ok so did a lot of thinkning and plannnig tonight. and came to the conclusion that i need to rebuild the motor now anyways. with a 147K on the engine its probably tired anyways.
so ive planned out:
CP pistons 8:5:1 compression
Cometic .70 headgasket
ARP Head studs
ARP Rod bolts
New bearings
new bottom lower gasket set
for the head:
new valve springs
retainers
keepers
have the head shaved for smoothness
have the block decked, bored and honed
after all said and done should have nice tight and new motor ready for new life.
at this point dont really care of the current state of the motor wheather its Rings, pistons, ring lands, or headgasket its all coming out for the new stuff anyways.
looking to finish this in the next 2 - 3 weeks.
many thanks to Charles AKA bassmaster for keeping me motivated and not giving up and for all his help.
care wil be back better than ever
your gonna keep the stock rods?
do you even know what a plethora is?
now how did i know that was the first question someone was going to ask.Originally Posted by ///M3 CRAZY
answer = yes
i beleive as well as others who have advised me stock rods will be fine. lotts S50's out there making good power on stock rods.
Join the club. I was wondering if VAC or another vendor sells a head component kit, including springs, keepers and retainers? Do you know of anything like that?
Steve
That sounds, well, expensive.
I'd at least do a leakdown test before jumping headfirst into a full on rebuild. But if you don want to rebuild one, I have a 'some assembly required' longblock for sale that will suite your needs if you want to minimize downtime.
SOLD -A dozen ///M3s of all shapes
lol yea sounds expensive but in the long run it will be worth it.Originally Posted by fritzintn
even if its just a headgasket id still like to go ahea and do all this at once for peace of mind and be able to run 20 psi and good tuning with no worries.
down time should only be about 2-3 weeks im not too wirried about that though as long as its done right.
i dont see a head component kit on their site but i see all the pieces you need its not really that expensive though for what you are getting.Originally Posted by slcook54
what are you doing to your motor while its under the knife?
Says the guy with 4 M3s, haha.Originally Posted by fritzintn
Steve
Depending on if the head is cracked or not, I might have to get a fresh one. Either way, same stuff as you pretty much, new springs, retainers, keepers and having it milled. Plus an MLS gasket and ARP studs.Originally Posted by CosmoE36
Steve
Thats a good idea, the dark side is calling Steve http://forums.bimmerforums.com/forum...d.php?t=489472Originally Posted by CosmoE36
Haha, not with this car, I'm done. Maybe with a project 2.8 in the future though , after looking at the springs I actually might skip on those depending on what others say. I think keepers, retainers and new valve guides should suffice.
Steve
Cosmoe36: Why are you rebuilding exactly? Is the car not running well?
EDIT: Nevermind, read your other thread just now.
-Curt
stock CR 92 non-vanos 325 / first ever Holset HY35 powered BMW / custom tubular manifold & motor mount / stock DME tuning / tial 50mm bov / 46mm xspower w.g. / green top injectors / IC piping designed by myself (above subframe of course) / 12x28x3" IC / oil return into pan that seems to work / e21 tranny mounts / custom blow through MAF / koni sport kit / 18x8.5 mvr replica's / various leaks & body colours
yea ive been wanting too for a while but didnt want to pony up the cash but now its unavoidable.Originally Posted by e36'n
time for change i suppose.
i was going to sell the turbo kit and part the parts on the car out and sell the car with the motor as is for significantly reduced price but after thinking things through i might as well just keep on going.
UPDATE
got the motor pulled last night and head separated. everything off to machine shop this week..
Thanx Charles!!!!! who is on his way back to NC. this man is hard core!! comes down after pulling a all nighter of work and gets my motor pulled and separated and heads out back home to NC this morining
pix here.
Sorry to hear about the motor. Hope all goes well with the rebuild and you can actually get it to run correctly.
2007 BMW 335i: stock for the foreseeable future.
BFC OT Cook Book 1st Editionhttp://forums.bimmerforums.com/forum....php?t=1035694
Originally Posted by Jeremy Clarkson
sorry to hear as well, my s50 goes in for a compression test tommorow as i think ive blow something and hopefully its just the headgasket.
Parts for sale anyone??
1995 M3 Custom Turbo, Turbonetics T66 BB,72lb injectors, Sias Tuning PnP Tec 3, IBM T30,PLX M250 wideband O2 sensor,Blitz SBC-iD Built low CR 8.5:1 motor CP Pistons,ARP head & main studs,Metric Mechanic HP Valve springs,walbro 255hp,BMP FPR,Modified fuel rail # 6 SS feed line,3in ss custom magnaflow exhaust,Lower level turbo intake,AA six puck disc, Spec Stage IV PP ,AA differential bracket,AA strut tower brace,UUC UD Pullies,UUC short shifter,UUC tranny mounts,UUC clutch stop,Fluidyne HP radiator.M3 LTW wheels Est..1001 rwhp!
Http://members.cardomain.com/bassmasterM3
(DIY custom turbo)
(DIY custom turbo)
(DIY custom turbo)
Hey cosmo, how much did the pistons+rings run you if you dont mind me asking?
Mods: Carbon fiber hood, headlights with angel eyes and 14000 Kelvin HIDs, blacked out/smoked tail lights and side turning signals, smoked front corners...and thats about it
Ohh...and some "bolt-ons" here and there........K&N air filter, m50 manifold, rouge trans mounts, a few V-band clamps, few silicon couplers....etc...etc....
http://forums.bimmerforums.com/forum/showthread.php?t=653809
i got them from vac website www.vacmotorsports.com for prices.Originally Posted by GodFather
Looking good! You move fast! Very excited for you going with 8.5:1CR and the rest of those goodies! You should have a 600whp capable car easily soon! So stoked to see you doing it! I really like your choices on mods! Very clean! Can't wait to see more!
