I just got both warning lights over the weekend, and I was able to pull the code for the CEL:
SAE Code P0306
BMW-Specific Code 243
Description Cylinder 6 Misfire Detected
so I was going to check the spark plugs and connections in that area (from searches done in here that seems to be the common check) and see how that works out...
but I know that I can't do much about the airbag light without taking it somewhere, right? I don't have the airbag tool, and I don't want any problems if, God forbid, an accident were to happen. should I just have a shop check out both warning lights since I need (think?) to take it in for at least the airbag? or are there some tests that I could run for the airbag light (and is there a way to clear that, and would I have to buy the tool to do so?)
thanks in advance
Um well you have one of two choices, you can pay a shop to read the airbag code, or you can buy the tool to read the airbag code.
I bought the tool because after two resets its paid for itself and from there on you never have to worry bout it.
Peak makes a nice one for this.
My airbag light came on, the car was under warranty. The dealer did not have the tool. He sent it out for diagnosis, (Pass seat sensor code) and then had his mechanic repair the faulty passenger seat sensor. Unfortunity the diagnosis was incorrect, light came back on after reset. I got tired of going back and forth. I took the car to a small one-man garage who took the time to traced the issue to a $49.00 control module.
Who did you bring it to? Toyota?Originally Posted by chewytwo
Passenger mat sensors are pretty common to fail but I would have thought by 99 that it was rare. IIRC, early mats had a short wire and could easily break with enough weight on the seat.
...steven BMWCCA 146825
http://318ti.org | http://bmwcca.org/forum
1995 318ti Club Sport - 1996 328ti Sport - 1991 325iC - 2003 Mini Cooper S
Just in case you need to purchase the tool, we do carry it...
http://www.bimmerzone.com/BMW_SRS_Airbag_reset_tool.htm
Good luck
<center>
<a href="http://www.bimmerzone.com/" target="_blank"><img src="http://i1181.photobucket.com/albums/x430/bimmerzone/Bimmerzonec.jpg" alt="" border="0"></a>
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
