Hi Guys,
Many of you are already know of Craig's (Alpinewhite) Turbo 325i and his personal build up. First off, we must say that for a young guy that has never done anything like this before, the turbo build, Craig did a good job and admitted that he didn't fully know what he was doing but you guys gave him some great advice and it came out pretty decent. A bad turbo and H.Gasket brought this car into our hands after he dynoed here to see how his work did. Anyway, the build snowballed into one of our custom 3" exhausts, 4" lower intake and some other new plumbing on top of a new gasket, one of our mini fuel systems and SC61 Turbo. He is still on a very restrictive charge pipe and a BS Starion IC that is really jamming things up.
Anyway, here are the preliminary results on this new build We still would like to do the IC and IC pipes and a new clutch and we estimate we could hit 440's on this car safely.
As usual, Dr. Mo Powa will follow up on the Q&A portion.
Brian
- Brian Rosenberg
Very nice, Brian and George! Who may I ask, was responsible for those AFRs? Also, very nice..
Question: Dont the trq peaks on turbo cars usually occur alot lower than the ~5500 trq peak we see above? What accounts for your relatively elevated trq peaks here?
___________________
Paul E
'11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
http://s11.photobucket.com/albums/a173/boostm3/
Damn! JUST last night I was telling user DMB882 how I couldn't wait be the first one to use an SC61 and get dyno results! Haha, oh well, that's awesome! Great results from that turbo.
What were the specs on the turbo? and how many psi? etc?
Congrats!
Nick
Porsche Technician
1996 328is - |AFE intake|S52 cams|M50 manifold|Custom trackpipe|AA Tuned DME|Stromung catback|Fan delete|ASC delete|3.23 LSD|MZ3 Shifter|Sparco Front Strut Bar|Powerflex FCAB, RTAB, and subframe bushings|RE clutch stop|RE Transmission mounts|LTW5 17x9 wheels|245/40 tires|Bilstein BTS kit|HID Depo's| -*SOLD*
1995 Turbo M3 - 405/395 at the wheels - *SOLD*
Its a 325is BMW little motor all stock internals, the 406rwhp run I made half way through the run b/c the cltch was starting to slip.Originally Posted by paul e
325is low compression gasket, stud kit all stock internals, 3 inch turbo back exhaust, SC61 .63 housing ICS custom 4 inch lower intake, intercooler is a pile of shit, Starion VERY RESCTRICTIVE intercooler, and charge pipe, new revision intercooler and charge pipe should.... be around 450rwhp.Originally Posted by Goofynick6
psi? tuning?Originally Posted by IMPORTEDCARS
A word of Internet Forum wisdom: Disregard any advice that begins with "I've heard..."
97 M3/4 - S54, TRM Coilovers, UUC SSK/Sways/LTW Flywheel
What the f*ck...
How do ya guys get all this damn power outta these motors....
oh well lthat is why ya make the big bucks
Damn nice plots and afrs.. congratsOriginally Posted by IMPORTEDCARS
___________________
Paul E
18 psi spike holds around 16.8-17psi AA tuning.Originally Posted by Shuasha
Damn it you guys!
One nice car after another!
I can't imagine the contrast between the stock 165 whp and this...
Not bad for a 2.5
Stock motor with 108k on the clock 1994 325is, the turbo seems to pull good all the way through. The intercooler is definately a handicap in this set-up.Originally Posted by CosmoE36
Wow nice #'s! How about some pics???
Very nice ICS!
Bayerische Motoren Werke
damn that awesome! i think m50 and m52 are perfect for a turbo set up... good stuff. s52 is meant for all motor/twin screew.imo..
Car Isn't pretty yet, came in w/no nose.Originally Posted by eurotekm3
Brian
- Brian Rosenberg
Those AFRs are pretty rich with 11:1 for most of the powerband. Lean those out to 12.5:1 and you'll make even more power.
Car is not even finished yet, A least be happy that the 325's are making headway, dont be a hater.Originally Posted by carnewbie
No hating here. You know me better than that I hope George. Just offering an informed observation.Originally Posted by IMPORTEDCARS
ICS has been known to only publish completed products. This recent build has differed from that pattern. I only want the public to know that there is even "Mo Powa" to be had here.
Congrats on the numberz, looks like its not a bad idea to get a 325i sleeper nowadays.
― George Orwell
I know.Originally Posted by carnewbie
My little 325 has potential after all....
OBD1 ECU TUNER
A nice intercooler charge pipe, stock M3 cams and some boost and race fuel, am I hearing 500rwhp?Originally Posted by dredder
That would be a very good way to go BOOM. Would love to see the EGT's with a 12.5 AFR on pump gas. LOL.Originally Posted by carnewbie
Chad Charlton - 913-207-6539, cell phone
www.mkcperformance.com - 913-432-8468
Hot Rod/Pro-4 Honda CRX - 9.51 @ 155
Pro Am/SFWD Honda Civic - 9.896 @ 139; Best MPH 151
DD Evo 8 FPRed E85 - 11.751 @ 123.79 ~ 440whp/380wtq
Drag Evo 8 - have motor need cage work
Originally Posted by kcevo
12:5 is the most optimal AFR for a forced induction application. You foget this car has a lowered compression with the .140 " headgasket?
Do some research before you make another ignorant post.
