After a coule months of having boost leaks and vaccum problem. We finally got Darth Mauls car running perfectly. We did a few 4th gear pulls on the freeway at 10psi.
Heres a few AFR reading.
This is at idle. Can you say cheese
The begginning log was a pull from part throttle in boost 10.9-11.5
last but not least a coule of WOT pulls 11-11.5 at the way to redline
After two ecu burn, i getting use to this. Next stop. We are installing the Porsche HFM this coming saturday. Bumping up the boost and burning new maps.
If you are just reading this.
Here is his setup:
42#injectors
TSI kit with GT3076R
euro 3.5" hfm
in a draw thru configuration
ECU tune by me.
OBD1 ECU TUNER
Why don't you use a blow through setup?
-Curt
stock CR 92 non-vanos 325 / first ever Holset HY35 powered BMW / custom tubular manifold & motor mount / stock DME tuning / tial 50mm bov / 46mm xspower w.g. / green top injectors / IC piping designed by myself (above subframe of course) / 12x28x3" IC / oil return into pan that seems to work / e21 tranny mounts / custom blow through MAF / koni sport kit / 18x8.5 mvr replica's / various leaks & body colours
-Curt
he is using BOV thats the reason for the spike. the tune is intended for draw thru
OBD1 ECU TUNER
-Curt
Do you keep your accelerator to the floor between shifts?
EDIT - Explanation:
BOV = Foot off accelerator = Throttle almost closed = almost no fuel = infinite oxygen and 0 fuel. In a nutshell, there is still pressurized air coming in that the BOV hasn't had a chance to completely relieve between shifts, but the DME has cut out fuel because the foot has come off the accelerator. Capice?
Boracay FTW
~Greg
My "small" engine is now 6.0L
'08 Trailblazer SS, '09 C6 Z51 (now with 600rwhp)
Calibrated SuccessEFI Tuning Classes and Consulting
Engine Management: Advanced Tuning
January is a perfect time to go - not too hot or rainy, and tickets are fairly inexpensive. I think we are going then also - we just went in May, but holy crap mainit naman! The heat of the summer, and the humidity of the monsoon season. Loved being there, but this 'Kano was melting.
Congrats on getting it dialed in more. A different maf would be nice, but you'd need the VE tables for it which aren't easy to come by..
Porsche Technician
1996 328is - |AFE intake|S52 cams|M50 manifold|Custom trackpipe|AA Tuned DME|Stromung catback|Fan delete|ASC delete|3.23 LSD|MZ3 Shifter|Sparco Front Strut Bar|Powerflex FCAB, RTAB, and subframe bushings|RE clutch stop|RE Transmission mounts|LTW5 17x9 wheels|245/40 tires|Bilstein BTS kit|HID Depo's| -*SOLD*
1995 Turbo M3 - 405/395 at the wheels - *SOLD*
I can't wait to see how it does with colder plugs and the porsche and more boost. When I let off the throttle it does go rich for a second then normal, not too bad, but it's something I gotta deal with for now. Anyways, I'm glad it's going to be up and running for the meet this saturday.
1997 BMW ///M3 - Estoril Sedan 5MT - M-Rain Interior (1 of 1)
2001 BMW ///M3 - Laguna Seca Blue 6MT
YouTube: (///Motorsport Throttle) https://www.youtube.com/channel/UCUM...pYSmibzy5YmUvQ
didnt you just do a DIY turbo. So what are you going with as far an fuel management? Are you still using turner motorsports chip for your turbo application?
OBD1 ECU TUNER
Not bad - the idle afr looks good. One thing that people sometimes have issues with idle afr is no only their fuel bins bouncing a little but also their spark bins bouncing. I like that my ecu offers idle lock - meaning at < X TPS, Y kpa, and < Z RPM, it locks a static timing advance and all you do is set fuel. I used to have a fluctuating idle and that is loooon gone
Good work.
-Curt
oooooooooooo PLEASE figure out a way to make the ford 90mm ass air meter work!!!!!
1/4 mile in 13.1 @ 106++ (calculators put this at 0-60 in "4.21" seconds.)
