Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1991 - 1999 (E36)
1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury.
Old 06-26-2005, 11:05 PM
Sarwat Sarwat is offline
Cars: 97 328i sportpkg 5-spd
Question How do you remove/install these hose clamps ?
It seems on the bimmers they are everywhere and I can't figure out what these clamps are called, how to remove them easily and what tool is needed to install them ?
I just took this one out of the power steering hose and replaced it with the standard worm type hose clamp.
| CDV delete | ASC delete | Fan delete | debaffled airbox
| H&R sports | Koni SA | 3.23 LSD | M3 CABs | M3 RTABs + shims | UUC Red TME
| Understeer SSK | Rear subframe re-inforcement | Powerflex subframe bushings (update: went back to stock) | Porterfield R4 pads
Old 06-26-2005, 11:16 PM
Steve530's Avatar
Steve530 Steve530 is offline
Cars: 2001 BMW 530i
Those are crimp on hose clamps. There's a special tool to install them. I've always just used a screwdriver to expand the top to remove the clamp.
You're better off with the screw type hose clamps because these can loosen over time.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads/M5 SSK/RedLine MTL/M5 rear sway bar
1998 323is CDV delete/Findanza LWFW/M3 clutch/Denso Iridium
BMWCCA Member #337964
Old 06-26-2005, 11:19 PM
abemcclellan abemcclellan is offline
BMW Enthusiast
Cars: 1994 325is, 300zx Turbo
agreed.
