So it's about time for the coolant hoses to be replaced. Since a few were soft, I figured I might as well replace all of them on my 11 year old car. Here's what I'm thinking of buying online. Can someone let me know if I'm missing something? Or if I should replace anything else while I'm at it? (I'm also planning to replace the thermostat housing with an aluminum one.)
http://realoem.com/bmw/showparts.do?...42&hg=11&fg=35
01. 11-53-1-708-499 Upper radiator hose
02. 11-53-1-726-344 Lower radiator hose
06. 11-53-1-738-053 Coolant distribution hose
07. 11-53-1-730-351 Reservoir to coolant distribution hose
14. 13-54-1-735-173 Intake temp sensor to engine
15. 13-54-1-735-174 T/B to intake temp sensor
http://realoem.com/bmw/showparts.do?...93&hg=17&fg=05
19. 17-11-1-723-521 Radiator to reservoir hose
http://realoem.com/bmw/showparts.do?...26&hg=64&fg=18
04. 64-21-1-394-293 Engine to water valve
05. 64-21-8-391-240 Engine to heater radiator
06. 64-21-8-391-239 Eater valve to (A/C?) radiator
Thanks, guys.
Maybe this diagram will help, although you probably already have seen it.
http://www.realoem.com/bmw/showparts...89&hg=11&fg=35
I am thinking of doing all the hoses on mine, but some of the hoses look very tough to get to, possibly requiring that some stuff be taken apart in order to open up space in which to remove/replace the hoses. To anyone who has replaced all of their cooling system hoses: Is it necessary to remove any parts in order to open up space in which to remove/replace the cooling system hoses that lie more toward the inner/back top rear of the engine? If so, then what are/is the best thing(s) to take apart in order to open up the space necessary to remove/replace these hoses with minimum trouble/time/effort?
If I knew more about how my car is put together, I would be able to answer this question myself, but since I don't the advice of someone who knows would save me a lot of time and trouble. Thanks, any help if much appreciated
You link is almost exactly the same as my first link. Thanks for the thought, though. I appreciate the effort.
As I understand it, the intake manifold and everything upstream needs to be removed, so a couple of gaskets will need to be replaced along the way.
I haven't decided whether to do it myself, but, either way, I want to buy the parts myself to save a couple of bucks. I can tell this is going to be one of those "fun" maintenance jobs.
The reason I haven't done this yet is removal of the fuel rail. I'm so afraid I'm going to cause a vacuum or fuel leak somewhere with all those old O rings and seals that I will be disturbing!
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
This is exactly the type of thing that I want to be aware of before I start trying to replace these hoses. Can anyone who has actually replaced the less accessible hoses that you would need to remove parts in order to access chime in with some insight?Originally Posted by stradmaster
There must be something wrong with the ETK. I ordered parts #4 (64 21 1 394 293), #5 (64 21 8 391 240), and #6 (64 21 8 391 239).
This is what I got. WTF? Two of the parts don't match up with the diagram (and my car) at all.
Here's an update with all the parts I used. I also included some extra if you want part numbers/etc for the other coolant-related stuff.
EDIT: Forgot to mention that the ETK lists the wrong numbers for the heater valve hoses. Maybe they're for the Euro M3 engine? Mine is the US S50 engine.
Hoses:
* THESE ARE WRONG *
05. 64-21-8-391-240 Front water valve outlet to heater radiator
06. 64-21-8-391-239 Rear water valve outlet to heater radiator
* THESE ARE RIGHT *
05. 64-21-1-387-424 (Use part from 325is)
06. 64-21-1-394-292 (Use part from 325is)
Radiator:
01. 17-11-1-728-908 Radiator
03. 32-41-1-093-596 Washer for fan temperature switch
Thermostat:
http://realoem.com/bmw/showparts.do?...03&hg=11&fg=35
01. 11-51-7-527-799 Water pump kit
04. 11-53-1-722-531 Thermostat housing
05. 11-53-7-511-083 Thermostat (92C)
06. 11-53-1-265-084 Thermostat O-ring
08. 11-53-1-740-437 Thermostat housing profile gasket
ex-1995 Cosmos M3 Coupé - deck spoiler / koni struts + shocks / x-brace / clears / unstaggered contours / yokohama avs es100 / alu thermostat housing / emp water pump / porterfield r4-s pads / gc rtab shims / bavauto ss brake lines / fdm / ie rsm plates / kicker sub + box + amp / sylvania silverstar lows / lamin-x / loc-tite'd opn / lots of refurbishing
Retired - mason strut brace / jl stealthboxes / tms chip + hfm / s&b filter + outerwears / ecis heatshield / alpine 9835 + aux
E36 ///M DIY & Tech - Door Handles / Underpanel / Coolant Hoses / Gear Ratios / 3.5" Intake / Lower Chain Tensioner / Threaded Starter / IAT Sensor / 24# Injectors
wow there are a lot of hoses in that system
Mods: Built s52,bored to 87.00mm,cp 8.5.1 High Comp Pistons Arrow h-beam billet rods,arp head studs,mls head gasket,combustion area polished, Complete Ferrea valve trainw/stainless 1mm oversize valves, titanium retainers, HD springs, hardened keepers Shrick cams. RMS Stage II Supercharger/Intercooler w/8 Rib pullys. RMS High Flow Fuel Pump, Porsche 803 MAF, Clutchmasters FX300. UUC v3 ssk,Koni sport Suspension, 17x8 BBS RC's. Wilwood Superlight 4 whl BBK. GC bump stops, Welded subrfame & sway bar reinforcements, strut tower reinforcement plates, Rogue RSM's, Every powerflex bushing, UUC red's with enforcers, Eibach swaybars, Mayle c/a's w full metal ball joints, Zionsville Competition Radiator kit, Samco hoses, RMS Headers with 2.5in midpipe,Supersprint Catback Exhaust, ZKW w/ FX-R 35W 6000K, Alpine HU, hardwired V1. Illuminated shift knob. HK 6x9's. Motion Underpanel. Stack Gauges.
hey man i dont want to flame on you or anything cuz you are just looking for some help but you might get more results under the "M3 Series (E36)" section rather than this one the non-m section. If I knew about that stuff id be all over it to help you but I havnt done any of that yet so im no help...
M42 Club Member # 102
what is the standard for replacing hoses? is it with age or mileage or ?
It's mostly a matter of time. I've heard suggestions to change all under-hood hoses every 4 years, but it seems like most people only change the upper and lower radiator hoses when they break. I went hog wild and did everything because the car is old and it's already a lot of work to get the intake manifold off.
i have a 91 318i sedan and need info on those hoses.
I'm changing the intake hose under the manifold and the part numbers on the diagram are all wrong. anyone have an updated list of part numbers and diagram for the hoses on the 91 318i sedan
you can send them off list if possible to brian@ispgroupinc.com
I have a 1995 318i sedan and it keeps running hot. I've replaced the radiator, water pump, thermostat, upper and lower radiator hoses and it continues to run hot. I'm concerned that I need to replace the head gasket and have the head checked while it's apart. Any suggestions before I pull the head off, as to what you might think the problem is? Also should I have a compression test done to rule out the head gasket or warped or cracked head as the problem? If you like to email me direct I can be reached at alweems1@gmail.com
Is it best to use aftermarket hoses or stock?
Seen this aftermarket coloured hoses, blue, red. But only for over and under radiator, looks nice.
* THESE ARE WRONG *
* THESE ARE RIGHT *
Radiator:
Many, many thanks!! I could not figure out what the heck was going on! I've had my 98 M3 torn down to replace the freeze plugs on the intake manifold side and wanted to replace every hose while in there since it is such a job to take apart. I could not figure out why ETK's part number looked entirely wrong.
Now maybe I can get this thing back together and start driving her again!
Jerry
95' 325i
