well im finally getting near completion.
needless to say im getting really excited. even though im going slower than i thought and wanted im ok with that. as long as i make sure i get things done right
heres the list so far.
Turbo - Garrett T3 60-1 T04S .63 - $645 shipped http://www.honda-tech.com/zerothread?id=1351135 http://www.kineticmotorsport.com/
Manifold - Spa Racing - $415 purchased from BFC member Techno550
Intercooler - Spearco 24x10x3 Bar and Plate - $250 purchased from friend who went bigger was bought on ebay for $300 originally
Wastegate - Spa Racing 38mm Big gate - $340 - purchased from BFC member Techno550 again
BOV - HKS SSQV $133 purchased on honda-tech slightly used for 3 weeks
Motor mount - Cartech - $150
Injectors - Ford motorsport greentop 42# - $210 - purcahsed from goofynick - can also be found on ebay as well as http://www.kineticmotorsport.com/cat...tor-p-129.html for 42.50 each 6 for 255 dollars
Sparkplugs - 2 sets 1 step colder 7 series NGK4091 and 2 step colder 8 series NGK4554 - 7 series set of 6 - $11.97 8 series set of 6 $12.97 www.barnettperformance.com local performance warehouse, much cheaper than www.sparkplugs.com
Gauges - 2 1/16 CF Boost and CF Oil Pressure - boost - $56.88 - oil pressure - $63.88 - www.barnettperformance.com
2 pod pillar 2 1/16 - 21.99 - www.barnettperformance.com
Oil Feed lines - Earls and Russells -3an fittings and SS lines with 1/8npt - $92 - www.barnettperformance.com - 3 way fitting and oil feed adapter where stock oil pressure sensor goes with two 1/8 npt outputs and 1 M12x1.5 output for stock oil pressure sensor - $15 - BFC member techno550
Oil Drain lines - Earls and Russels - 10an Fittings and SS line w/-10an Oil pan fitting - $53 - www.barnettperformance.com
Wastegate and MBC lines - -3an fittings and -3an SS lines (dont want any rubber lines melting from the wastegate since its so close to the exhaust area) - $47 - www.barnettperformance.com
Total = 2537.75
Downpipe
4 bolt flange - www.atpturbo.com - 25.00
4 bolt gasket - www.atpturbo.com - 8.00
2.5-3.0 inch exducer - 15.00
o2 sensor bungs - www.atpturbo.com - 5.00 x 2 = 10.00
o2 bung plug - www.atpturbo.com - 4.50
3 inch U bend - www.atpturbo.com - 30.00
3 inch x 6 inch flex pipe - www.atpturbo.com - 36.00
Total = 128.40
Intercooler piping
Hotside - 2.5 inch universal Aluminum pipe kit - 135.00 shipped http://cgi.ebay.com/ebaymotors/2-5-I...QQcmdZViewItem
Coldside - 3.0 inch universal Aluminum pipe kit - 135.00 shipped http://cgi.ebay.com/ebaymotors/3-Int...QQcmdZViewItem
Silicone Hump connectors
2.5 inch hump connectors - 12.00x3 = 36.00 www.atpturbo.com
3.0 inch hump connectors - 12.00x3 = 36.00 www.atpturbo.com
2.5 in- 3.0 inch transition - 17.50x1 = 17.50 www.atpturbo.com
Tbolt Clamps
3.25 inch clamp - 3.75x6 = 22.50 www.atpturbo.com
2.75 inch clamp - 3.75x6 = 22.50 www.atpturbo.com
Total = 404.50
$3070.65
PnP TEC III - $2000 dollars
so far sitting at $5070.65
Then add a UUC Cerametallic Clutch and Pressure plate - 688.00
Total with everything AND clutch $5758.65
got quoted on a full 3 inch exhaust from downpipe to muffler with all flanges and O2 sensor bungs for 700 dollars with me doing nothing(good price in my opinion)
so when all said and done everything finished i wil be sitting at 6458.65 including full stand alone tec3
take away the tec3 and the entire kit sits right at 4458.65
in my opinion a pretty good price for full kit which still includes a clutch kit, full exhaust, gauges and all SS lines and great quality parts that can make over 400 hp.
and now for the pictures
All going on this dirty baby
I wondered about mixmatching spark plugs....don't you suspect any problems? Why not just run all the same plugs?
1997 Arctic Silver/Black M3
1999 Techno Violet/Dove M3
Originally Posted by BMWManiac
im not mixmatching.. i got 2 sets.. 1 step colder 7 series and 2 step colder 8 series so when i go get tuned i can try both sets out with various gaps from .28 - .32 and see what best works for me.
they say for every 100 hp go one step colder than stock.. well my goal is 400 hp and thast over 100 but not quite 200 hp over stock so i just got both sets and wil try 7 series first and if i need to ill take them out and try the 8 series..
once i find the heat range plug i like and proper gap i wil drop some money on the Denso iridium plus in whatever heat range i need.
nice setup and good luck. Are you installing all your self?
NICE!! great job! thanks for the write up! keep us posted on the progress.
-jon
-M3J0N
Nice setup.
How much space is there between your dump pipe and the area where your downpipe is supposed to be? I know w/ my GT35R there is almost NO space between them. Its gonna be a close fit.
M3 Sedan Club President #21
Also,
Are you planning to run stock compression?
I think your oil drain is a bit too short .
SOLD -A dozen ///M3s of all shapes
Originally Posted by RRdawho?
yea its kinda close but i know it will fit with the DP.. i might not be able to go with the 4 bolt to V band adapter flange and just go wiht a standard 4 bolt flange we shall see.
and yes planning on stock compression. id like to see where i get with this setup first before i start tearing apart the motor..
figured someone would catch that lolOriginally Posted by fritzintn
i am definately cutting the line shorter when i test fit the turbo on a mock up motor with oil pan i was just foolin around with that -10an hose end fitting on the end of the drain line because one hose end is earls and the other is russels and i wanted to see how much harder one was over the other to thread onto the SS line. turns out its about the same hardness i stil got blisters on my hands lol
tuning? tuning? tuning? tuning?
u kno thats what we want to kno
What is the Diameter of the 4 Bolt? 2.5 so it fits the SPA Downpipe or larger?
Originally Posted by turbospool
im really leaning towards the PnP E manange ultimate offered by MA right now but i came across a great deal on a AEM 1050U box from a honda friend of mine for 1000 dollars barely used.. so all i would need is a C2DI box and custom harness form the 1050 box to the 88pin DME ive been talking to someone about making the harness for me and setting the 1050U box for me with a flat price
and with everything i have priced together for the AEM setup going my route i am saving a considerable amoutn of money over the evosport kit (not saying its bad) im just always open to cheaper alternatives even if it takes me longer to get there because if i had the money right now i would get the evosport kit no doubt..
tec3 is still in the air.. has a great pric for their PnP kit from Sias tuning so those are my 3 options..
well there are 2 types of 4 bolt turbos. ones with 2.5 in outlet and ones with 3 inch outletOriginally Posted by RRdawho?
i have the 2.5 in outlet yes the SPA downpipe would have fit perfectly but its 2.5 in all teh way out.. i want a DP that is 3 inches all the way from the flange..
nice, how much have you spent so far?
that would be great if you listed where you bought each peice for the kit
04 M3 Coupe Current///97 Civic HX (DD) Current///08 Ducati 848 Pearl White Sold
///00 323i Sold///02 RSX Type S Sold///99 996 C2 Sold///01 996 C2 Cab Sold
///01 325ci Sold ///98.5 M3 Alpine Sold ///95 M3 Cosmos Sold///90 Accord Sold
Originally Posted by Bm3R
updated my first post for your request.
it was at this point i just realized and noticed my magical paper with price list with everything i had planned out and marked as gotten and not gotten yet.
i must have left at barnett performance wen i left.
keep it up, cannot wait to see how it comes out. i too am slowly collecting the parts for my car
M52 Power! 500whp?, ? ft/lbs
Mods:8.5:1 CP pistons, Eagle rods, S52 cams, M50 intake manifold, Eurosport High Performance underdrive pullies, 3.23 lsd, ZKW's w. DDE, BBS RC's 18x8.5, Bilstein sport shocks, H&R sport springs, Eibach sway bars, BMW Motorsports x-brace, pwr 57mm rad, stewart high performance water pump, 6000k prolumen hid's, m tech kit
custom turbo: sias tuning tec3, t67 ho, spa turbo manifold, 24x12x3 ebay intercooler, 750 cc low impedence injectors, arp head studs, walbro 255 fuel pump, aeromotive fuel pressure regulator, hks ezII evc, tial 50mm bov, tial 40mm wastegate, plx m250 wideband o2, cartech motor mount, turbowerx oil scavenge pump, spa gauges
Similar setup to mine except mine has thicker headgasket, arp bolts, new exhaust manifold studs and nuts, bigger turbo and a cartech engine mount. I changed the valve cover gasket, spark plug gaskets and stuff too while I was in there.
What kind of power gains are you aiming for? How do u plan on doing the intake side w/ the stock engine mount? Oh and bolting on the SPA manifold is going to be a B*TCH with the head on. It was already time consuming with it off
Good luck!
i forgot to mention i am purchasing the BOOST LOGIC motor mount that clears 4 inch intakes.. only 150 bux..Originally Posted by RRdawho?
or i might have techno550 fab me up one for a price ifs he up to it since hes local he does great work.
i just picked up a new oil pan gasket so when i take the pan off to tap for return line ill have a new gasket there..
i always make trips to my local stealer for little things like gaskets i just didnt mention them in my prices lol figured they were minimal and a give in.
They do add up, trust me
Keep a tally of your costs please. I want to know how much DIY's are dishing out for these turbo kits.
Originally Posted by Julz69
i did look at my first post..
i did NOT include any costs on gaskets and such mainly because when you buy off the shelf kits you dont get any of that stuff either..
also i included price of clutch, PP and flywheel kit but that should NOT be tallied into the cost of what i have spent for the turbo kit because as i said before i dont see any other Turbo kit out there that includes a full clutch kit as well.. AA, TT, TSI, Boostlogic, MA ect.. none of them include clutch kits so why should i u know lol
I seeeeeee you.
So this time you are going to get the " 0 BOOST " in the E46 M3.
Congrats
Nice Kit
BMW-PC F80 M3 HotLap │ Formula 1000 Video │ 3 Time NASA-SE GTS2 Champ │ TRM Stg.2, Coilovers & Tuning │ Racing Videos[/CENTER]
Nice to know you bought some of your things from kinetic.
Kinetic Motosports is just a skip and a hop away from where I live.
That's where I got most of my stuff. I know the shop owner.
Shawn. He's a great guy and knows his stuff.
In the first picture of this thread their is a line coming off the turbo going towards the top of the picture (the thin one), is it the oil feed? And why is the oil drain hose so long? And where are you going to tap in for an oil feed? Sorry im a newb. thanks
