Actually me
My AA stage 2 arrived! I will be installing it this weekend. Very nice kit, Stimpee out did himself, Props to you buddy. I will be enjoying all your hardwork shortly, Thanks!!
JMC
Motor: Hurtig/AA custom 2.0l TS OBD2 AA tuned 444whp/384wtq SAE 470whp/400wtq STD
Exhaust RMS headers, Maximum PSI custom exhaust, magnaflow mufflers
Driveline E46 M3 6 SPEED, 2.93 LSD, Rouge SSK/tranny mounts, UUC Ultrasmooth /LTW steel flywheel. CDV delete, UUC clutch pedal bushings with GSP pedal
COOLING: Stewart WP, 78* thermostat, S54 radiator, Euro/S54 oil cooler, ES TS oil cooler adapter, M3 power steering cooler
HANDLING: MR M CAR SF reinforcement, TCK D/A CO 450/500, TCK Camber Plates, Rogue RSM, Ireland SFB, Dinan STB. CCW classics, polished lip, brushed centers. P295/30/18 P245/35/18.
THE SHOW: Stygar Z8 Nozzels, Leather Z armrest, Z8 push button start, chrome door handles, OEM FOGS, BMW Traffic Pro.
Monitoring: PLX Wideband, VDO vision boost/VAC both with custom chrome trim ring.
COMING SOON: custom intake
wow... such nice hardware, im excited for you
good luck with the install... and enjoy : )
07 MDX | 08 m3
1 friggen picture??? You stingy bastard!! I want a ride!!
For Sale- Infinity Basslink 2
Your a Jersey Guy, while settle for pics when you can come by some day and touch it!!Originally Posted by olsen185
JMC
+1Originally Posted by resisTm3
BMWCCA Member 376052RIP Pandashizzle
Thanks, yea AA's web page still has the prototype pics, it doesnt do the production kit justice.
JMC
Keep us posted. Unless something bad happens, then you can PM me!!
Have you been Screwed?
Hell if you need help with the install let me know. Once I get my tuning issue taken care of we have to run them to see the difference!!Originally Posted by jmc
Where in Jersey are you?
I am something under 3 hours from you if you need anything!
Steve
he'll prolly need a couple sandwiches
07 MDX | 08 m3
I love to hear your first impressions.. esp. from a former CF owner!
The hardware looks great! Please document the install.
Wow, looks very nice completed. I'm in New Jersey as well and would love to get a ride after you're done.
Wow thats a really well designed kit from the look. Really high quality looking pieces! The intake manifold looks bitchin!!
And this coming from a guy who hates SC's. But man Im a sucker for good mfg'g and those pieces looks good to me.
Looks like a great kit. I can't wait for the ES kit to be finished.
Impressive!Originally Posted by stimpee
"We are the music makers...and we are the dreamers of dreams."
Wow the kit looks really well done. Interesting though is that I thought it was basically the same as the Eurosport kit. It sems different thought. THe Eurosport kit seems to put the Twin Screw unit right against the head while the AA kit still has some type of manifold with runners and all. What are others thoughts on this?
For Sale, E36
92-95 Non M Airbag-$50
21.5# injectors(50k miles)-$60
Crystal Clear 4 door corners-$20
Grey 2dr C Pillars covers-$30
Grey Sunvisors-$30
Grey Sunroof Motor cover-$10
Grey Sunroof trim peice-#10
http://forums.bimmerforums.com/forum...d.php?t=566229
ES kit has runners too. In the pictures you see of the ES kit installed the runners are covered by the fuel rail and injector assembly, just as the AA kit will be. A big difference is the linkage from the TB to the intake of the TS.Originally Posted by PrestoMB
I see, so both kits look identical then?
For Sale, E36
Grey Sunvisors-$30
The one thing that stands out to me, is that the AA/Stimpee TS kit has a low level intake. The ES TS kit - uses what looks like the Conforti CAI kit.Originally Posted by PrestoMB
<img src="http://www.aatuning.com/supercharger/tse36m3/main1.jpg"/>
-Dave
That is true. Some of the reasons for that difference are outlined in one of the other semi-active threads on our kit.
The kits are of course quite similar, but certainly not identical.
Steve
Not identical, but remember there are only so many ways a TS/Aftercooler can fit into an M3. Basically, for all intensive purposes, one way.Originally Posted by PrestoMB
Look at the difference between the linkage to the TS intake. I know first hand that Josh had an engineer look at air turbulence and flow in his linkage assembly. A lot of work and R&D went into that piece alone. Needless to say, they should and do appear quite different. These are the this that will be different: the things that are up to the kit maker's design and not limited to practicality, tradition, and physicality of the design constraints. You have to have a charger connect to the aftercooler to the manifold and there is only one way to do this. This aspect will look the same on any TS kit. Just as all centrifugal and turbo kits have their similarities and differences from kit to kit.
looks awesome! i can't wait to hear the results. once you are up and running we should get tristate FI meet. there are enough of us around.
do you even know what a plethora is?
agreed.Originally Posted by ///M3 CRAZY
07 MDX | 08 m3
congrats!
-M3J0N
whats kinda of numbers are you expecting??
david
this looks amazing man
cant wait to see everything ni the right place workin proberly
update us step by step ...
good luck ...
salam ..
