Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > M series > 1992 - 1999 M3 (E36)
1992 - 1999 M3 (E36) (1992 - 1999) BMW's second generation M3, and the first M3 to feature BMW's classic inline six motor. Featuring 240hp (european models had a 286hp and 321hp), a slick shifting gear box, and near perfect weight balance, the E36 M3 was named Car & Driver's "Best Handling Car At Any Price."
Old 12-21-2006, 05:56 PM
rao rao is online now
Cars: Chevy powered 92 325
Clutch Master Cylinder Bore Size
I am trying to confirm the bore size of the M3 clutch master cylinder, both the older pre 95 build date style and the newer style. The best information I can find is that the older style is 5/8" and the newer one is 3/4"
Also, are there any other BMW clutch maters that will fit that have a larger bore?
TIA
Old 12-26-2006, 06:49 PM
anybody?
Old 12-26-2006, 07:30 PM
///M3 CRAZY ///M3 CRAZY is offline
A.K.A. Drew
Cars: z06, toyo tundra
i do not know the answer but i am curious as to why you would want a larger bore on the master cyl?
do you even know what a plethora is?
Old 12-26-2006, 08:01 PM
I need to know if a shim will be neceessary on my T-56 release bearing. If the MC is 5/8" then it will be a close call, at 7/8" I know it will work just fine.
Old 01-19-2007, 10:12 PM
I replaced the cluitch master and took the old one apart and measured. The bore size is 3/4" (0.750"), which puts it right between 5/8 (0.625") and 7/8" (0.875"). Tough call on the shim, but I think I am going to use a .125" shim.
