As stated....I have my engine out about to be put into a shell thats not smashed.....and I'd like to put a new header on now while everything is pulled. It just seems like it would be so much easier to do this now as opposed to when the engine is in the bay and all installed.
headers on m42 you wount gain anything
My dyno charts show a 10 whp gain over a similar DASC setup M42 after I installed equal-length headers.Originally Posted by mischiefteck
Originally Posted by dallasfan824
where did you get the dyno chart from
The dyno place I took my car to and had it dyno'd on?Originally Posted by mischiefteck
www.dynoshop.com
The stickied "Dyno Sheet" thread in the E36 forum.Originally Posted by mischiefteck
http://forums.bimmerforums.com/forum...1&postcount=65
Originally Posted by TC535i
Wait, I don't see the dyno sheet with stock exhaust manifold- is it posted??
To be worth anything, your dyno runs would have to be done with the stock manifold and then with your headers- no other changes.
Stock M42 exhaust manifolds are about as good as they get in terms of flow. If you experienced a 10hp gain with headers alone- I'd like to see it.
Bret.
No, this was compared to a friend's baseline dyno when he just installed his DASC (he's gone to 11 psi since, piggyback, several other mods)... don't have it online, sorry.Originally Posted by Rigmaster
Sure. Is your TI DASC'd? Do you have a baseline dyno?Originally Posted by mischiefteck
No i havent dyno my car to many problems im using a eaton supercharger and are you still using the AFM or have you swoped to MAF
Running everything bone stock, 100% CARB legal. Eaton M62 s/c unit here, and the additional FPR DA supplies in their kit. Absolutely no tuning, stock ECU, etc... just the header, still have stock cat/resonator/muffler.Originally Posted by mischiefteck
couse i have othere car and it has 200k miles i been think if i should do FI
or keep it NA
After, I boosted my 318... I REALLY want to turbo my 535i. People are putting down 400whp and 350 wtq on 11 or 12 psi intercooled, stock internals...Originally Posted by mischiefteck
thats crazy i been saving up for a 350 swap
So what I seem to continue to hear is it's not worth it to tune an m42? I do have the option of picking up a cheap 6cyl from a 92 535, maybe it would be better to leave my m42 stock and just start building the 6. What is a 92 535i, m50? How are these engines?
yeah that would be best or you can buy a m44 head and build your motor
Only way to get power out of an M42 is gonna be boost. Otherwise, sell the car, and buy a 6-cyl.
buy one off ebay. They are supposed to be good but i will report back when i get the (used) one i bought.
What's the advantage of the m44 head on an m42?Originally Posted by mischiefteck
You're getting an m44 head or a 6cyl off of ebay?Originally Posted by nickmpower
im getting an m42/m44 header.
there is no advantage of an m44 head, there are however many disadvantages
