Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Forced Induction sponsored by Active Autowerke
Forced Induction sponsored by Active Autowerke Discuss turbocharging and supercharging your BMW engine. Also force-feeding Nitrous, Propane or water.
Active Autowerke
Old 02-12-2007, 09:18 AM
marc1119's Avatar
marc1119 marc1119 is offline
Senior Member
Supporting Vendor
Cars: 97 Blown M3, 08 335I
Originally Posted by IMPORTEDCARS View Post
Thats edxactly what I was told.... so I did not want to coment and stir up any issues.
Enlighten me..please....
I am in NO WAY a T trim expert....I only had one 10 minute conversation with Vortech, and I am not saying what I was told was accurate..
If a T trim at 46,000 RPM makes more CFM than a V1 or V2 at 46,000 RPM, that is great...I just was told NO..by Vortech.....
1997 M3 Coupe technoviolet 39K miles
new T trim upgrade, RMS Stage 2+ ,AA custom tuning, Porsche HFM, Schrick cams,M50 manifold,Cometic .080 HG,ARP head studs,RMS headers,AA race exhaust,42 lb injectors,Kenne Bell BAP,Aquamist WI, 3.64 gears,AA clutch/ LWFW,Brembo 4 wheel BBK's, Sparco Evo 2's,Sparco harness bar and belts,Sparco wheel, 18 inch BBS RC's, PWR 58MM Radiator,Bav Auto coils, Samco hoses, UDP's,GC coilovers, Powerflex LCAB's, RTAB's, Motorsport frt and JTD rear brace, X brace, RD sways, GC endlinks, Vorshlag camber plates,Vorshlag poly motor mounts, JTD trans brace, AA DSB,AA rear camber arms, Rogue diff cover, MA Shaw GTR hood, etc
2008 AA'ed 335I Coupe Space Grey,Steptronic, Sport Pkg, Black Leather
AA Intercooler,AA stainless exhaust,AA downpipes,AA BOV and AA processor,Sprint Booster, PSS10,TMS boost gauge, Stoptech rotors, Hawk HPS.. 19" Forgeline ZX3S
Old 02-12-2007, 09:33 AM
IMPORTEDCARS IMPORTEDCARS is offline
Senior Member
Supporting Vendor
Cars: 977rwhp SAE and 821
Send a message via AIM to IMPORTEDCARS
I was told the same thing. I WILL not get into this b/c #1 im super busy today... and its not my priority today, besides Philip has the same Map that I have. Try studying it and see what you come up with... im sure you can find time in your day, we would all appreciate it.
GeorgeKakaletris@gmail.com (203) 653-2394
ICS Performance
www.ICSperformance.com
Technique Tuning Authorized Dealer and installer.
Custom software available.
Authorized HKS Dealer and Pro Tuner.
Latest ICS Performance Stage 1 Dyno Video.
http://www.youtube.com/user/Icsperformance
Old 02-12-2007, 09:47 AM
marc1119's Avatar
Senior Member
Supporting Vendor
last question, since you are busy...
Vortech told you ALSO that there is NO ADVANTAGE of a T trim to an S trim below 50,000 RPM, except for durability..correct?
Because that is what I am basing my info on, and my RPM calculations on...
Old 02-12-2007, 09:59 AM
pbonsalb pbonsalb is offline
Cars: Bavaria, 2002, E39 528i, E36 M3 SC, E70 X5 4.8i
But Phil..isn't the majority of the advantage of the T1 happen after 50,000 RPM....?
That is the way I see it -- I agree and would not put a T Trim on an E36 M3 and spin it to any less than 50,000 rpm because as you point out, the advantages, if any, would be slight.
But this thread is mostly about an E36 M3 modified with lower CR so it can run more boost. The blower has to spin faster to make more boost, and the S Trim is not rated to spin any faster. The T Trim offers up another 5000 rpm, which might equate to the kind of boost increase we see when going from 45,000 to 50,000 rpm with the S Trim. I'd be hoping for 16-18 psi at 55,000 rpm.
Another point you brought earlier in the thread also comes into play -- the T Trim is a V1 based blower with straight gears and thus uses a 3.45 step up ratio. That means a bigger pulley ratio is needed to get to the 55,000 rpm impeller limit. A 6.00/2.60 combination might work with an 8 rib, but if there is slippage, it might take a 6.25 or 6.5 or larger crank pulley (clearance might be an issue at some point for those with fat radiators), but I am sure all this can be figured out along with other things like bigger injectors and tuning.
I am watching and waiting. I am also still hoping for some data on squish -- the tuning differences required for, say a thick HG S52 with 9.5:1 CR and an S52 with 9.5:1 pistons and no other changes (probably impossible since anyone building an engine will likely do some head work). Based on the dynos posted in the first page of this thread, though, the problem seems minor if it is a problem at all.
Philip Bradley
Old 02-12-2007, 12:46 PM
highboostingm3 highboostingm3 is offline
Thick Member
Cars: Turd with wheels
Send a message via AIM to highboostingm3
Old 02-12-2007, 01:44 PM
DIRT11's Avatar
DIRT11 DIRT11 is online now
Cars: 540I SPORT
Originally Posted by highboostingm3 View Post
Now where could I fit that under my crowded 540i hood.HMMMM,
Old 02-12-2007, 02:06 PM
The guy does not even know whether the intercooler is one, two or three rows. I did note that they used the V2 SQ S Trim on the new Corvette. Its a high CR motor that runs high rpm, but they keep the boost to 7 psi so the impeller speed is not an issue. They also discussed the noise of the V1 based blowers like the T Trim.
Philip Bradley
Old 02-12-2007, 02:29 PM
Originally Posted by carcrazed4life View Post
1) Even with the boost pump on the fuel side, I was still maxing out my injectors at the limiter.
The boost a pump will not prevent you from going to 100% duty cycle. All it will do is increase voltage which increases pump output. At some point, it can increase pump output to the point that it overpowers the stock fuel pressure regulator, which will increase fuel pressure and thus increase fuel flow. That can be tricky to calculate, but you might figure it out through trial and error. It is also possible that the regulator would not last.
You could go to an aftermarket regulator, and raise fuel pressure and then scale it down in the software. NickG already does this to some degree when he uses the Walbro pump that overpowers the stock regulator at low rpm and that would otherwise cause the motor to run rich.
You could also go to larger injectors. I don't think 52 lb injectors are really that big for a 6 cylinder for tuning with the factory ECU for a smooth idle even if they are high impedence. I think it would be pretty easy to scale the fuel part of the programming accordingly. This would seem to me to be the way to go.
Philip Bradley
Old 02-12-2007, 02:43 PM
Senior Member
Supporting Vendor
Philip Bradley
I have never seen a Walbro 255 lph ruin a regulator unless the diaphram is weak it may cause a rise in fuel pressure. I have tested this theory over and over, 2nd.. a boost a pump once hooked up to the fuel pump via power and ground will automatically raise the voltage from 12 volts to 14 volts without adjusting the idle.
ICS Performance
Old 02-12-2007, 02:57 PM
Jim M3's Avatar
Jim M3 Jim M3 is offline
2 blown 3's
Cars: 97 M3/4 Lux, 07 BMW 335XI zsp, 03 BMW X5 4.4 sport
My AA tune didn't work with the Walboro even after putting in a new regulator.
1997 BMW M3/4 Cosmos Black Luxury Package 437whp 378 ft/lbs torque Dyno Dynamics Dyno
10 psi Stage III KO Performance Vortech supercharger,
Old 02-12-2007, 02:59 PM
Senior Member
Supporting Vendor
Sounds like a first to me, unless Nick's software automatically adapts to such minor issues without causing issues elsewhere.
ICS Performance
Old 02-12-2007, 03:26 PM
m3jasper m3jasper is offline
Bavarian Solutions
Supporting Vendor
Cars: e36 m3, e46 325, e36
Mine was just richer across the board when I swapped the walbro in. Marco advised me to take it out as it would eventually mess up the fuel pressure regulator as it did in your car.
Dave Vilanova
E: Dave@BavarianSolutions.com
W: www.BavarianSolutions.com
Old 02-12-2007, 03:39 PM
carcrazed4life's Avatar
carcrazed4life carcrazed4life is offline
ICS/NickG St. 4 Vortech
Cars: 99M3, 97NSX, 03S600, 04RX330, 04Dakota, 01 3.2TL
Is it just Jim's Car that experienced this with an AA tune, or have others with AA Tunes experienced this as well?
I for one have never had issues, but my tune has always been NickG and I've had the Walbro in there since it went to George.
Just curious thats all.
Engine & Driveline: ICS Stage 4 SC * 8 Rib * 15+psi * xx# injectors * Schrick Cams * Larger HFM * Port & Polished Head * 3 Angle Valve Job * VAC MLS .140 HG * E36TD Fan Setup * Shorty Headers * Track Pipe * UUC UDPs * S54 Oil Cooler * OEM S54 Radiator * S54 Guibo * Stromung Exhaust * ACS Delete * UUC SSK * Rouge WSR * UUC TME
Chasis Tuning: GC COs * UUC Sways * X-Brace * Rouge RSM * GC RTAB * AA DSB * Z3 Steering Rack * BBS RC 18x8.5 ET38/ 255/35/18s @ all 4* Front Strut Brace * RaceLogic * 3.38 LSD
Exterior: DEEP BLACK PAINT * Rolled Fenders * Custom Vented Hood * RD Diffuser * Red DDEs * 8,000K HIDs * Smoked Markers
Coming Soon: Finish ICE * 6-sp Trans * 6 Pot 13.6 Fr, 4 Pot 12.9 Rr BBK
4 Sale: M3 S52 Cams * M3 Rear Seats * 99 M3 Fan&Clutch, Intake Manifold, Headers * Alum Therm Housing * 42# Injectors * Dresmann Rear Kit * Tilton/ICS Flywheel & Clutch * LED, Smoked & OEM Taillights * & More
Wheels & Tires: Custom 18x8.5 BBS RCs * 3 17x8 Grey OZ Superleggeras * RD RGS 17x8
Old 02-12-2007, 03:41 PM
Bavarian Solutions
Supporting Vendor
Marco told me that Angelo experienced the same thing. I found it odd since Nick has so many turbo kits running around with the walbro and I haven't heard of any problems with them. George also tells me that he has never had a problem with them.
Dave Vilanova
Old 02-12-2007, 03:51 PM
Jim M3's Avatar
2 blown 3's
I installed an entirely new fuel system components, new filter, regulator, pump and it ran like crap. The car was pig rich and idled pretty badly on my car.
Old 02-12-2007, 03:56 PM
Senior Member
Supporting Vendor
It must be some of differences of the 2 tunes.
ICS Performance
Old 02-12-2007, 04:01 PM
Bavarian Solutions
Supporting Vendor
I believe its because the AA tune is supposed to run on the oem pump. When I was on the dyno the first couple of times, George gave Karl a ring to ask why the car was detonating up-top. Being that I had the original pump in my car, he suggested that I install a walbro. Afterwards, I was told to remove it and it would cause a conflict since the tune wasn't designed with it.
Dave Vilanova
Old 02-12-2007, 04:05 PM
Thick Member
Philip Bradley
Yeah that is sad that he didn't know. It wasn't the blower on the Corvette that I was talking about, however as long as more power is made, I guess psi is relative like with a turbo. With a very large blower you flow more air at less psi. More power is the ultimate goal, not psi.
The Stimpee part was only because Stimpee had mentioned in another thread how he thinks air-water will always dominate over air-air in a blower setup where someone else argued air-air is always better. This guy agrees with Stimpee so I was just pointing it out since a spokesperson for Vortech agrees with Stimpee which is sorta cool.
Old 02-12-2007, 04:06 PM
NickG has stated in this forum that the Walbro overpressures the stock regulator slightly at idle. His tune takes this overpressure into account:
http://forums.bimmerforums.com/forum...ht=walbro+nick
Oother tunes that do not may run rich enough at idle to cause problems, which seems to be the case from what several others have reported in this forum.
Philip Bradley
Old 02-12-2007, 04:07 PM
Thick Member
Maybe it changes flow characteristics as if you were to install different size injectors. If the tune was designed for one thing, then changing that thing(fuel supply hardware) would require a custom retune for that specific hardware?
Old 02-12-2007, 04:13 PM
Bavarian Solutions
Supporting Vendor
Philip Bradley
Good to know.
Makes complete sense. Thats why I found it odd that I was told to keep the OEM pump but when the car went on the dyno and detonated, Karl said to install the walbro.
Dave Vilanova
Old 02-12-2007, 04:16 PM
Eric BMW's Avatar
Eric BMW Eric BMW is offline
Senior Member
Cars: 95 M3 Turbo
Send a message via AIM to Eric BMW
Superchargers are confusing
Rancho Palos Verdes, CA | St. Louis, MO
1995 BMW M3 Turbo - Dakar/Black
Old 02-12-2007, 04:31 PM
Bavarian Solutions
Supporting Vendor
This one is for George and Kurt (Paradigmguy)...superchargers are cool, turbos are gay!
Dave Vilanova
Old 02-12-2007, 04:34 PM
Senior Member
Supporting Vendor
Hey Kurt lets get him.
ICS Performance
Old 02-12-2007, 04:35 PM
ParadigmGuy's Avatar
ParadigmGuy ParadigmGuy is offline
Cars: '97 M3/4 - black/bla
Send a message via AIM to ParadigmGuy Send a message via Yahoo to ParadigmGuy
How is it that turbos are gay but it's superchargers that suck?
Kurt for President in 2024
