to say the least i was and am pleasantly surprised..
my set up:
started with my 3.2 @ ~230whp added a powerdyne blower, water injection and NickG's (remote) magic for now.
my numbers:
florida's sun index: 86f
whp- ~292
wtq- ~245
3 lbs of boost (only )
afr 10:1 which explains the low torque numbers, for now until i get to go down and visit with Nick next week.
conclusion: Nick knows his shit..
-zkw- -hella- -bosch- -depo- -prolumen- -kwd- -bbs- -predator chromium- -predator ice- -simota- -ecis-
//-install guides-//-total lighting group buy-//-zkw group buy-// -exhaust group buy-//-ellipsoids+hid group buy-//-led tails group buy-//
What!? You made 292rwhp on 3psi of boost?
Steve
barely 3lbs, just barely.Originally Posted by slcook54
Thats aweome...those are numbers for a stage one vortech or rotrex at like 7 psi...wow, very impressive habbie...3 lbs of boost.
i find it difficult to believe since most powerdyne units are making those #'s with 8psi.
do you even know what a plethora is?
must be the MA bug going around....Originally Posted by ///M3 CRAZY
thats my story/numbers and im sticking to it.
Yeah, sorry, but I'm with Drew . How did you monitor your boost via a boost gauge or did the operator run a line?Originally Posted by ///M3 CRAZY
Steve
Let me first say, I am not doubting this for second ... I have seen Nick's work on others' cars on here and he does know his work very well.Originally Posted by habbie
But, making almost 300rwhp with only 3 pounds of boost and no other motor mods?
Are you sure your boost gauge is reading correctly? Maybe you have a line loose? It probably should read 8 pounds and it's only reading 3. 300rwhp on just 3psi just doesn't make sense whatsoever.
boost gauge.Originally Posted by slcook54
You could possibly have a leak in your line running to your gauge.
Steve
engine puts out lots of compression, m50 manifold, aa exhaust and that's it.Originally Posted by Armo95
first run:
let me also say this was meant to be a prop to Nick and his excellent work, lets not turn this into a mud slinging contest.
Talk about being rich... My guess a severe leak somewhere and your gauge is off, maybe in the vac line to the gauge. There is no possible way you can hit those numbers on 3psi boost, unless you have a V8 sitting pretty under the hood.
maybe but i doubt it.Originally Posted by slcook54
Habbie's got a really weird setup, as his motor has super-duper high compression (250+psi cranking compression), so it got a REALLY conservative program initially to keep the engine alive (extra rich and retarded timing). Obviously habbie's car needs more tuning, and that will be done next week. I'll see for myself what the boost is and what this puppy can put out.
Nick Glantzis
2005 330i ZHP auto with Technique Tuning turbo kit (currently For Sale)
I don't think they even make a 3# pulley.
250psi I think is greater than 11 1/2 to1 lotsa milling to that head I guess
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
3 psi -> 60 rwhp, 1 psi = 20 rwhp increase...
but then if I think about my car,
10 psi -> 270 rwhp, 1 psi = 27 rwhp increase...
i guess it could be possible.
2008 X5 4.8i
2003 330xi -sold-
2001 X5 4.4i -sold-
2001 M5 -sold-
2001 M Roadster (SCed, Highly modified) -sold-
2000 M Roadster -sold-
1995 325is -sold-
I doubt that boost is a linear value. Nothing with adding hp is.Originally Posted by bimmerpwr
I would advise that everyone hold their skepticism until Nick can see the car in person and give the final results and his impression of the setup.
What Habbie didn't tell you guys is that his motor isn't stock, it was built (to what extent, I don't know) at one point by the previous owner and is thus a mystery motor with extremely high compression and there is another credible vendor on this forum that can vouch for that.
So let us allow our resident Tuning Messiah to finish his magic before we begin to declare war on Habbie.
Hey man, I'm a professional!
250+ psi of compression! Schnikes! You probably don't want to run more than 5-6 psi tops anyway..haha. Is the engine built somehow to be that way?
Porsche Technician
1996 328is - |AFE intake|S52 cams|M50 manifold|Custom trackpipe|AA Tuned DME|Stromung catback|Fan delete|ASC delete|3.23 LSD|MZ3 Shifter|Sparco Front Strut Bar|Powerflex FCAB, RTAB, and subframe bushings|RE clutch stop|RE Transmission mounts|LTW5 17x9 wheels|245/40 tires|Bilstein BTS kit|HID Depo's| -*SOLD*
1995 Turbo M3 - 405/395 at the wheels - *SOLD*
Sweet!!!! High compression plus boost!!!! Last time I rode in something like that it was a Civic with a fully built Type R motor and turbo....geez that was a fun 500WHP ride.
Kudos on the power! Now get that thing tuned!!!
Riaz
Although I cannot confirm what Habbie's ACTUAL boost level is, I know enough about the car and the motor to be confident that it's output is likely to be a bit of an anomaly compared to what we are used to.
Let Nick get done with it, and confirm the boost, and then there will be no remaining questions.
But, in the meantime Ouri:
Steve
Have you been Screwed?
Habbie any news??
95 M3 stock
2002 gtp 7psi
97 328 stock
1972 Mach1 boosted
I'll let habbie chime in if he wants to post the results. But in the end, we retuned it and got a nice fat, even powerband
Nick Glantzis
