I had an issue with my car running with the key removed. All of the people I talked to (EE guys on MSEfi.com) thought that I was getting feedback from the alternator over the +12v line, but I noticed the car has an uncoupling diode over the charge indicator line by default, so adding a diode would be pointless. So I just woke up and was about to add a seperate relay for the coils to see if it was coil related or main relay related. I was powering EVERYTHING from the main relay (LC-1, MS, Coils, Knock box). I was paging thru wiring diagrams this morning as I sloooooowly woke up after a concert last night and saw that the coil packs get their power from pin 56 (ign turn on) at the ecu, NOT the main relay as some people had suggested. So, I cut the coil packs +12v from the main relay, spliced into the Pin 56 (IGN Crank and Run) and presto, car shuts off with the key
Just a heads up for people doing more than the conventional install.
