Obviously the first step is to remove the rear parcel shelf.
After that you have to go into the trunk and remove one nut as well as the light bulb socket.
To argue with a person who has renounced the use of reason is like administering medicine to the dead. ~ Thomas Paine
You can safely assume you've created God in your own image when it turns out that God hates all the same people you do. — Anne Lamott
Custom watch straps for sale
FOR SALE: watch straps!!
E36 DIY: My articles are now located in the E36 DIY page
Then lift up above the bolt and wiggle backwards to remove:
Disconnect the wiring harness and you are done.
Do you have a DIY, as to how to remove the rear parcel shelf? Or is it totaly straight forward?
what is the benefit to this?
AC Shnitzer 17" wheels, Alpine head unit,iPod integrated, clears all around, Debaffled Airbox,
Yeam in my case I'm trying to figure out how to remove the shelf, to cover it in suede... but don't want to damage it so I'm seeing if hes got a write up for it.
It is here:
http://forums.bimmerforums.com/forum...d.php?t=348275
Starting with post #37
good thread
sorry for bumping an old thread...old skool, do you get an OBC light when you do this?
I didn't keep it out, so I can't say
Any specific reason why you didn't keep it in? I'm planning on doing this today or so.
Edit: Maybe I'll just pull the bulb...
i moved mine out so the tinter could tint that area because imo its looks butt ugly when u just tint around it
Bumping this instead of making a new thread. In my e36 m3 I bought I have a rear brake deck lid like in this thread. The car came with a oem spoiler like this..
I removed the spoiler and I am adding a Abrahams LTW wing. Right now when I look in the trunk to add a bulb to the third brake light it looks exactly like the first post in this thread.
I found out I need a 7506 bulb and when I went to put it in it obviously doesn't fit. Is all that I am missing is this.
http://www.ecstuning.com/BMW-E36-M3-...rake/ES174244/
It looks like there is a plug connector on this. Or am I seeing things. Do I just need this piece and put the bulb in it then put that in the opening in the car? Thanks in advance for the help. I feel like an idiot but it's hard to find the answer while searching. That's how I came across this thread in the first place.
Oh I guess it's not a plug. Looks like that piece is all I need.
how did you get this spoiler off??? http://images.bimmerforums.com/smilies/help.gif
