1993 BMW E34 M5
Last year made for USA Market Hand built in BMW Motorsport, Germany
Black on Black leather
Sport Seats
Every option
Full Records since New (100's of reciepts)
150,xxx Miles
No Accidents Ever
Ice cold A/C
Dinan Stage 2 SLS Delete Suspension
Dinan EProm
Dinan Cam gear
Tri Flow SS Cat Back exhaust system
AC Schnitzer Type II 17x8.5(f)17x9.5(r) Wheels (1995 Dead stock shipped from Germany)
New Toyo Proxes 4 225/40 (f) 255/40 (r) Tires
Brembo Drilled Front rotors
Rare nardi 14" Steering wheel
Bimmian Aluminum Shift knob
Original BMW Motorsport Mirrors
Original BMW Motorsport Door Handles
Ellipsoid Headlights from later 750iL
Hella Euro Tail Lights
Hella Euro Front corners
Alpine 9856 Headunit w/ipod connect
JL Audio 250/1 & 300/4 amplifiers invisibly mounted on rear deck
Bavarian Soundworks front 2.5 inch midranges
MB Quart front+rear components mounted in stock locations
Full Engine rebuild performed my myself (I am a auto engineer/mechanic) @143,xxx Miles
Engine dynoed @301 to Wheels! 286 Torque
Every part that wasnt perfect was replaced from oil pan up!
CP 11:1 CR Forged Aluminum Pistons 94mm
Fully Blurprinted/Balanced Crankshaft,Rods,Camshafts
Cylinder head by Steve @ Hollywood Racing:
Flowed and ported
Full 3 angle valve job
All new valve springs,bronze valve guides,seals,keepers
VAC Motorsports MLS headgasket
BMW M3 Updated Chain tensioner
New Oil Pump & Drive Gear
94mm Bore bottom end, all new rod and crank bearings
New Behr radiator,water pump,thermostat,overflow tank & all coolant lines
New oil cooler and oil cooler lines
New Motor mounts
All components have been hot tanked,media blasted,and painted this a beautiful and clean engine
Fully rebuilt intake manifolds (individual throttle bodies):
Disassembled and media blasted better than new
all new gaskets,seals,hardware has been renewed or replaced
Fully synchronized and flow perfectly
Rebuilt Fuel injectors flow within 0.9% of each other with all new internals-flow bench tested to 9000 RPM
New high pressure fuel supply lines
Transmission:
Fully rebuild by the only experts on the west coast for Getrag 280's
New synchros from 1-3
New 5th gear was installed
Red Line Tranny Fluid
UUC Motorwerkes street/race tranny mounts
UUC Motorwerkes enforcer supports
Short shifter kit
Fully Rebuilt Shifter linkage
Driveline:
Rebuilt/balanced Driveshaft (new guibos)
Body:
Is original and never repainted, shows some chips and a couple of dings, expected from a 13 year old car. Overall Very good.
No rust ever! very solid garaged California BMW.
Interior:
The best of any e34 M5 i've inspected, minimal wear on drivers seat,no rips or tears anywhere the rest of the seats look almost new.
Dashboard is perfect along with the rest of the interior.
Clean carpets and headliner.
All controls 100% functional
Recent Fan control resistor pack replaced (common e34 problem)
Additional:
No expense was spared in this rebuild. I spent countless hours digging through the BMW Parts catalog ordering every last o-ring,seal,oil seal,gasket,vacuum hose,etc that was involved in the rebuild process.
Many parts and detail have been left out, for length's sake I have full reciepts for everything I replaced and only used OEM BMW parts or better.
I have a full detailed photo journal of the entire process as well.
Everything assembled by myself with high quality workmanship and snap on tools, if you want it done right, do it yourself!
This car runs strong and doesnt skip a beat. Very fast and civilized supercar that will keep up with (and beat) almost anything out there.
I built the engine be reliabale and better than stock.
This is one of the best BMW's ever built, rare and has the respect of any BMW guy. It'll be tough to find a better E34 M5.
Looking to get 19,500, Email/PM me if interested!
This car is sexy! and fast! You need to here her!
Will entertain trades! looking for possibly a 3 series or M3, any year.
Email me vespam5@gmail.com
Rebuild Pics in reverse order: for some reason i cant link the photobucket, but add a space between the "/BMW" and "M5/" at the end of the link
http://s3.photobucket.com/albums/y100/vespam5/BMW M5/
Please post pics ASAP of this amazing car.
E82 135i: Alpine white on black leather; ZSP; ZCW; iPod/USB
Previous Bimmers owned (from last to first): E46 M3, E34 540i/6, E30 325iS, E34 525i, E30 318i
you need at least 10 posts in order to post pics. Go to the off topic forum, make 9 coments here and there and then you should be able to post some pics.
No posts in the Off-Topic section dont count as actual posts. You need to make posts in actual threads. Id say to start in the E34 5 series section. Actually, you could start by commenting on my exhaust thread.
http://forums.bimmerforums.com/forum...d.php?t=715680
Thanks!
Nick
________________________________
Nik
91' M5 3.9L Stroker
92' M5 3.8L
95' 540i6 Supercharged
95' 540i6 4.7 Stroker
95' 550i6 M70 Conversion
Hurry Up!
I would rather be judged by 12, than carried by six!
i cant pm you either -- please send pics to dcazin@nc.rr.com
HPDE Driving Instructor (THSCC/TZC)
Ok figured it out, and finally it works. more pics to come, please try Pming me again M3Raleigh!
Bump for a VERY clean M5, if only....
-Brandon.
WOW! That is a sick M5. Good luck with the sale!!
Has anyone really been far even as decided to use even go want to do look more like?
wow is right. b e a utiful
bump for a sick m5...
pics man!
More pics!
Interior
And
More
More
that is beautiful. wish I could afford it! Great job!!
want to trade for an e30 m3 plus some cash?
Edwin
Got Jesus?
wow
I miss her, back in a BMW for the time being
trade for my 19 year old girlfriend (cheerleader, european, sexy)
my 98 328i (black/black, some tasteful mods)
and like 4400$CAD?
i didn't think so, but it was worth a shot
Ask me about Canadian DRL compatible LED Kits
first off ... the car is absolutely gorgeous. secondly ... friggin amazing job on that engine. impressive numbers ... that is a seriously strong s38!!!
1997 M3/4 5spd: Dinan Supercharged; Vortech V2 SQ; AA Tuned; Stromung exhaust; Cross-drilled rotors; Bilstiens; NO SUNROOF; Manual non-heated seats; 3.38 LSD; only 56k miles young!!!
Pics: http://summer2006-m3pics.mypicgallery.com/ Pics: http://m3-pics2.mypicgallery.com/ Pics: http://m3-pics.mypicgallery.com/
bump!
so georgous. Good luck with the sale
1992 Racing Dynamics 325i SOLD
1995 Mugello Rot M3 SOLD
1973 2002 SOLD
1999 Estoril Blue M3 SOLD
2008 550i M Sport Current
badass
good luck with the sale!
440 whp & 335 whp
how bout my m3 and a mountain bike 21 spd! hahahaha
sweet m5 though good luck with the sale!
ever take it up to turnbull canyon?
1997 Alpine White BMW M3
2002 Stellar Blue Pearl Toyota 4runner Sport Edition 4wd
if only i had moo money its everything i want in a car too
M3 is life
