So after pulling the OBDII error codes I finally found out the problem--a busted intake hose.
P1189: Pump Speed Signal Fault
P1188: Calibration Memory Fault
Before Pic
After
jk, I didn't really fix it that way. I bought a new hose from the stealer for $40.
Hmmm, now I replaced the intake hose and the check engine light is still on. Even after having the battery unplugged all night. Is there a way to clear the code? Thanks.
did you get your code cleared? I have the same code and actually my boot looks the same, waiting for the boot to come in. you can get your code reset at autozone. let me know if the boot fixed it
so where is this acutaly on the motor, and does it differ if you have an aftermarket intake.....because i have the same C.E.L code(p1188) and want to fix it.
Leaky intake boot will also throw up codes for pre-cat O2 sensors out of range, mixture adjustment out of range, airflow meter, etc, etc, etc. Amazing what a little unmetered air will do...
James Muskopf
RRT Racing
DC Metro's premier BMW service and racing facility
so the duct tape fix isnt acceptable, that what i used, it worked fine on my car
lol that's exactly how I "fixed" mine. But I used super glue first and then used the duct tape to cover the rip. Better get my replacement soon.
-2008 Mini Cooper S (4/30/2010- )
-2009 TSX (8/1/2009- )
-2006 Impreza WRX Sti (9/5/2007-8/1/2009)
-1997 Hellrot M3 (11/29/2006-8/19/2008)
-2003 G35 Coupe 6mt (03/27/2003-09/10/2006)
-2000 Civic Si (STOLEN)
-1995 325i (00-03)
TY so much for this thread!!!!!!!! i've had this for a while that i wanted to fix.
does anyone know a the part# for it because i want to order a new one instead of rigging it
is their a possibility of getting this code because of bad gas?
well the autozone guy told me to put some good gas in it and see what happens because the place where i filled up @ had questionable gas and it was my first time going there.
It seems they always say that.
What they won't do (at least in MD) is clear the code for you so you can test their theory. Why not get the codes cleared somehow and duct tape the hole closed before you plunk down $40. That is, if you have a leaky hose.
Thanks for this post. +1 on the cracked hose. I went out and looked and found duct tape on there from the previous owner where he covered up a crack.
ordered a new part from Pelican. Thanks again. Hopefully the 1188 and 1189 will go away!
1998 M3 Cabriolet (Estoril, Hardtop, Vaders, Dinan Stage 5, M50 Mani, Eisenmann Exhaust, UUC Pulley & SSK, Reiger Body Kit, 19" Staggered Axis Pentas, Momo Steering Wheel & Shift Knob)
2002 Audi S6 Avant, 2013 F150 Ecoboost (6"lift, 20" wheels, 35" tires) 2005 Kawasaki ZX-6R 636 (2 Bros Exhaust, Power Commander, Fender Eliminator, Flush Mounts, Throttlemeister, etc.)
Interested in using a Professional Fender Rolling tool w/ Heat Gun?. PM me for details.
www.TraysonsToybox.com
Sorry to bring back a dead thread but trayson I'm just wondering if the new hose you ordered fixed your P1188, P1189 and CEL? I'm experiencing the same 2 codes and will be checking the intake in the morning. I'm supposed to pass emissions by Friday so I've gotta get this figured out asap! Thanks
Cool thanks man hopefully that'll fix it I'll report back once I get a chance to check it out
GUYS! im kinda new to this site..The scanner originally gave me code P1188, so I looked around for any leaks and found a hole in the intake hose in so i used duct tape to stop the leak while I wait for the new one to come in but i am still having the same problem. Any other suggestions on things i can do before taking it to the mechanic???? plss
Did you get the codes cleared?Originally Posted by Jaymedina
