Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > M series > 1992 - 1999 M3 (E36)
1992 - 1999 M3 (E36) (1992 - 1999) BMW's second generation M3, and the first M3 to feature BMW's classic inline six motor. Featuring 240hp (european models had a 286hp and 321hp), a slick shifting gear box, and near perfect weight balance, the E36 M3 was named Car & Driver's "Best Handling Car At Any Price."
Old 11-22-2005, 03:27 PM
EricP's Avatar
EricP EricP is online now
Cars: 97 M3/2
Send a message via Yahoo to EricP
HIR lights?
http://www.rallylights.com/hella/9006.asp
Quoth the link:
Halogen Infra Red 9006/HB4 Bulbs - 12V
General Electric patented this new technology in 2000. Their intention was to creat a bulb that emit about 3/4 as many lumins as an HID capsule at a fraction of the cost. The technology was licensed to Toshiba for automotive use.
The technology involves a specially shaped quartz globe which has multiple layers of semi-reflective materials deposted on the surface. The coating reflets a portion of the Infra red energy emited by the filament back to the filament causing it to glow hotter and produce more light, which escapes through the uncoated forward portion of the globe. Even though the filament runs hotter, the bulb produces about the same amount of heat as a stock bulb.
Interestingly enough, the 9012 bulb can be used in a 9006 lamp with a simple modification with a Dremel tool or file. Due to federal regulations, we can not make this modification, but you, the end user, can. The material to remove is marked on each bulb.
Is this the right bulb to use in our cars for the HIR mod with stock US headlights? Just zip off a bit of plastic with a dremel and use these puppies? I want more light and I don't want to bother with HID. I have been looking for a site that stocks these.. and here they are. It looks like a pair would cost ~$60 from this site
Has anyone tried this?
97 M3/2 Lux
Old 11-22-2005, 03:34 PM
Daved's Avatar
Daved Daved is offline
Moderator
Moderator
Cars: 5/94 Euro 325i coupe
I've made a thread on HIR a while ago...
http://forums.bimmerforums.com/forum...d.php?t=390552
25/May/1916 ~ 26/Jun/2006 RIP grandma
Originally Posted by ClintonM3 View Post
the Audi A4 is a tweaked, cosmetically enhanced, cross platform, put-together overnight VW.
Originally Posted by joeuser528e View Post
Staggard setups are for cars that you park at show meets. They go well with 5 screens and 3 12"s.
Old 11-22-2005, 03:37 PM
EricP's Avatar
Cars: 97 M3/2
Pfft!
97 M3/2 Lux
Old 11-22-2005, 04:10 PM
deilenberger deilenberger is offline
Fanatic
Cars: '01 MCoupe '02 M3C/6
Quoth the link:
It appears to be the correct ones. The ones you want are made by Toshiba. There are some crap Chinese ripoffs that are not a good bulb (little things like the filament being purposely off center..)
You can also check http://www.finemotoring.com as another source.
Here is a tiny little article about bulbs for the stock housings:
http://www.bmwcca.org/members/AM/Tem...e_Be_E36_Light
Have fun!
Don Eilenberger
'01 M-Coupe, '02 M3C/6, '03 525iaT, '07 R1200R
Old 11-22-2005, 04:19 PM
EricP's Avatar
Cars: 97 M3/2
I appreciate it.. I can't really find a definitive answer on if they are significantly brighter or not, but the one guy that says not claims to have bad vision anyway. Go figure.
If my stock halogens are old and faded.. I may as well give it a try sometime. Now I just need to find a dremel
97 M3/2 Lux
Old 11-22-2005, 04:29 PM
Fanatic
I believe you might find the "definative answer" on if they are significantly brighter in the article I referred you to.
At least that's what I tried to do.. give actual data...
Don Eilenberger
Old 11-22-2005, 04:30 PM
EricP's Avatar
Cars: 97 M3/2
I think I read that a long time ago, EXCELLENT article I will give myself a refresher I suppose.
97 M3/2 Lux
Old 11-22-2005, 05:40 PM
nismo skyline nismo skyline is offline
Cars: M3
they sell toshiba hir bulbs on ebay for 30 each. search in parts & accesories for "toshiba hir". the 9012 will fit 9006 and 9011 will fit 9005 with a little trimming. this is a pretty popular modification in scion forums i visit.
