I finally decided to post up about my project in this forum as it is in full swing now. Car is a 1988 E30 M3 that I blew up at the track Easter 2005. Then it was a 2.3 litre stock motor. Great fun, but I wanted more. Thought long and hard about rebuild NA but as every man and his dog has done it, I decided to go FI route. I had to fight a few demons, both mine and others, in relation to going turbo on such a classic car, but in the end, its what I wanted. I know of only one other in Australia, and that’s a race car in my state. Perhaps Kenny may know of any in Sydney? Hopefully it should come together in the next 2 months..................hopefully.
*2.5 litre block.
*2.5 litre Crank.
*Verdi forged rods.
*95mm JE 8.1:1 CR pistons with high heat ceramic coated crowns and moly coated skirts.
*Head ported and polished.
*Cometic MLS head gasket.
*ARP head studs.
*ARP main and rod bolts.
*EVO III valve springs.
*TMS sump baffle.
*EVO III oil pump.
*Custom intake plenum.
*Custom made ceramic coated manifold and dump pipe.
*Custom exhaust.
*Garrett GT30R .82. Running 1.2 – 1.3 bar
*Tial 44mm external Wastegate.
*Tial 50mm BOV.
*PWR intercooler.
*PWR radiator.
*Motec ECU.
*Bosch 044 'Motorsport' Fuel Pump.
*Custom made surge tank.
*Delphi 780cc Injectors.
*Lightened Flywheel.
Cheers
Dave
Not long now.......
Sounds like it's coming together!
I'm confused as to the fuel setup, your using one 044 pump but are running a surge tank? no twin pumps?
Should be a track weapon!
Ben the S14 already has 2 pumps. I am simply replacing the main one with the 044.
Not long now.......
:Beautiful car....Originally Posted by DCR62
Great list. Post a picture of the e30 M3 (and e34m5 for my own viewing pleasure). Your cars are both very beautiful.
Current: 95 M3 Turbo | 08 335i
Step it up and pick up a GT35R turbo. It would be incredible on your setup. By the way gorgeous car!
-Julian
Sick! I'd go with the GT35R too, and a 38mm wastegate. Regardless, sick as heck, can't wait to see the build pictures and end result
I know a gt35 builds boost decently quickly, but on a high revving 2.5, worldn't a GT30R be perfect?
Not really sure where it will end up. I am new to this so I dare not try and guess a figure. Up until now I have only ever had NA cars. Maybe those with more knowledge could give that estimation.Originally Posted by VelocityM3
Thanks for that.Originally Posted by Eric BMW
I really want it to work well on the track though. So I will stick with the smaller one for the time being.Originally Posted by Julz69
I am hoping so.Originally Posted by Schneller Bayer
Not long now.......
Beautiful M3
Thank you.Originally Posted by BlackWolf
Not long now.......
I wet myself looking at your cars... I envy you. You have two of the best BMWs EVER built in your collection...
AC Type 2 3-piece it looks like.Originally Posted by CosmoE36
Sick cars BTW
And you need to post a video of it running. Dyno?
I'm a ROLEX wear'N
Diamond ring wear'N
KISS steal'n
WHEELIN DEAL'N
Limousine RIDE'N
JET PLANE FLY'N , SON OF A GUN!
And I'm havin a hard time holdin these alligators down!!!!!!
WHOOOOOO!!!!!!
your pictures are my new desktop!!
Please put up some more high-res pics of that M3. Thats my next car. beautiful cars by the way
Correct. 17 x 7 1/2" front and 17 x 8 1/2" rear.Originally Posted by KarlSpackler
Sorry I dont have any Hi Res shots unfortunately..Originally Posted by Julz69
Thanks everyone for the kind words.
Not long now.......
Here is a small video of it prior to the motor going south. It is still a 2.3 stock motor at this stage. Its one and only trip to the 1/4 mile. It was a charity day organised to help raise money for children with cancer. I suspect my next trip back maybe a tad quicker.......just maybe.
RIGHT CLICK AND SAVE AS
With a friends M3 CSL.
Not long now.......
A couple nice little packages today from Topend Performance. Excellent to deal with.
Cometic MLS 1.8mm Head Gasket, ARP Head studs and my Custom 95mm JE pistons. 8.1:1 CR, ceramic coated crowns and moly coated skirtks. I am expecting the 2.5 litre Motorsport crank from Fedex tomorrow.
cheers
Dave
Not long now.......
Looks great. With a build like that, I would fabricate an equal length split-pulse manifold and use a gt35R with ATP turbo's t3 divided exhaust housing in .78 A/R(www.atpturbo.com). If not, just use the regular .63 A/R exhaust housing.
Beautiful car!
97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
16 M3 - 9.3@151 - Built motor/twins
15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
BMW SOB's turbo E30 - 8.72@158.39
follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
I might go with the 0.63 A/R housing as well if you want as wide a powerband as possible, but if you're really zinging it up to the 7500-7700 RPM range then you might want to keep the big housing to let it really breathe up there.
The 30R should be good for a solid 400rwhp at the track on a reasonable amount of boost, and 500rwhp when you really turn up the wick(but I wouldn't try/want to track it at that powerlevel).
Well after a few weeks wait and quite a few dollars later, my crank finally arrived from Germany via Florida. Thanks to Don at McADAMS AUTOSPORT. I cannot recommend Don highly enough to do business with if you are after anything BMW. Cant complain the way it was packaged though. Packed like a true car nut, in a nice new Coleman Cooler. The Fedex guy couldnt help but laugh with me when I told him what was in it and the trouble Don had gone to get it here.
So only waiting on Turbo and few other bits and pieces and off to the engine builder it goes.
Cheers
Dave
Not long now.......
got a little negative camber?...lol
one of the best/cleanest M3's ever
BMWCCA Member 376052RIP Pandashizzle
