need to detail the crap out of mine this year. It looks like hell compared to yours.
THE E21 MOVEMENT IS ON - You can either go with me or against me, the choice is yours!
~ JT ~
1977 BMW 320i - 1986 BMW 528e
http://jtresto.com/e21info.htm
ur engine bay is stoopid clean
Bav's Build Thread: http://www.stanceworks.com/forums/showthread.php?t=2498
thanks guys. fyi, its more fun to drive than to look at.
I still want your wheels.
~ JT ~
how did you remove the cable?
He's probably looking for a car, considering that there was no 318is built prior to 1989, and even those were only for Europe.
Cable removal is easy enough, you just need to get in there, disconnect it from everything, thread it out. Getting it all back threaded through is the part that's a little harder.
Metal Bumpers Are For BEEETCHES!!!!! "King of Lean" - Retired
"If that bikini isn't made of Micro-Fiber and has Quick Detailer on it then GTFO!" -BabyM
