This isn't a true walkthrough as I have already removed a lot of it and didn't take pictures. However removing the maplight itself can be a bit of a pain when you have to reach through the small and sharp hole in the headliner.
Hopefully these pictures can help you get an idea of how to go about doing it.
You first have to remove the wiring harness going into the map light:
To argue with a person who has renounced the use of reason is like administering medicine to the dead. ~ Thomas Paine
You can safely assume you've created God in your own image when it turns out that God hates all the same people you do. — Anne Lamott
Custom watch straps for sale
FOR SALE: watch straps!!
E36 DIY: My articles are now located in the E36 DIY page
Then you can release the map light connector by pushing in on the two levers in the middle of the top of the connector. Then slide it backwards and the map light drops out.
hey thanks for all your DIYs! Do I need to remove the headliner or the sunroof jam trim to disconnect the maplight? I had a go at it today (sorta) without taking off those 2 parts. Doable?
So can I pry the harness and connector down from those 2 pipes so that the black connector would come off without damaging anything? Or would I have to disconnect the harness first and then disconnect the other part from the black connector which connects to the 2 pipes? Thanks!
