Nickg's Software Obd 1. For A Vortech Blower 8psi,540 Hfm,and 36 Lbs Injectors.chip $250 Shipped Obo..
I Used It With 8 And 11psi. With W/i..CAN BE USED WITH 413 DME TO BE DISCLOSED BY PM AFTER SALE.
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
Here's My Dyno At 8 Psi..mustang Dyno
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
Looks like it goes kinda lean after 5300 rpm?
Do you have the dyno sheet with this chip & 11 psi?
I have a socketed 97 obd2 DME, this wont work I assume?
Not sure if will work with your DME.Mine was a 413 and I used a 506 chip..
I'm assuming the sniffer was a little weird cause this is a dyno before with the same setup.No changes
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
97m3john I sent you an email but no response. I am very interested. What motor was this running on? How can I confirm my DME version (93 325is)?
IDON'T HAVE MY EMAIL LINKED TO THE FORUMS.iF YOU WANT CALL ME..CAUSE TOMARROW I WON'T BE NEAR MY COMPUTER.
PULL YOUR DME OUT OF THE COMPATMENT AND ONTOP THERE ARE A BUNCH OF#'S THE LAST THREE ARE THE VERSION..IF YOUR 506 OR 413 YOUR OK
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
Still Available
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
Still avail?
pmed
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
