Is this too big?
fix that ugly ass valve cover...
Sir, this is my mock up motor.
I've cleaned and painted some parts so far
The tubro looks good, and your brace makes sense. Can't wait to see it.
Will the valve cover be done too? Please?
Sir, I am happy to hear thatOriginally Posted by UrineMachine
Of course - thats my motor waiting build. Notice no crank
Ah sheit.. who needs a crank. Slap it together and run mad nos and boost yo
I don't know. For someone who currently has 2 cranks and is about to obtain a third one, I have a feeling you need a crank.Originally Posted by jrhaile
As for the bling blang, it should look great when finished. Now, is it just me, or is that motor mount bracket in the spot in which the AC would go? And no, the turbo is not too big.
Rob - 2000 BMW Z3 M Roadster | 1986 Porsche 944 5.3L LM4
Originally Posted by Robstah
Dude Robstah you made me panic. I actually got in my sisters 530 and drove over to our shop (2 miles away) at 1am here because I thought I had the engine mount bolted in wrong when designing the up pipe!!! I drove over and realized i left my 525i keys at home, so I got on the ground and looked up from under. No, the engine mount goes there on the E34. I think there are those other two holes behind (to the left) of the mount for the E36! Man I was panicked! I compared the mount on my engine stand to the mount in the car and they're in the same spot... whew!
Heh, too bad for you I didn't read this just after robstah posted. I would have quickly pointed out that the E34 and E36 use different mounting holes. (I had to make motor mount adapters for my E34 when swapping M20's. M20's and M50's have 6 motor mount holes, but only use 4 on a given car... and the motor I got to swap in only had those 4 used before tapped...)
You'll definately need to brace the turbo. Thats a HUGE moment on the flange on the manifold... and its an ssautochrome manifold that was doomed to crack/fail anyway. I'd hate to see the carnage of a hot live turbo bouncing around in an engine bay.
Michael McCoy TRM
Originally Posted by techno550
Well the heat of the actual turbo will be off of that manifold now, and I think I am going to brace it to the head flange studs. Should work out!
The turbo makes heat? I always thought the engine did that. You're mani will glow regardless turbo placement. I've seen five or so autorcrap manis that were braced to themselves fail, and a couple that didn't when the turbo was braced to the engine itself. Your plan should work out fine.Originally Posted by UrineMachine
edit: you should brace it down to the block too.
edit 2: here's a pic I sniped of what honda guys who are too cheap to shell out $$$$ for a good mani do:
Heat of the turbo?Originally Posted by UrineMachine
Michael McCoy TRM
Heat transfer through the turbo??!.......Originally Posted by techno550
damn, someone beat me to it..anyway.
that turbo..it's a bit small :P
will you be bracing the manifold and turbo? That piping is gonna get hella hot and red..how much does the tubo weigh?
No worse than heat transfer through anything else cast. with similar surface area. like say the stock manifolds.Originally Posted by and1c
Michael McCoy TRM
Sorry Jon.
Just curious, but where does the AC mount up to?
AC?
Does that answer that?
