Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > M series > 1992 - 1999 M3 (E36)
1992 - 1999 M3 (E36) (1992 - 1999) BMW's second generation M3, and the first M3 to feature BMW's classic inline six motor. Featuring 240hp (european models had a 286hp and 321hp), a slick shifting gear box, and near perfect weight balance, the E36 M3 was named Car & Driver's "Best Handling Car At Any Price."
Old 11-24-2005, 09:42 PM
fliplap fliplap is offline
Mustard
Cars: 91 318i
e36 Carputer with GPS, MP3, Video, Bluetooth w/ Pics (56k maybe ok)
Finished being a relative term. This will be one of those projects that never ends.
Goals:
Retain stock look in the interior.
No wires visible anywhere in the interior. Everything is hidden and run along with the stock wire runs.
Retain as much trunk space as possible while still allowing easy access to carputer.
Retain ability to return car to stock. This means no heavy modifications of the interior. Sunglass holder was cut, thats about it.
No inverters. Why go DC->AC->DC
The Hardware:
Lilliput 7" 16:9 Touchscreen mounted in OBC/Sunglass area - Powered off of the M1-ATX so that the screen comes on and turns off with the car, as well as providing power regulation. I don't trust those silly adapters to properly prevent frying something as sensitive as a screen.
Via EPIA MII 10000 1ghz lower power motherboard
M1-ATX automotive power supply with shutdown controller - Carputer turns on with car, hibernates when car is turned off
10gig IBM Travelstar 2.5" laptop hard drive (planning to add a USB HD)
Hand built plexiglass case secured in the trunk
USA-SPEC DF-BMW audio adapter with 2 aux inputs
Orinoco/Lucent PCMCIA 802.11b WiFi card
Zoom USB Bluetooth dongle
Globalstat BU-353 USB GPS reciever mounted on rear parcel shelf
USB 1.1 hub in the front behind the screen
USB 2.0 hub in the trunk
Lots of cables and wiring
RoadRunner CarPC interface including:
MP3 player
Video player
iGuidance GPS - With 2D and 3D map display and voice guided directions
Speed camera alerts
NES/SNES/Genesis/Gameboy/Other emulator.
Bluetooth phone integration - Can view battery level and incoming calls, place outgoing calls from phonebook, view recieved/missed calls, send SMS messages and use for internet connectivity when not near a WiFi access point.
Pictures:
Old 11-24-2005, 10:01 PM
hatm3's Avatar
hatm3 hatm3 is offline
Precious Roy
Cars: 1998 M3 Sedan (Sold)
That really looks good. Did you have to do any modification to the OBC/sunglasses area besides cutting the piece in between?
Also, did you keep your OBC inside somewhere?
Old 11-24-2005, 10:03 PM
Mustard
Cars: 91 318i
I did have to trim a small ridge, but I left enough of it that the OBC can still be remounted. And I did not relocate the OBC. I only had the 11 button and didn't find it useful for anything.
Old 11-24-2005, 10:20 PM
95MMM's Avatar
95MMM 95MMM is offline
Stock is SEXY
Cars: 95 Alpine White ///M3
sick
what was the total price?
///M3 Cc#65
95 M3 Alpine White Acquired 6/17/03
Cosmos Racing 3.5" CAI / AA Stage II Euro HFM Kit / UUC Stage II Flywheel / M5 Clutch / AA Gen III Exhaust / Bilstein + Eibach Prokit / OEM X-Brace / AA Strut Brace / ZKW + OEM M5 Projectors / Philips 85123 upgrade
97 Integra LS-Turbo Sold 6/14/03
10 psi of boost
Old 11-24-2005, 10:41 PM
souroull's Avatar
souroull souroull is offline
Cars: 97 M3
Send a message via AIM to souroull Send a message via MSN to souroull
thats nice, where did you get that case?
Old 11-24-2005, 11:04 PM
98M3Sedan's Avatar
98M3Sedan 98M3Sedan is offline
Cars: 98 M3 Sedan Manual (Esto
Very Clean.!
Old 11-25-2005, 12:30 AM
deilenberger deilenberger is offline
Fanatic
Cars: '01 MCoupe '02 M3C/6
That is exceptional work. Looks factory.
Where can more info be found on the software (RoadRunner CarPC)? I'll do a Google, but any info would be neat.
And how is the touch screen to use? I assume hard to use when moving since it's located low and would require attention to use..
Don Eilenberger
'01 M-Coupe, '02 M3C/6, '03 525iaT, '07 R1200R
Old 11-25-2005, 01:27 AM
Daved's Avatar
Daved Daved is offline
Moderator
Moderator
Cars: 5/94 Euro 325i coupe
Great work. Congrats. I love carputers.
25/May/1916 ~ 26/Jun/2006 RIP grandma
Originally Posted by ClintonM3 View Post
the Audi A4 is a tweaked, cosmetically enhanced, cross platform, put-together overnight VW.
Originally Posted by joeuser528e View Post
Staggard setups are for cars that you park at show meets. They go well with 5 screens and 3 12"s.
Old 11-25-2005, 01:40 AM
NegativeCamber NegativeCamber is offline
style 5s are not rs'
Cars: 95M3, 92 325, 97 528
The Hardware:
Old 11-25-2005, 01:42 AM
Hammer03's Avatar
Hammer03 Hammer03 is offline
In Pursuit
Cars: '98 M3, '74 2002
mp3car.com has a lot of information deilenberger
thats a very clean install man! nicely done. did you angle it up at all to see it better? and how is the glare, are you having any issues?
Old 11-25-2005, 02:21 AM
Skipjacks's Avatar
Skipjacks Skipjacks is offline
Cars: 1997 ///M3
The use of the touchscreen at that level isn't difficult at all. I've got one there too. It's right in front of the shifter so your hand is always right there. It works wonderfully.
I want to try and change a spark plug while the engine is running.
Old 11-25-2005, 02:24 AM
RUddin3's Avatar
RUddin3 RUddin3 is offline
Cars: 1998 BMW M3/4
Send a message via AIM to RUddin3
Very neat. You should definitely be proud of your work.
How is visibility while driving? I wish we could be able mount the screen higher (like in place of the radio and climate control), as I'd gladly move those less often used controls so I could get a better view from a quick glance at the screen.
Drive Safely,
Raza
1998 BMW ///M3/4 - a few Dinan goodies
FS: Xenon Relays for OBC LBF
Old 11-25-2005, 03:39 AM
LazyUSN's Avatar
LazyUSN LazyUSN is offline
What?
Cars: 2004 GMC Yukon Denali
Send a message via AIM to LazyUSN
so how much do you want to build me one
very nice clean setup man! i like it a lot!
SOLD 8/95 Alpine White M3 ~61k miles
UUC Stage 2 8.5# Flywheel | E34 M5 Clutch | Euro 3.5" HFM | TMS Conforti Chip | ECIS Intake | AA Track Pipe | AA gen 3 exhaust | AA Short shifter | H&R Race springs | 18x9 TSW Kyalami's (gunmetal w/polished lip)
Ordered/In Garage: GC Track/School Coilovers, GC RSM's, UUC SwayBarbarians F/R, GC Adj. Endlinks, GC LCA's, AA DSB...
Old 11-25-2005, 07:44 AM
Rory's Avatar
Rory Rory is offline
McLaren MP4-25 FTW
Cars: E36 M3 Evolution, Me
Send a message via AIM to Rory Send a message via MSN to Rory
Very interested in this, great job!
Old 11-25-2005, 10:30 AM
Mustard
Cars: 91 318i
Too much. Its one of those projects that nickels and dimes you to death. I suppose the entire thing came to about $800 all said and done.
I built the case with about $10 in 1/4" plexiglass, a $3 plexiglass cutter and about $5 in L brackets, hinges and screws. Definatly use a plexiglass cutter and not a dremel if you're going todo it, it take a lot longer but its easier to cut a straight line. A table saw would be ideal.
I used metal brackets only because I couldn't find an adhesive that would bond plexiglass in a reliable manner. It turns out that Weld-On #4 or #16 will do it, but it isn't available at Home Depot. Weld-On MEK is available ay Home Depot but apparently doesn't do as good of a job.
To be honest I probably won't keep the case. A 10" by 10" junction box will hold everything, only costs $20 and I think I'd feel more comfortable with a metal case.
The best place to find out anything about CarPCs is MP3Car.com. The frontend forum is here: http://www.mp3car.com/vbulletin/forumdisplay.php?f=60 The most popular choices are Centrafuse, Frodoplayer and RoadRunner. I tried Centrafuse but decided not to use it because its commercial and comes wil the Destinator GPS software, which has really lousy routing in the US. At the time I was looking I wasn't impressed with the selection of skins available for Frodoplayer, they all seemed to have very small buttons, which isn't good for a CarPC.
RoadRunner was the logical choice for me. I liked the skins available and it integrates nicely with pretty much any GPS software. Best of all, it is open source and me coming from the linux world, I just felt more comfortable knowing that I could see and modify the source if I needed.
As for the screen, its a Lilliput 619GL-70NP w/ the touchscreen option. I don't usually plug vendors, but MP3Car.com's store worked out well for me. The first one I got refused to display the color red. They pretested a new one for me and sent it out while I sent the other one back. I would definately ask them to pretest yours if you decide to order one.
I did not angle it up. tried that approach but I didn't like how it looked. The only time that glare is an issue is just after sunrise when heading east. Any other time its fine, even with the windows down and the sunroof open. I do have a black interior though, I'm sure that helps quite a bit.
The visibility while driving is great actually. The fonts for everything are huge so I can read it at a quick glance. You can mount the screen in the radio and climate control area but it isn't easy. You have to fab a mounting plate for the screen and move the CC and radio down to the OBC area, which requires rerouting the heating ducts and doing a ton of cutting and wiring. I'd say its not worth it.
I'm an insane safe driver, I don't dial, pick up, or use my cellphone while driving. The only reason the bluetooth features are there is because I already had the USB bluetooth dongle and wanted to be able to send music and pictures from my phone to the carputer, all of the other integration was just a bonus. I don't play with the screen at all except maybe to change tracks. Since the buttons for that are all arranged along the bottom it was easy to memorize where they are.
Thanks for all the compliments and questions guys! It was a fun, but time and money consuming project with more than a few headaches. I really thought it would never get done.
Old 11-25-2005, 12:35 PM
hinzm3 hinzm3 is offline
Senior Member
Cars: 99 M3,88 325,06Civic
Send a message via AIM to hinzm3
That looks really clean! Great job
Old 11-25-2005, 05:01 PM
clumpymold's Avatar
clumpymold clumpymold is offline
clumpy mold
Cars: B7 Audi & Yamaha R6
Send a message via ICQ to clumpymold Send a message via AIM to clumpymold Send a message via MSN to clumpymold Send a message via Yahoo to clumpymold
Wow, that looks really nice. But I like my OBC though. Can't think of parting with it.
2005 Audi (Purchased 07/09) - 2005 Yamaha R6 (Raven) (Purchased 5/06)
07/97 BMW (Sold 08/09) - 03/01 Audi A4 1.8TMCX (Sold 06/03)
Please do NOT PM me! Email me: clumpymold@sbcglobal.net
Old 11-25-2005, 05:46 PM
souroull's Avatar
Cars: 97 M3
i've been meaning to tackle a project like this for quite a while but money is keeping me back, lol. i feel exactly the same as you do, since its only been a couple months since i've retroed the 18b obc. i've been planning to move the climate control at the bottom where the sunglass holder is (a bit of bodo work will do the trick, and some texture paint to get an even more updated and sleeker look) and then make a bezel for a screen where the head unit is (and get rid of it )
Old 11-25-2005, 09:37 PM
Beamin''s Avatar
Beamin' Beamin' is offline
Original Member
Cars: 98' 328i, 91 318is
A lap top hard drive can withstand the bumps of driving? How long does it take to boot up?
Old 11-25-2005, 10:58 PM
Mustard
Cars: 91 318i
I chose a laptop hard drive specifically because they can withstand the shocks of driving. The IBM Travelstar drive I have in there can withstand 125g for 2ms while operating, which is signifigantly more than you should see while driving your car. The highest (that I know of) g-forces survived by a human was 83gs in the 1950s, it caused the guys retinas to detach. Granted that was for more than 2ms. There was a chimp that survived just short of 250gs in 1ms, but he passed out. I swear I'm not that big of a nerd, I watched a thing on the history channel about plane crashes and the ability of the human body to withstand impacts. Either way, if you're seeing 125gs of shock in your car you're in serious trouble. Its also mounted using some small rubber spacers to absorb a small amount of shock, but not enough to cause the drive to bounce around.
Depending on how I have it setup it takes 10 to 30 seconds to boot. 10 seconds is if I have it set to standby. Problem with standby is that the power supply will shut it down completely after 2 hours, to keep it from draining the battery.
Right now it takes alittle under 30 seconds to come back from hibernate, with all of the GPS and audio ready to go. And this way it doesn't put any drain on the battery.
Old 11-26-2005, 12:01 AM
m3ntalmn m3ntalmn is offline
Cars: MCoupe,M5t,M635CSi
absolutely amazing. that is really impressive the oem+ look of the system is just great. you have much to be proud of congratulations on an awesome project.
Old 11-26-2005, 01:54 AM
SQ Bimmer's Avatar
SQ Bimmer SQ Bimmer is offline
License Suspended
Supporting Vendor
Cars: '05 Ram 1500
Send a message via AIM to SQ Bimmer
I have been planning to do something like this for quite some time, but have been worried about the passenger being able to see the screen while in 5th gear.
Old 11-26-2005, 02:10 AM
waferGS waferGS is offline
Cars: '00 A4 Avant, '99 Co
Nice setup!
I thought about doing this with some spare parts lying around - but the OBC is useful for me. Decisions- decisions...
Old 11-26-2005, 10:55 AM
Skipjacks's Avatar
Cars: 1997 ///M3
It's not a problem. The shift knob in mine doesn't block the screen in 5th. In 3rd it does, oddly enough, but not in 5th. (3rd puts it right in the middle of the screen.)
In 5th it's to the right side and if the passneger leans back it's out of view.
Old 11-26-2005, 03:07 PM
Mustard
Cars: 91 318i
I meant to post this earlier too, but check out what I found stuffed under the center console while I was ripping it apart to running cables and wires. Thank goodness I found them all before getting pulled over by a cop who happened to have a drug dog with him.
Last owner was riding the white pony it seems...
