hello my m50 motor from a 93 325is with stick shift was misfiring in all gears from 1-4 except 5 it will rev smoothly. when i adjusted my foot on gas and played with the gas pedal i got some spots of smooth revs in gears 1-4. hmmm. the motor pulled stong in 5th but not in other gears unless you vary the gas pedal pressure playfully. I dont know what revs is all this happening because my instrument cluster does not work. I always have had a cel on that goes away when the car is idling and not moving for more than a couple of minutes. The idle is smooth and steady.Hello experts what do I do this car. and what is the causant of bad acceleration in some gears but not 5 gear? I tried the pedal dance to get codes.no good. cel just flashes and stays on. goes away after idling and non movement for a while. M50 experts please chime in. and any other non experts too.
Sounds like a missfire... What brand coil plugs do you have? Take off the plastic fuel rail cover (10mm bolt, 2 of them) then take off the big plastic cover that says BMW on it, which is also heard by 2 10 mm bolts. Under that you will see the six coils. On the coils where will be a brand name and a number. There is a company that bmw used to make coils on the early models that were bad. Forget the name. Bosch are the good coils, but they can also go bad. How many miles on the car and also what is the condition of the spark plugs?
Other things to think about is fuel, but that shouldnt set off a CEL light if the pressure is low or something like that on a OBD1 car. 02 sensor could be bad but it wouldnt flash the CEL, it would just stay on.
-Serge
Check the throttle position sensor. Disconnect wire & measure resistance as you slowly open throttle(engine off). Should have smooth change in resistance. If it jumps around or has areas of zero resistance, replace sensor.
yes i will take off the plastic fuel rail cover and check and also the big plastic cover.OK.Done. I have 2 coils that say Bremi 11856T Made in Germany 12.10.04 and 4 coils that say Zundspule M 91 06 and have the bmw logo part number is 2052.0110 002 on it. Bremi Coils are on cylinders 2 and 5 and Zundspule coils are on the rest of the 6 cylinders. I do not know the mileage of the car because the instrument cluster is not working. spark plugs are? cant pull them. My CEL does stay on!
I need to get that multimeter to check tps. Will buy one at radio shack tommorow.
Getting the car scanned would be great. Thats weird you have diffrent coils in there. I think the Zundspule are the early bad coils, but dont quote me on that. Ill search around and see what I can find. Do you have any repair records?
It indeed looks like the Zundspule are the bad brand of coils, and the bremis arent that good themselfs. Here is a coil resistence thread.
http://bimmerforums.com/forum/showth...oil+resistance
-Serge
Nope zero records.
thanks a million. how do i scan my car, right?
Thanks,Resistance will be checked tommorow when i get the multimeter. What brand of coils do you recommend?
Most shops can do it, Im lucky enough to know people and get it done free, so not sure about the cost. Usually they will charge an hour for diagnostics, not sure what the rate is in miami. It would probably cost around $100 to get the car scanned. But you can go to an auto parts store, here I know autozone has scanners that let you view codes. They are very general though, but they still do get the code. Not sure what auto stores you have in miami.
-Serge
OEM, bosch is the way to go. Cool, let us know.Originally Posted by miami325
-Serge
i will call autozone and other car part stores around here and ask about the scanners. Thanks
What place do you recommend for the coils?used or new?
Something like coils Id do new. Not sure about the best site. Pelican parts most always has some of the best prices.Originally Posted by miami325
-Serge
call up the people at bmaparts.com
hello
i called autozone and they have the obd2 code scanner but it doesnt read obd1. i found this adapter in ebay that could help me pull some codes look for obd bmw adapter in ebay. this site doesnt allow me to post urls
I called a shop and they told me its 40 bucks to pull some codes but they dont know if they have the obd1 20 pin for bmw. i will take it and see. anyone has a obd1 code scanner in miami,florida that could pull some codes for me.
Post here: http://bimmerforums.com/forum/forumdisplay.php?f=177 Its the florida part of the forum.
-Serge
thanks i just posted there.
Is your valve cover leaking?
"When tolerance becomes a one way street, it leads to cultural suicide."
i dont know where do i check on the front , left or right side or back? I would see black oil?or residue?
carfax says car has 143000 miles on 2003. 2 owners. 1 owner till 2003. 2nd owner till now which is 3rd owner me! nope I have no repair records.
There are these little rubber rings that keep oil from going into the spark plug hole. If that is leaking it can cause a missfire.
-Serge
so i check the spark plug hole?
hey could you check the carfax please post on page 2 of e36 forum and tell me where they towed it too. i dont know and cant check!
