Works well when not used (default's to open) with the 3:91 diff.
Nice linear power band and increased H.P. past 3g's without the transition lagg it causes (4-5g's) when used.
Problem is it through's a Cel while disconnected.
Anyone know how to fool the ECU? Or if all I have to do is block the vacume line? Remove the butterfly?
Huh what are you talking about? DISA???? Whats that stand for ? Not familiar with the term.
Duel Resonance Intake System.
It is a butterfly system that switched from longer to shorter intake path's in 4 bangers.
Longer = better low end torque
Shorter = more high end H.P.
Although I think I already have my answer from a fellow BF member (bimmer95). ECU only.
Awsome thanks Had no idea what that was And now that I know I dont think I can help you But thanks for the enlightenment.
