Just starting to get my feet wet...
AA Stg II turbo package arrived today and I managed to hang a couple of the bits. I had some concerns about clearance issues for the intercooler and piping; looks like they were largely taken care of with the supplied electric fan, rack mounted power steering fluid cooler and revised righthand engine mount.
More to come...
You are going to have too much fun with that.
BMWCCA #364799
Peake SRS airbag reset/diagnostic tool $95 shipped
Searching for my 848 Unicorn
"Have a mind that's open to everything, get attached to nothing" - Busey-ism
Randy,
The brass tubes near the rack are power steering cooler lines?
JMC
Motor: Hurtig/AA custom 2.0l TS OBD2 AA tuned 444whp/384wtq SAE 470whp/400wtq STD
Exhaust RMS headers, Maximum PSI custom exhaust, magnaflow mufflers
Driveline E46 M3 6 SPEED, 2.93 LSD, Rouge SSK/tranny mounts, UUC Ultrasmooth /LTW steel flywheel. CDV delete, UUC clutch pedal bushings with GSP pedal
COOLING: Stewart WP, 78* thermostat, S54 radiator, Euro/S54 oil cooler, ES TS oil cooler adapter, M3 power steering cooler
HANDLING: MR M CAR SF reinforcement, TCK D/A CO 450/500, TCK Camber Plates, Rogue RSM, Ireland SFB, Dinan STB. CCW classics, polished lip, brushed centers. P295/30/18 P245/35/18.
THE SHOW: Stygar Z8 Nozzels, Leather Z armrest, Z8 push button start, chrome door handles, OEM FOGS, BMW Traffic Pro.
Monitoring: PLX Wideband, VDO vision boost/VAC both with custom chrome trim ring.
COMING SOON: custom intake
So does this put a 3rd Z in the Forbes garage?
Looking good. I guess I don't have to ask for you to keep us posted
Scott///M | BeerTech #467 | Spec E30
Very nice, I can't wait to come see that next week.
-Jason
Weekend Car
'99 Boston Green M Roadster - intake, M50 manifold, schrick cams, magnaflow exhaust, TCK D/A Coilovers 500/600, RD front bar, ltw flywheel & clutch, harddog rollbar, schroth harnesses, zionsville radiator, S54 oil cooler, stewart pump, etc ..... ~245rwhp
Only temporarily, this Coupe lives in Minnesota. The car came in for the differential mount upgrade and stayed for a little performance makeover.Originally Posted by Scott///M
There's been lots of visitors (2 M Rdstrs & 3 M Coupes) to the Forbes' garage lately, also known as Sports Cars Plus, LLC.
Correct.Originally Posted by JMC
Might have to put you to work too...Originally Posted by JBgotM
I just had a boner.
1999 Cosmos Black/Dove Grey BMW ///M3 convertible - 5 speed - SOLD
2005 Atlantic Blue Pearl/Taupe Leather Subaru Legacy 2.5 GT Wagon - 5 speed - SOLD
2014 Tenorite Grey/Black Mercedes-Benz GLK 250 - bone stock.
2013 Bianco/Rosso Abarth 500c - 5 speed
2016 Oxford White/Grey Ford Transit 250 Powerstroke 148 MR (DIY RV conversion)
so how much do you charge to install a turbo?
1997 Arctic Silver/Black M3
1999 Techno Violet/Dove M3
Is the turbo the mits with the T60-1 compressor why the engine mount was modified.
AA Stage 1 Gen III, BMP head gasket, Bored Throttle Body, 3.0"DnPipe & Custom exhaust with AA Gen 2, Aquamist 1s water/methanol injection,
Last dynojet Aug 02 248c SAE 369whp/354ft-lbs at 10.5psi, 1/4mile 12.6@116mph
New Sept 02 Head work and exhaust porting, April 04:UUC Pulleys, Turbo to intercooler pipe 2.5" Aug 04 3.5"HFM,11.5psi
The converted 20g/60-1 needs the motor mount b/c of the off-set of the manifold that sits the turbo in a lower position, compared to the Turbonetic's manifold used on the TT kit, that has fitment for the turbo to located abit higher.Originally Posted by M3TurboCa
Good old days...fun, fun, fun...
You might want to wait until I get this one (maiden voyage) done firstOriginally Posted by BMWManiac
I expect I would be less expensive than most shops, due to a much lower overhead. I wouldn't even pretend to be an expert though, you'd have to be going with an approved & coordinated package and I could install it.
To be truly cost effective, I would presume you're located near Toledo, Ohio...?
Are you going to be doing the headgasket yourself? If so, will you please take alot of pictures.
TEC-3R, T4 GT40, WISECO, EAGLE, SUPERTECH, O-RING'D "FRANKENSTEIN" STROKER.
Don't mean to speak for Randy, but
http://forums.bimmerforums.com/forum...d.php?t=335226
Could you do me a huge favor and take a few pictures for me??
Im looking for one of the same view as you had of the engine mount but with the turbo and no intake pipe installed...And then one of the piping comming through the engine mount, and then one of where the intake piping goes to...
Im about to upgrade my turbo and am trying to figure out my low level intake...
looks great! i did all of this a few months ago!
-Keith
Duuuuuuuuuuh, thank you!Originally Posted by caldweb
Very cool, looks like you're almost there... when are you hoping to fire her up?
Boris
'96 Cosmos Black M3 422rwhp/407rwtq SAE @ 13psi / 444rwhp/444rwtq SAE @ 14.5psi
Engine/Drivetrain: Technique Tuning Stage 2 Turbo TT Turbo Exhaust, M50 Manifold, TMS Oil Baffles, SSR Comps, SPEC Stage II Clutch, UUC SSK, Titanium Cavallino Ti-130R Shift Knob, UUC TME, EMC Diff Bolt, RCCA's. Suspension: GC Coil-overs, GC RSMs, GC RTABs, GC Trans Mount; H&R SB. Instrumentation: VDO Boost, VDO Oil Press, VDO Oil Temp, VDO Water Temp, BMW Traffic Pro Navigation, Valentine One TODO: W/A Injection
Okay, usuall shop rates will apply...Originally Posted by icemann633
j/k!
I'll be taking dozens of pictures during the install, it's what I do (www.rfdm.com/gallery , this car is album "crc"). I'll try to keep your request in mind.
Another turbo M roadster/coupe.. cool!
Can't wait to see the results...we'll finally get to see how your subframe mod holds up with the turbo!!!
-Dave
Originally Posted by Randy Forbes
Looks like an "expert" did it to me!!
jmc
Wow...seems like everyone's going FI
Looks great Randy
Nice to see another M Coupe getting a turbo upgrade!
drool.....
how much power are we looking at?
sushi sushi!
wtf is moadster and his turbo? my off shore acct is tapped out for the AA.
google-black.blogspot.com kenvsryu.tumblr.comsonyalphanex.blogspot.com
Spence:You ever kill anyone? Sam:No, but I did hurt somebody's feelings once.
join the Bimmerforums Chat: http://youtube.com/stream?s=235077632
of course.... The reason you probably didnt recognize them is that on most M3s, they are black, and covered with grease and oil from the notoriously leaky lines.Originally Posted by jmc
___________________
Paul E
'11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
http://s11.photobucket.com/albums/a173/boostm3/
