Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > M series > 1992 - 1999 M3 (E36)
1992 - 1999 M3 (E36) (1992 - 1999) BMW's second generation M3, and the first M3 to feature BMW's classic inline six motor. Featuring 240hp (european models had a 286hp and 321hp), a slick shifting gear box, and near perfect weight balance, the E36 M3 was named Car & Driver's "Best Handling Car At Any Price."
Old 10-17-2005, 12:06 AM
LuxoM3's Avatar
LuxoM3 LuxoM3 is offline
Power to the Yellow Man
Cars: 1995 M3/2
Send a message via MSN to LuxoM3 Send a message via Yahoo to LuxoM3
Why the B&M might not be a good shifter... (pics)
Hey Guys, checking in after a couple hours of being under my M3...Below you'll see a pic of a de-installed B&M Short Shifter from my 1995 BMW M3. A little backround...I bought my 1995 used from the original owner, the car came with a 45126 Model B&M Short Shifter. The shifter was installed brand new and has less than 10k on it.
The Issue
On warm days (70+ degrees) and/or under hard driving, the heat from the Catalytic converters heat up the transmission tunnel...thus causing the shifter linkage to have a binding feeling. I've had the tranny fluid changed to Royal Purple Syncromax about 2 weeks ago. Good stuff, that helped BUT as soon as the next warm day came, the shifter would bind.
The Symptoms
When cool, the shift is smooth and feel great! Fast fast fast. BUT On a warm day, the shifter would almost fight against you...it feels like you are forcing it to get it into gear. You can feel/hear a CREAKing in the linkage. It's defnitely noticable. It's not shifter slop or bad synchros (as you would notice those issues even when cold).
The Design and Thermodynamics Issue
I've driven one other BMW with a similar B&M short shifter (it had a similar issue) and asked around online...this binding issue isn't new and a couple of calls to various BMW vendors tell of customers with similar experiences. The B&M at sub $200 might be a great price and offer great shifting, but once that heat issue kicks in, it makes the shifter useless.
Ok here's the skinny, you'll notice from the pic that the shifter shaft is similar to every one elses, stainless steel and an aluminum top portion. The B&M has a nice feature in that you can pretty much just drop in the shifter (as it comes almost pre-assembled and it sits at the right height and utlizes the stock shift linkage. Shifts are fast and smooth.
BUT, here's where the fairy tale ends...once your car is pretty warm (i.e. the cats are flaming red)...the transmission tunnel begins to get some heat. You'll notice this especially driving in stop/go traffic, city traffic, etc. on a warm day. This heat collects in the tranny tunnel where the shifter is at the highest point (think heat rises)...The aluminum carrier of the shifter soaks up this heat (aluminum loves to soak up heat) AND this heat is transferred to the aluminum bearing collar of the shifter... from this point ignore the blue carrier and concentrate on the bearing collar and bronze bearing of the shifter.
According to B&M, this collar and bearing are "self lubricating". But if you have a look at this unit, there is no lubrication other than a thin oily film.
Once the shifter collar is heated up, it begins to resist the movement of the bronze bearing. I tried looking up the expanions properties of the bearing and collar and came up with 2 theories:
1. The brass bearing gets hotter and expands. Not a lot, but enough to take up the gap between itself and the collar, thus offering resistance.
2. The heat buildup increases friction - it breaks down whatever little lube there is in there
If you had this unit to try right now off my car, it actually fights you as you try to rotate the bearing collar around the bearing. Not to noticeable when the unit is on the car and leverage helps you move it around.
All in all, I'd advise strongly against any of you guys buying this thing.
I've got an MRoadster lever in my M3 for now, but am looking at the UUC or Rogue units as an option.
Hope you guys found this helpful.
-Percy
BMW CCA Member 186373 - Golden Gate Chapter
(Retired - Chapter Representative, Bombe Magazine - "The Toy Box" Product Review Writer)
1995 E36 M3 (sold 1996 E36 M3)
Arctik Silber : LTW Splitter • Turner LTW5 Rims • Apexcone/ZKW HID Lighting - 55w DDM 4500k Low-Beam & 35w DDM 4500k Fog-Lights • Z3 Steering Rack • Bosch 800 (Part #0 280 217 800) 3.5" HFM • 3.5" ECIS Intake • F1 Racing 16lb Flywheel • TRM Chip • Rogue RSM • Borla Exhaust • UUC SSK + DSSR + Tranny Enforcers • Koni SAs • Eibach Sport Springs • Strong Strut • UUC Stainless Lines • Euro Rotors • Sumitomo HTR III • PIAA Wipers • Recaro Baby Seating
