I am going with the .140" regardless, but I want to know how low it will drop the M50 non vanos since the non vanos is already 10.0:1 instead of 10.5:1 like other M5x motors
Using the spreadsheet that was made by two members a couple months back, I get 8.3969:1. That's assuming stock bore and stroke at 84/75mm respectively.
-Curt
stock CR 92 non-vanos 325 / first ever Holset HY35 powered BMW / custom tubular manifold & motor mount / stock DME tuning / tial 50mm bov / 46mm xspower w.g. / green top injectors / IC piping designed by myself (above subframe of course) / 12x28x3" IC / oil return into pan that seems to work / e21 tranny mounts / custom blow through MAF / koni sport kit / 18x8.5 mvr replica's / various leaks & body colours
Yeah 84mm bore 75mm stroke. 8.3:1 huh, sounds choice
Basically 8.4:1. How much boost could you run on pump gas (91 or 93) with that? What about using a 0.120" which drops it to 8.79:1?
-Curt
I want lowest compression possible. 8.4:1 is perfect. I am going to run ~9 psi daily and was hoping 18+ in high mode
lmao, that will change to 15 psi daily and 22 in high mode after a week.Originally Posted by UrineMachine
A word of Internet Forum wisdom: Disregard any advice that begins with "I've heard..."
97 M3/4 - S54, TRM Coilovers, UUC SSK/Sways/LTW Flywheel
Attached is the equation used for calculating compression ratio.
B=bore
S=stroke
Vc=Volume of combustion chamber, head gasket, volume from piston compression height to deck, and +/- any piston dish or dome.
Do people really have all this info somewhere? Because I really need it. If someone has all this info for these M/S5x motors, I will send you a present.
