Put your hand into the cubby and reach your finger through the hole in the top. Apply pressure to the spring action clip on the bottom side of the OBC and then pull out at the same time.
To argue with a person who has renounced the use of reason is like administering medicine to the dead. ~ Thomas Paine
You can safely assume you've created God in your own image when it turns out that God hates all the same people you do. — Anne Lamott
Custom watch straps for sale
FOR SALE: watch straps!!
E36 DIY: My articles are now located in the E36 DIY page
Pull the OBC all the way out and remove the cables if you like. Then lift up on the cubby while gently pushing down and forward on the bottom part where it clips to the shifter surround just above the shifter boot.
Tilt the cubby forward and wiggle it out of the shifter console.
This is what the cables look like from the back. Remove them simply by pulling them out.
Apply even pressure to the back of the switches and push them up through the console to remove.
this is what the wires look like going to the back of the cigarette lighter.
It's out.
Install new cubby in reverse order
Just push the OBC back into place and you are done.
WHen I looked at your pics, I remember why I did the Woodgrain Delete Mod. Why did you replace the whole cubby though?
Turner Perf Chip/Fan Delete/Sparco Strut Tower Brace/X-Brace/JTD Underpanel
Zimmerman X-D Rotors/Axxis Ultimate Pads/Solid Caliper Guide Bolt Bushings
UUC EVO3/DSSR SSK/3.15 LSD/Cosmos Racing CAI V2/ASC Delete
96+ M3 LCA/LCAB M3 RTAB and GC Shims
BMW OEM Alarm/Woodgrain Delete/Blizzaks baby!/16x7 BMW Style 30 Sport wheels
eh...why not?
I had the other cubby and now I can sell the complete cubby with wood grain...if anyone will buy it.
Just because you could have changed the insert for $7 and not have had to buy the new cubby or remove it is all. The insert is a seperate part and is replaceable.Originally Posted by old skool
yeah...but I had fun and got to do the write up.
But that is good info for others. Thanks
"If it ain't broke, fix it"Originally Posted by old skool
Thanks for taking all this trouble to make these great DIY guides, keep up the good work!!
Glad it was helpful.
When I swapped out my woodgrain insert, I had to remove the whole cubby to get it out as I didn't want to risk breaking the wood panel. I'm glad I did - I don't think I could have removed the panel without taking out the cubby first.Originally Posted by hellrot325
BigBilly
1987 M6 Cinnabar Red (I think) / 2014 M5 Alpine White / 1998 328iC - sold
Hey everybody - it's been a while. Glad to see BF.com is still thriving.
Any pointers on care and feeding of an E24 are appreciated.
Some of these things should be self-explanatory lol.
93 E36 S50 c38 stg2
00 B5 A4 GT2871r
01 E46 325i - 343,782 (Stolen 3/2021) RIP
2019 WRX
auto->manual conversion crew / bf.c motor swap crew
Thanks for the writeup... I need this because I plan to remove mine to drill for my XM Roady.
My 12 V socket is not working and that's no good because I can't plug my portable air compressor into my own car to pump up the tires. So, you have to take the OBC out to get to it, right? This may be a dumb question but, do I need to disconnect the battery before doing this?
'14 Evora S - Chrome Orange/Ebony
'02 M5 - Carbon Black/Silverstone
'15 M235i xDrive - Mineral Grey/Black
No need to disconnect the battery.
Did this the other day to see what was wrong with my cig lighter socket. And like a dumbass, I didn't think to check the fuse first. Yep, that was it, lol. Oh well, it was easy to access the lighter socket, no tools needed to remove OBC and sunglass cubby.
good thread
I noticed you took out the part above the cubby [I forget what its called lol) im guessing this is necessary to take out the cubby since i cant get mine out without it sounding like its about to break?. haha
Can u please let me know how to replace the cubby, my backlight on the clock and date is not working, so i am trying to change it i bet, guy told me to check the whole diy , but i wonder if i can remove just cubby and reach the backlight screen or bulb, thanks
