Results 1 to 25 of 33
Thread: Getting tired of DDE problems...
    Dec 2004
    Snohomish, Wa
    1996 328is CBR600F4i
    Ok, off and on my DDE's would come on, come off, be dim, be bright, etc.
    Now tonight the whole driver side doesn't work any more. Which means i have to buy ANOTHER ballast from Umnitza. So i disconnected the other side so i dont look like an idiot and for some reason the euro city lights come on? And now my passenger side high beam wont work, I dont think I have the wire wrong.
    What else can be wrong with my DDE's? Would it be that bad of an idea to upgrade to Predator Chromium (new DDE) if it's more reliable?
    PS: What is teh difference between Predator, and Predator Chromium exactly? Just brighteR?
    Jun 2004
    Lafayette, California
    E36 325is Bmw
    i feel you on the dde problems and i got my shit from umnitza too
    Dec 2004
    Snohomish, Wa
    did you have to replace ballasts or what to fix them?
    Dec 2002
    Calgary, Alberta Canada
    BMW e36 320i
    sounds like your ballast
    sucks that you have to fork up more $$ to replace their products that dont work properly
    Alberta's BMW enthusiast forum.
    -Projecttechnik.com
    Jun 2004
    E36 325is Bmw
    no i just let it be. its irratating, i thought they were tight. now they just embarrass me on the road.
    Oct 2002
    Buenos Aires, Argentina
    5/94 Euro 325i coupe
    So some neon DDE would be more reliable... even if they got cracked with the shaking of the roads, they would still be
    Quote Originally Posted by ClintonM3 View Post
    the Audi A4 is a tweaked, cosmetically enhanced, cross platform, put-together overnight VW.
    Quote Originally Posted by joeuser528e View Post
    Staggard setups are for cars that you park at show meets. They go well with 5 screens and 3 12"s.
    Mar 2004
    Napa Valley, CA
    01 540i/6,02M5,99M3,72E3
    Um your DDE's have ballests that run the??? I have predators and they dont have a ballast they just hook straight to 12 volts, er at least I think they do unless the ballast is inside the headlight housing.
    Dec 2002
    Fed Way, Wa
    E46 M3
    i have he ccfl's and love them never had a problem
    Mar 2004
    Napa Valley, CA
    So the CCFL's are the ones with no ballast right?
    Dec 2002
    Fed Way, Wa
    E46 M3
    Quote Originally Posted by leedawg
    hey have a small box never had a problem and are the brighest i have seen
    SF (officially a city of so cal)
    e46 m3
    ccfl has a lil ballast
    328i RIP 4/23/2009
    PQ & USA
    --97 SC'd ///M3--04 ///M3 VERT--07 ESCALADE--
    the new chromiums carry a lifetime warranty and are rated @ 50000 hours they have proved very reliable over the past year with very few warranty claims, less the 2%.
    predator is the name brand of our latest ccfl line.
    they are available in 3 trims:
    thinline--> just the ccfl tube.
    oe----> ccfl tube + plastic cover for BMW oe look
    chromium----> ccfl tubes + oe plastic covers+ chrome backing for maximum output and great look.
    -zkw- -hella- -bosch- -depo- -prolumen- -kwd- -bbs- -predator chromium- -predator ice- -simota- -ecis-
    //-install guides-//-total lighting group buy-//-zkw group buy-// -exhaust group buy-//-ellipsoids+hid group buy-//-led tails group buy-//
    Dec 2004
    Snohomish, Wa
    so the OE predators are 100 on your website, and the predator chromiums are 170. So i am paying 70 for a chrome/metallic backing?
    PQ & USA
    chromium are $199, lifetime warranty, upgraded ballast and 50000 hour life span.
    for $100 you get 4 ccfl thinline basic rings, not oe.
    as described on the site:
    "No mounting system - you must use silicone to install
    No additional features in the ballasts
    No wiring harness"
    Quote Originally Posted by Spieluhr
    Dec 2003
    VALLEJO
    Boring E36
    no its not your ballast. Check your PNP. You have a problem there.
    U MAD?
    Dec 2004
    Snohomish, Wa
    why is it that when i unplugged my DDE's that the city lights came on? I thought the city lights wiring was cut for the DDE's.
    DeLand/Gainesville, Florida
    1996 328i
    This sounds extremely odd. I am almost 100% convinced that your wiring is incorrect. The DDE's will only work when wired with the correct polarity, but you can provide 12V to them a number of ways. Also, check the connection to your parking lights if thats how you have it wired. It sounds as if maybe you aren't getting a really good connection there and so you are having issues relating to that.
    Nov 2001
    SF Bay Area
    E30 E36 E46
    Your little black connector is crappy (the one between the ballast and each of the rings). The connection on the little tin pins are terrible for higher voltage. My dimming buzzing issues went away (on a previous kit long ago) when I cut the plug out and crimped it directly. I am 80% certain that is the source of your problems and headaches.
    PM is full. Do not PM me. EMAIL me to communicate!!
    *** SF Bay Area ***
    SRS Light Reset $15 (first 10 ppl, then free after that for everyone)
    The only replacement for displacement is technology.
    E46 03 325i
    E36 98 M3 Vert
    E36 95 M3
    E36 93 318IS
    E30 89 M3
    Feb 2001
    East Bay, CA
    M5, E61
    Oct 2005
    Hiddenite, NC
    96 328is
    I have problems with my dde's in cold weather aswell. If it is really cold they are dim but if it is just a little cold only three of them work. This is extremely annoying and looks really stupid. I'm dissapointed in these 600+ headlights.
    Dec 2005
    Philippines
    BMW E36
    I had the same problem with my halos before, the bulbs kept on getting burned for some reason and it was really annoying. The electrician finally figured out that i need reisistors to keep the current at the right level. Never had problems since. Although i don't know how long that is going to last. I spent a lot of money on it already.
    Play on.
    Nov 2003
    Happy Valley
    1996 estoril M3
    Mods, why the heck do my posts keep getting taken away from this thread?
    Mitch's Avatar
    Mitch is offline for science, you monster Secret Santa Deadbeat
    Sep 2004
    townsville
    cars
    umnitza, you have a pm
    Jan 2005
    New York City
    e30
    Hope you guys know that the raptors are out..
    Jan 2003
    Philly.
    06 M roadster
    I've allways had problems with my dde's
