Results 1 to 25 of 27
Thread: What's the most Boost I can run on my GT30R w/my setup??
    Phoenix, AZ
    E36 M3/4/5 & E46 LSB M3
    I got the following installed:
    -VAC .140 MLS Head Gasket
    -ARP Head Studs
    -GT3076R Internal Wastegate
    -Porsche 993 TT HFM (next week)
    -GReddy Profec II Boost Controller
    -Innovative LC-1 Wideband
    -Gonna get a Dyno Tuned Chip from my friend Titus (Dredder), most likely next weekend or so if he has time.
    Just wondering how much boost I can run safely on this set up, with good tuning.
    1997 BMW ///M3 - Estoril Sedan 5MT - M-Rain Interior (1 of 1)
    2001 BMW ///M3 - Laguna Seca Blue 6MT
    YouTube: (///Motorsport Throttle)
    https://www.youtube.com/channel/UCUM...pYSmibzy5YmUvQ
    Aug 2003
    San Diego,CA,USA
    1997 Turbo M3 Coupe
    Well doesn't look like your fuel pump or lines have been upgraded so even though you have the compression ratio, you might want to do 11-12psi max on 93 I would think. With that better pump you could probably do 18psi with the proper tuning and larger injectors...what size are your injectors?
    Where have I been? Astral projecting.
    Quote Originally Posted by jszy25 View Post
    Get drunk with Mike Radowski they said, it'll be fun they said...A broken toe, the worst hangover known to man, and bite marks in my arm said otherwise
    Jul 2004
    Pluto
    93 325iS
    I thought he was running 42#'s but maybe he isn't being its not listed. Speculation on my behalf, but I think with 42# injectors 18psi should be safe on 91-92oct pump.
    How important are lines and pumps, and at what point does that come in to play? The Eurosport TS has an upgraded fuel pump, but stock lines. Where is the point that it becomes required to have larger lines or pump?
    Thanks guys!
    Phoenix, AZ
    yes I have 42#'s. Guess I would need to get an upgraded fuel pump. Not sure about what lines you're talking about?
    Apr 2003
    Toronto..
    turbo325is, 01 330xi
    i think hes refering to your fuel lines, you can upgrade your pump and continue to do so but if the lines restrict the flow than it will obviously hinder your performance.
    Jun 2005
    NYC
    A Junky One
    what kind of upgraded lines are available????
    Apr 2003
    Toronto..
    that ill let the experts on FI answer as im not close to even needing those with my little rotrex charger setup hehe
    GGray's Avatar
    GGray is offline Did someone say racetrack BMW CCA Member
    Aug 2003
    Christiansburg,Va.
    A few BMW's...
    AN lines
    You can run AN lines from the tank to the fuel rail. But you will need a new regulator and fuel rail. I ran -6AN from the tank to the regulator and through the BL fuel rail. And through a new fuel filter.
    The -6 lines actually fit in the stock line holders under the car. So it looks almost stock
    Gary Gray
    If you can take it apart you can make it faster!
    Dec 2004
    Longmont, Colorado
    searching for a new one
    Many people are making 450 + rwhp with stock rail and lines, upgraded pump.
    -Dan D
    95 M3 White/Black
    A few bolt ons...
    08 Honda Accord Silver/Black
    EX-L 4 cylinder (wife's car)
    01 Pontiac Grand Prix GT White/Grey
    Daily Driver
    techno550 is offline Senior Member Supporting Vendor
    Nov 2003
    Atlanta, GA
    E36's + 300D
    Quote Originally Posted by Darth Maul View Post
    -ARP Head Studs
    18-20 psi.
    Quote Originally Posted by highboostingm3 View Post
    18 psi should be easy. 12 isn't impossible on stock compression and pump gas. (just not terribly beneficial compared to 9psi.)
    Most use a walbro in tank 255lph pump. They were discussing replacing the fuel lines that go from the pump to the fuel rail.
    Quote Originally Posted by GGray View Post
    Stock fuel lines are *close* to -6 anyway. (which is why they fit so easily.)
    (8/25.4*16)= -5 (dash 5)
    The flow difference between -5 and -6, a 16th of an inch difference in diameter, isn't going to shift the max flow point by tons.
    Michael McCoy TRM
    Feb 2002
    Ma
    Turbo 3er
    how much that turbo run you
    -ARP Head Studs
    E36 in pieces
    Jun 2005
    south
    85 318i
    Question about the GT30R at what psi does it become inefficient is it good for 30psi?
    My manifolds powering 8sec and over 1000rwp cars
    Home of the highest HP stock M30 in the world 550rwhp/622rwtq
    1/4 mile---> 9.81 @138 C4 Auto
    10.08 in car vid --->https://youtu.be/OiinFhUomjg
    Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
    Nov 2003
    Atlanta, GA
    E36's + 300D
    Quote Originally Posted by good & tight View Post
    that depends. at a PR of ~2.4 the map *ends* around 50 lb/min. At 2.6, the map goes to ~53 lb/min. At a PR of 3, we're back to 50 lb/min. The map goes all the way up to a PR of 3.4, but you're down to 40 lb/min by that point.
    so the *sweet spot* is the just-past-50 mark at ~23psi. It'll do 30 psi and flow just past 50 lb/min efficiently there.
    Michael McCoy TRM
    Phoenix, AZ
    how much are those walbro 255 pumps?
    fairfield, nj
    M3/4/5
    i think around $100-$120 if im not mistaken
    Jan 2005
    PDX
    E36/5 ///M & Turbo 325
    your stock fuel pump should be good for 400rwhp if im not mistaken
    OBD1 ECU TUNER
    Aug 2003
    San Diego,CA,USA
    1997 Turbo M3 Coupe
    I know somebody(non-bmw)ran it to 40psi and 540whp(Mustang) on 2.0L.
    Quote Originally Posted by techno550 View Post
    That is correct. He gets the pump and he is good to go.
    Phoenix, AZ
    So what's the most I can boost without the pump, even though I have the 42#'s. I'm picking my car up hopefully today, so just wondering about this.
    Aug 2003
    San Diego,CA,USA
    1997 Turbo M3 Coupe
    You can try for 18 but keep that wideband dialed in to see if your car starves for fuel anywhere in the rpm range. However, 18 should yield much more than 400whp and that is the amount people say where you should go Walbro if you want more power. So start at 13psi and keep working up until you see some lean issues and then back off.
    Jul 2004
    Pluto
    93 325iS
    I think mine was $100+SH (~$10) for a Walbro 255 w/ install kit (Generic kit) from Oakos.com. There are many places to find one for about the same price, but this one happened to have an install kit. And shipping was quick!
    Titus, have you finished up his tuning?
    How is she drivin'?!
    Phoenix, AZ
    Hopefully next weekend when I get my Porsche 993 TT HFM, Drove my car tonight, wow, it feels way better. I can't wait for the Dyno Tune, gonna try for 16 psi or so. Right now it feels fast and very smooth!!! Gotta get my Wideband O2 Sensor plugged in, Saturday i'll see what the AFR's are.
    Phoenix, AZ
    Sigma, you should make it to our HUGE Oregon Meet on the 30th!!
    Jan 2005
    PDX
    Thats great Tony. Didnt I tell you i would take care of it. Wait until I get my car running so we can dyno at the same time.
    Stay tune BFC member for VID and complete writeup, hopefully this saturday.
    OBD1 ECU TUNER
    Jun 2005
    NYC
    A Junky One
    Looks interesting
    Jan 2005
    PDX
    Quote Originally Posted by Black96m3 View Post
    Looks interesting
    Rmember, this is the TSI kit (the upgrader version-Extreme), with GT3076R internally gated running on DME tuning.
    OBD1 ECU TUNER
