Originally Posted by
Justin e36
7 button on board computer:
1.Hold down the HR/DAT button for 3 seconds. The time will begin flashing.
2. Now use the h/DAT and min/DAT buttons to adjust the minutes and hours on the display.
3. You can also press the °C/°F button at this time to change between 24-hour display, and 12 hour (AM/PM) display. (this is an undocumented feature.)
4. Press SET to save the time.
5. Now you can input the date using the same h/DAT and min/DAT buttons. Press SET again, then you can input the year, and finally press SET one last time.
For an 11/18 button OBC hold down TIME for 2 seconds, use the 1, 10, 100, and 1000 buttons to adjust the clock, then hold down TIME again to save your settings..
