Where is the ZKE module, is it behind the glove box?
And what colour is it?
Bump
behind glovebox only in cars 94+ the unit with the green and yellow connectors attached to it...there is also a black connector one in the back which needs to be disconnected to take it out.... to remove unit first remove front connectors...make sure cars off and windows are all up because removing the yellow and green connectors and then plugging them back in will reset the windows and even if they are down it will think they are up (its prob a good idea to disconnect battery as well)...then remove clip that holds unit in pull out a lil and reach behind to get last connector....
why do u want to know where it is? OBC retrofit???? if so the connector u want is the black one in the back
M42 Club Member 188- 1994 318is
Question. I'm Reading the OBC retrofit, and are the ZKE and Check Control Modules the Same??
